Question about Dishwashers
BEKO DE 2431 FW - fails to start
My machine is just 5 months old and I am having intermittent problems when starting the machine. Although the power light is on the 'Wash' light fails to come on hence the programme fails to to start. Only by turning the slector knob to 1 and returning to 3 (my preferred programme) and pressing the Start/Stop button again will the machine operate. I have checked the salt and rinse aid levels and also that the upper basket is properly located in the machine (i.e. back as far as it will go). Since 24/4/08 there have been 7 occasions when this has occurred.
  • 3 Answers
Dear LizzyL,
If your machine is only 5 months old it is still in warranty and you should go back to the shop you purchased it from and get them to send in a Service Engineer. It is not fit for purpose.
Posted on May 17, 2008
My beko washer is only six months old its washed all day. On last load it has started to make a loud metalic noise while emptying and spin its like something is stuck but filter empty
Is it out of warranty?? It sounds like the washer drum bearing failed. Do you use approved super low suds detergent? You can not use regular detergent it will corrode the drum bearing.
Jun 01, 2016 | Beko Washing Machines
Beko washing machine WMG11464W. It wont drain. No blockage in filter or waste pipes. How do i reset it please in case its the pump. Its only 3 months old. Please help. Thank yoj
At 3 months old it will still be covered by the manufacturers warranty so you would be better off contacting them. If you tamper with anything, they will claim you have voided the warranty.....been there, done that.
Modern machines are all controlled by a circuit board and they do fail on a fairly regular basis and my guess is this is the problem.
I would lay money on the engineer replacing the board, a 5 minute job and the problem solved.
I can't emphasise enough, do not touch it and do call them out.
Sep 17, 2015 | Beko Washing Machines
I have a beko de 2762 fw dishwasher when i press start 3 out of the 4 lights come on and the moter continually runs.
It sounds like you have a leak. You need to take the dw out and lean in back untill the water will run outside.
Dec 16, 2013 | Dishwashers
What are the serial numbers of the faulty Beko fridge freezers that is a on going problem with the defrost timers.
CA 5411 FFS/FFW/FFX
CA 7014 FFX
CA 7015 FFW/FFS/FFX
CDA 539 FS/FW/FX
CDA 543 FS/FW/FX
CDA 645 FW
CDA 647 FS/FW
CDA 648 FS/FW
CDA 653 FS/FW/FX
CDA 659 FS
CDA 751 FS/FX
CDA 752 FS/FW/FX
CS 460 FF/FFS/FFW/FFSD
CS 461 FFW/FFS
CSA 4706 FFX
CSB 4606 FFSD/FFS/FFW
Hope this helps.
Jul 08, 2011 | Beko Refrigerators
Apparently there is a problem with Beko refrigeration manufactured between 2000/2006. Please confirm model number in question.
From Beko:-
"The BEKO frost free fridge freezer models affected were manufactured between January 2000 and October 2006. These have a serial number that begins with either 00, 01, 02, 03, 04, 05 or 06. and this information can be found on a label inside the fridge. Beko is making a free of charge modification to all affected models, this modification takes approximately 30mins.
Other Beko branded models and all Beko frost free fridge freezers manufactured after this date are unaffected.
Affected model numbers:
    • CA 5411 FFS/FFW/FFX
    • CA 7014 FFX
    • CA 7015 FFW/FFS/FFX
    • CDA 539 FS/FW/FX
    • CDA 543 FS/FW/FX
    • CDA 645 FW
    • CDA 647 FS/FW
    • CDA 648 FS/FW
    • CDA 653 FS/FW/FX
    • CDA 659 FS
    • CDA 751 FS/FX
    • CDA 752 FS/FW/FX
    • CS 460 FF/FFS/FFW/FFSD
    • CS 461 FFW/FFS
    • CSA 4706 FFX
    • CSB 4606 FFSD/FFS/FFW"
If you find that your model is listed above and is in the correct model year range then you need to click here for further guidance. There is also a freephone number, but it's swamped by callers. Even if you get through you will receive exactly the same advice as you would from the website links.
If you want to know more about what the actual problem is, then click here.
Please take a moment to rate my answer.
Jul 06, 2011 | Washing Machines
Hi, iv'e lost my manual for beco dryer
Try Googling (beko)(model)(manual) without parens.
Jul 19, 2017 | Dryers
Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
Apr 11, 2009 | Washing Machines
Beko DE 2431 FW dishwasher
hi there.....when the machine brings water in...have you cancelled the program reselect a program and checked that it is puming out..if all is ok then you need to check that the main wash pump rotates freely....if all is ok here..then i suspect you have a failed capicator on the wash motor....little white cylinderical component on top of the motor
regards Sir Galahad
Jan 20, 2009 | Beko 24 in. D3421F Free-standing...
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Turn power button off (not at wall)
Select 90 degree wash
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
Apr 26, 2008 | Washing Machines
Dishwashers Logo
439 people viewed this question
Top Dishwashers Experts
