Question about Canon i80 InkJet Printer
Hi, my canon i80 printer wont feed paper through
Hi, my canon i80 printer wont feed paper through at all. even when i push the buttom 3 times. the printer makes an awful buzzing start up noise. the printer is about 3 years old and i truly never dropped it and i barely used it. i did clean the print head and remove any excess ink and paper from ink slots. any help greatly apprciated. thanks
There is only one solution to the problem with the i80. Here it is: there is nothing jammed. This problem is the result of the top of the printer being pushed down, effectively crushing the paper feed path by a sixteenth of an inch, right at the center of the machine. Likely this is the result of being carried in a travel bag full of other stuff, like the power supply, or from things being placed to rest on top of the printer. The solution is to open the two top covers, to grasp the main steel bar that runs the entire width of the printer with a pair of long-nosed pliers and to simply apply upward pressure. This will, in turn, lift a black plastic paper guide that has been pushed down into the path of the paper by the slightly bent metal. The printer will happily feed paper after this relatively simple fix. Mark the problem up to bad industrial design (though the mechanisms of the printer are otherwise ingeniously well thought out).
Posted on Jul 17, 2012
  • Ronnie Dec 05, 2013
    How does one open the tope 2 covers? I have removed all the screws from the outer case and cannot separate the top and bottom with reasonable force.
SOURCE: Canon MP 160
I had the same problem with my mp 160, I tried to print but the printer only took the left side of the page and the paper got jammed. I pulled it out but I think a piece was left inside the printer. Error message was blinking, but somehow I got the printer moving again. I tried to print again, but this time the printer would take 1/10 of the whole page and stop, even though rollers were moving. My solution for this was to take a piece of thin cardbore(I used a magazine cover), cut it in a shape of A4, put it in printer, printed it and when the rollers start moving I forcebly pushed the cardboard through. Now it seems to work fine.
Posted on Feb 28, 2008
SOURCE: i80 black cartidge not printing
get a q-tip and wet one end in water.  run wet q-tip along head a few times.  then take dry end and run along head again to dry it.  then run wet end again on the absorber side of head.  then dry with dry end.  replace parts, do a deep cleaning, and try a test print.
Posted on Jun 14, 2008
SOURCE: Canon MP600 paper wont feed- error message- HELP!
Right ... After 5 minutes of looking and fiddling I have found the solution!! press the button abover HOME and it should change the tray in which you are printing from :D
Problem solved
Posted on Feb 08, 2009
SOURCE: How do I remove a Canon 730 Multipass print head
Press the button on the right hand side of the printer. Lift the lid, pull up the little gray handle. Rock the print head container a bit and you'll see a little metal bar. Grab that and pull straight up.
Posted on Jun 13, 2009
pineworks
  • 4041 Answers
SOURCE: I have a Canon i9900 not even a year old and I
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 01, 2010
When i turn on/off my printer,Paper Feed Roller automatically push the plain paper(A4)
hi . you should check the mechanism. there is a solenoid responsible for picking the paper up. clean the metal plate of the solenoid. it should be sticky and that cause that problem. good luck
Mar 15, 2016 | Canon PIXMA Office Equipment & Supplies
Morning, Im working with a Canon All-In-One Inkjet MX300 printer. It is not allowing me to print as it keeps telling me I do not have paper loaded in the printer. I have turned it off, and back on. Even...
Hi....hard time with your Canon... It possible you have a paper jam inside you unit.. at the back you will see a endle in both side take off the tray and look for paper jam., also check where you feed the paper if you don't have anything like paper clip pencil jam it inside the feeder
Oct 16, 2010 | Canon MX300 Office All-In-One Printer
Canon i80 has a 64 'colour cartridge missing' - and it's not. It's there, it's new. How to reset? thanks
here is some reset procedure for canon i80 printer
1. Turn off the printer.
2. Press and hold down the Resume/Cancel button
3. Press and hold down the Power button.
4. While holding down Power button, release the Resume/Cancel button.
5. While still holding the Power button, press 3 times the Resume/Cancel button.
6. Release the Power button
(printer will initialize, LED blinks in green)
7. When the Led steadily lights in green, press the Resume/Cancel button 4 times.
8. Press the Power button and wait until the printer initialize again and return to menu selection.
9. Turn off the printer and then turn on again and print a test page.
I hope that is what you needed.
Please comeback and do rate this solution.
Thanks for using Fixya.
Aug 25, 2010 | Canon i80 InkJet Printer
Sounds/looks like it's printing but paper comes out clean - there's lots of ink and I've changed the ink levels
Hi, have you checked to make sure you removed the sticky tape cover from the end of the cart?
Sounds silly I know but I have done this before & it's easy to forget when your in a hurry :-)
Cheers
Sham
Jun 01, 2009 | Canon Bubble Jet i80 InkJet Printer
Printer will not work because of paper jam eror
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
607
Jan 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon i80 error 5100
Hi antoinette,
Someone has ever asked this problem and I have post a solution for this. Here is my answer:
Service error 5100 indicates that carriage return (CR) operation is not performed successfully. After the printer turned on, printer initialize some operation include CR operation. This error happens when carriage part (carriage unit) has problem when move right and left in initialization process.
This may be caused by:
* Faulty carriage part so thatit cannot read film encoder properly. As a result, carriagepart move on uncontrolled.
* Dirty film timing **** strip (Horizontal film encoder;available only ini series and above) so carriage part cannot read film encoder properly.
* Another material (such as broken paper, etc) present in carriage path, blocking carriage part from moving.
To fix this problem you may try the following tips:
* Check if any material present in carriage path; remove (clear) it
* Check if film encoder is dirty; wipe slightly with moistened clothe.
* At last, if carriage part is faulty you need to replace it.
Hope this will be helpful for you. Best regards,
Source:
Inkjet Printer Forum
Dec 18, 2008 | Canon i80 InkJet Printer
My Canon i80 will not feed paper for printing into the printer.
hmm..did you check under the feed tray and inside for paper obstructions?
Aug 19, 2008 | Office Equipment & Supplies
Canon ip90 printer wont grab paper
The most likely culprit is that the rollers that pull the paper are dirty. Use the steps below to clean the rollers.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
1) Confirm that the printer is powered on.
2) Remove any paper from the printer.
3) Press and hold the <Resume/Cancel> button.
4) Release the <Resume/Cancel> button after the Power lamp blinks three times.
Note: The Power lamp will blink and the paper feed roller starts cleaning itself by revolving.
5) When the Power lamp lights in green, repeat Steps 3 and 4 up to two additional times. (Please wait approx. 30 seconds for paper feed roller cleaning to complete.)
6) To confirm whether cleaning has been performed properly, set a blank sheet of plain paper (8 1/2 x 11 Letter size) in the sheet feeder or cassette.
7) Press and hold the <Resume/Cancel> button and release it when the Power lamp blinks three times. (The paper set in the printer is picked up and fed.)
8) Repeat the process as necessary
May 12, 2008 | Canon PIXMA iP90 Mobile Printer
I80 black cartidge not printing
Apr 27, 2008 | Canon i80 InkJet Printer
I80 paper jam
CHECK IF THERS SOMETHING UNDER THE INK TANKS
Feb 27, 2008 | Canon i80 InkJet Printer
Canon i80 InkJet Printer Logo
276 people viewed this question
old marine
old marine
