Question about HP Compaq 6910p Notebook PC PC Notebook
My laptop top will not turn on its getting no power to turn on i plug the laptop in the charger works but the laptop will turn in
  • 72 Answers
I think u must get the battery checked .........
Posted on Sep 16, 2010
Why wont my Gateway NV53A36u turn on ?
if your charger is ok then it will be a problem with the dc jack (where your charger plugs in to) or your actual motherboard.
Jul 29, 2012 | Acer Gateway NV53A36u
Targus Charger Problems
It looks like there is a shorting taking place whenever you insert the power jack into the laptop. Most likely the shorting is taking place on the laptop side and requires replacement, which should be done at the manufacturers service station even if its warranty has expired.
Dec 02, 2011 | Targus Computers & Internet
My NV52 lap top computer shut down on me the other night and now i can't get it to power on. The charger works fine but when i plug it into the computer the light for the charger turns off.
remove the battery and try to power on the computer using just the charger. if you can try to use a different charger. if the charger light still goes off when plugging it in your computer then it might mean that there is a short in your motherboard. you can try removing the peripherals (i.e. memory, harddrive, DVD or CD drive, wireless card, battery or modem) to check if it is one of the peripherals causing the short. if you have removed all the peripherals and the system still doesnt turn on or if the power light on the charger still turns off and you have tried the charger on a different computer then it would mean the motherboard is damaged.
Apr 01, 2011 | Gateway NV5215u Notebook
I have a HP Compaq CQ50-130us notebook. Yesterday I had it on and it just turned itself off after that I tried turning it back on the power button lights up and the cd drive you can hear turn on. But it...
hi aliyoow, i am happy to assist you, Step - 1 did you check whether your laptop is working without battery , just take your battery out and plug your charger in DC jack and check whether your laptop is getting on or not. If it get on mean you have problem with battery.
Step 2 - Use some-other charger of your friends laptop which is same averatec laptop and check whether your laptop getting charge or not. if your laptop get charge mean you have problem with your charger. if you change it , i will start to work again.
Step 3 - take you charger put in some-other laptop find-out it charging that particular laptop or not, if it get charge mean your charger was is good condition you have problem with your DC jack.
Step 4- take your charger put in DC jack on your laptop switch on power and try to move it side wise softly right and left and top and bottom check whether your charger light glow in your laptop , if it get glow at any point mean you have problem with your DC jack so try to change it so that you can able to bring back your laptop normal working mode.
If you have warranty on the laptop you can directly go to showroom and change it , they will help you without cost. if you don't have warranty just check the steps i have mentioned.
Good luck ! if you think your problem solved don't forget to rate
Jan 02, 2011 | Computers & Internet
When i plug the charger in the first time it is working but when the charger is unplug the laptop is not working.
Hi Tim, As per my understanding you are experiencing issues with the laptop not working without a charger being plugged in.In this regards what I would suggest you do is see if the battery charges with the charger plugged in and in case the battery does get charged see if you are able to power on the laptop with just the battery connected and no charger plugged in.If you are able to get the laptop to turn on only with the charger connected and unable to power on with just the battery then it would be an issue with the battery not getting charge.So before you replace the battery please unplug all external devices from the laptop including the charger and the battery and without the charger or battery connected to the laptop please press and hold down the power button for 30 seconds after which please insert the battery into the laptop and see if you are able to turn on the laptop.This step is performed so that we could drain out unwanted static electric charges from the laptop.In case this step does not work please do consider replacing the battery since it would be an issue with the battery not getting charged. Best wishes for your effort.
Nov 12, 2010 | ASUS A9RP Notebook
Charger was plugged in and working fine, went into
OK unplug power supply from back of laptop, remove battery, insert power supply, if NO light, on laptop, power supply is broken..Replace. IF it is OK, hold power button ON for a while, or until, the PC starts, if/when it starts, shutdown, with power ON key, and then take out power supply, replace battery, replace power supply, turn laptop on, now should be OK.
Mar 01, 2010 | Toshiba Satellite A70-S249 Notebook
My lap top just died there is no power to it even if I plug it in to an outlet. Could you please suggest a soloution.
hello,
the charger might be the problem, try it on another similar laptop, if it works it surely is not the charger,
then that means the port the charger gets plugged on the laptop is faulty.
carefully unscrew the laptop, pull off the charging port gently and carefully replace with another port. screw back the laptop together and try to turn it on.
Jan 02, 2010 | HP Pavilion dv1000 Notebook
I have an acer 5920 laptop will not turn on. when i plug the charger into the wall socket the charger has a constant green light. when i plug the charger into the computer the green light flashes the...
sounds like the power jack at back of computer has gone bad, check voltage of battery and see if it has good power if not then it is dead and not getting charged through port the jack at rear generally requires MB replacement and is very expensive and cheaper to get new laptop, u can remove HD from old lap top and copy data over. another choice is to get stand alone charger for laptop battery and use battery mode,
if battery tested good them there is slight chance power switch is bad
Jul 07, 2009 | Computers & Internet
Dell Inspiron 6400 charger not always working
u r very correect its the time for new 1 to be bought. u can get the new 1 from radio shack websites. and also dont try to use that faulty charger again as it can possibly blow the laptop electrical parts internally due to any over power short circuit.
Jan 04, 2009 | Dell Inspiron 6400 Notebook
HP Compaq 6910p Notebook PC PC Notebook Logo
107 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
