I have a acer aspier 3515-2153 laptop.It wont go to the user screen.it will turn on say configuring updates then it shuts off agin.How do i fix it i cant afford another computer pleasehelp!!!
  • Jennifer DeLaCruz
    Jennifer DeLaCruz Sep 16, 2010
    What operating system are you running? XP, Vista, 7?
  • 137 Answers
HI Steel,
For this you dont need to buy another computer.
Follow the steps.
1. Try safe boot, F8 key @ BIOS screen just after you turn on the system. Choose safe boot from menu.
2. In safeboot.
Go to control pannel and choose option Show windows updates. else they may also be visible by default.
3. Minimise the window.
4. after you find the system is turned up completely.
close the opened window without touching anything.
5. give the system a complete shutdown.
6. reboot.
7. System may say " System has recovered after a serious error"
Still if it does not works.
1.insert the OS disk.
2. choose to follow wizard seriously reading each step.
3. It will ask you ro repair your OS.
Choose this option.
4. let the system recover (The process is slow; may take 30 mins or more)
Rate this solution, Write a comment to keep in touch, let me know how it worked the first way or the other.
WisBee
Posted on Sep 16, 2010
Can't logon to my acer laptop it says the following, the user profile service failed the logon user profile cannot be loaded
Shut down your computer. To do a hard shutdown hold the power button down until it turns off. You probably need it to go to last known good configuration. To to this 1. find the F8 key (keep finger on it(not pushed yet). 2. Turn Power button on and immediately start tapping F8 key. This will take you to a screen with many options; Last Known Good Configuration is one of them. It should start up. Hope this helps.
Apr 27, 2013 | Acer Computers & Internet
When I turn on my computer the screen reads configuring updates: Stage 3 of 3 0% complete. Do not turn off your computer. Then it goes to shutting down. It starts up with acer, microsoft corporation the...
downloads are either being stopped by a firewall or your system cannot update what it needs to because your missing other updates. if you dont have all required updates some others will not install.try automatic updates.download all critical and recommended updates.
Oct 05, 2009 | Acer Aspire 9410 Notebook
Acer5920 stuck in configuring updates.
This is generally caused by bad blocks in the Master Boot Record(Table). The drive itself is probably not salvagable. You'll need a reputable reapir person to slave your drive to another system to get the data off.
Good Luck
Mar 21, 2009 | Acer Aspire 5920-6727 Notebook
Stuck on the updating screen
Reboot your computer and when the message appears at the desktop that there are updates available, click on the link to see what updates are available. Make sure any third-party antivirus and firewalls are disabled. Uncheck any that are "Optional" unless you really think your system needs them. Try installing those that are critical/important first, and leave the rest for afterwards.
Feb 24, 2009 | Acer Aspire 5500 5570-2609 Laptop
Screen problems/overheating problems
If it's an overheating problem, updates won't help, cooling will. With the unit turned off, blow out all vents & screens on the bottom, sides & back of the unit. Get a cooling unit to put under the laptop. Mine dropped the temperature about 30 degrees and it hasn't shut off since I started using it.
If it's not from overheating, the way you have Vista setup to view different users windows should be changed.
Jan 04, 2009 | Acer Aspire 5100 Notebook
Cannot start up my laptop since in done an update
Try booting into "Last known good configuration" it is on the same screen as Safe Mode, if that does not work, you can try to run CHKDSK /r from the windows install CD, just choose "Repair" in the option, if this does not work I suggest removing that hard drive and slaving it into another computer to get your data off and then reload Windows onto it. It is missing a .dll
Nov 28, 2008 | Acer Aspire 1642WLMi Notebook
How get for Internal from Acer Aspier SH85-524B8
try www.global acer.com/support/downloads.htm they have acer computer software and utilities there
Oct 26, 2008 | Computers & Internet
I have an acer aspire laptop, when i start it up its says configuring updates stage 3 of 3 0% complete then it will shut down come back on say the same again and shut down again. it will keep on doing this
Maybe you could try the last known good configuration. When the laptop is starting up, wait until the acer screen disappears and then tap F8 on the keyboard before the windows screen comes up. You should get a black screen with some options that say safe mode. The fourth or so option on the list will be "Last Known Good Configuration". The computer should try and load windows. Hopefully that will restore the machine before the update.
If it works it would be a good idea to go to http://windowsupdate.microsoft.com/ and fully update your laptop. This will download the update manually instead of doing it with automatic updates.
Oct 14, 2008 | Computers & Internet
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
