Question about Microwave Ovens
Microwave gets very hot on outside and top.it`s a new appliance used twice.It has good clearance. gets hot after 6 minuites.Is that normal.
  • nl28 Jul 10, 2008
    my microwave is about 2 years old and I just noticed today that it was quite hot on top I am not sure how long it has been like that.
    Problem Solver:
  • 17 Answers
If it gets hot enough were it is uncoftable to lay your hand on it then there is most likely a problem. If it is a new unit I beleive I would return it. Good luck.
Posted on May 17, 2008
Why is the outside panel hot to the touch?
Many factors at play here. Are you cooking on the range? Are you using the microwave? Is the light on?
There is very little current going to the touchpad and if there were a short in it the touch pad would not work. It is just heat from another source. Don't worry about it.
Dec 13, 2014 | Maytag Appliances Over-the-Range Microwave...
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. It is only 6 months...
Small component called a diode. Open up the microwave and try to find a black (usually) component that is most often connected between the magnetron (the thing that heats the food) and the chassis of the microwave oven (ground). I used to make a fortune replacing these! Costs about 5 bucks most appliance supply stores. Make darn sure you get one of the same value.
Apr 06, 2010 | Maytag MMC5000 Microwave Oven
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Mico only heats 4 to 6 minutes
many microwaves require x amount of clearance for exhaust heat, is it installed with the proper clearances?
it is one, not venting and tripping the overtemp,
two, the overtemp module is bad, or the board receiving the signal is bad
Nov 12, 2008 | Microwave Ovens
Microwave not cooking
I would say you have a bad door switch or door switch mount, or your door is loose or out of alignment.
But since it's new, and under warranty, I would contact Goldstar (LG) customer service to have them repair it free.
Contact LG at 1-800-243-0000 or http://us.lgservice.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 28, 2008 | Microwave Ovens
Panasonic Microwave NN-A770S getting hot on right side externally
If you described this to Panasonic very carefully, and they said it's normal, then I would say keep using it until such time that you get other symptoms. The inverter has some parts mounted on a large chunk of aluminum called a heat sink. It draws the heat out of the parts and the heat radiates and/or convects away. This keeps the circuit parts from overheating. As long as you have good air flow through the vents, it sounds okay.
Sep 13, 2007 | Microwave Ovens
Non-Stick surface peeling off inside microwave.
Normally you can strip and sand the old paint, get it squeaky clean, and use appliance paint. Yes indeed it is a heat-resistant enamel. You can get it from appliance parts stores, Wal-Mart, or home centers, etc. BUT if it's under warranty I would call GE Customer Relations with your model and serial numbers. They're at 1-800-386-1215 (8-6 ET) and I would also suggest you ask them for a referral to a GE-authorized servide center in your area. Good luck. I appreciate your thoughtful rating of this answer.
Jan 29, 2007 | GE JES1231 Microwave Oven
Microwave Ovens Logo
1,532 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
