Question about GE Refrigerators
The refrigerator keeps blowing the main electric to the whole house
    Genius:
  • 1,044 Answers
Case Short Circuit in the machine. Please check the power cord, the plug and the connection at the end. Check for any loose/broken wire connections. Also Are you getting any burning smell near the machine when the fuse blows up, If so then wiring in the compressor is short circuited. You have to call a technician as you may not be having tools to check the short circuit.
Posted on Sep 16, 2010
Won't turn on. Power went out to the whole house when roof was being replaced. Tell me where reset button is
What won't turn on? If the entire house lost electricity, that means that either the main electric line was severed or the main breaker in your panel was tripped. I suspect the latter. Go to your main electrical panel, open the door and look at the top of the panel. There should be one large breaker marked either 100 125 150 or 200 A. This is your main breaker. Turn it off and turn it on.
If you don't know where your electrical panel is, go outside and look to see where the electric wire comes from the pole to your house. There will be a meter pan here with a glass housing on it. Your panel is almost always directly opposite of that meter inside your house so figure out what room that aligns with and that's where your panel is. I hope this helps.
Jan 04, 2016 | Home
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
Why does My dm2852 works on electric, but not gas. It lights (small flame), but doesn't cool.
It is more than likely just a dirty orfice. It can be cleaned quite easily by soaking it in rubbing alcohol then blowing it out. Do NOT POKE ANYTHING THROUGH IT! 946177a3-e85b-4832-879e-b23434d529ef.jpg ArctiCold Refrigeration We keep it cold
Jul 22, 2014 | Dometic DM2852 Americana Fridge...
Electrolux EOB 6632 oven trips main house circuit breaker if used above 180c. Installation electrician has done whole house test, says everything normal, must just be a particularly sensitive ciecuit...
Hi, welcome to FixYa! my name is Shaun. I hope i can help you out with your question. Your main house breaker is tripping over 180C because of the amount of current your oven is drawing. Keep in mind that an oven is capable of pulling up to 1/4 the amount of amperage of your total house current capacity, up to 50 Amps. This is assuming you have a typical 200 Amp main breaker. Add this in with your heating/air-conditioning, up to 30A, if electric, your water heater, 25 A if electric, and whatever lights and appliances you have plugged in and turned on, you can imagine how quickly those amps add up when your oven is on. Your oven breaker won't trip because you're not exceeding 50A on that circuit, however if your total household load is exceeding 200A, your main will trip. Also, breakers lose efficiency over time. Sometimes they can drop current capacity by as much as 25%. So your best bet is to replace your house main and see if that fixes your problem. Hope this helps out. Have a good day!
May 05, 2011 | Electrolux EOB6632 Electric Single Oven
Compressor keeps turning on and off, I can hear it and it dims the lights showing an increase in power draw, it will blow the main circuit breaker to the house. Therefore it does not run enough to remove...
If when it's running it dims the lights in the room or entire house, The circuit breaker for the receptacle it's plugged into, is not a high enough amperage to carry the dehumidifier and whatever other electrical appliances that are on the same circuit. OR if your house is hold enough (1970's era), it may have aluminum wiring and its overheating .
If it's blowing the Main Circuit Breaker for the entire house and not just the circuit breaker for the receptacle it's plugged into, Stop using the dehumidifier immediately!!! Have an certified electrician check your home's circuit breaker panel and wiring. This could be a dangerous situation.
Mar 01, 2011 | Maytag M3DH30B2A Dehumidifier
Fridge keeps blowing the breaker
Depending on what is causing the breaker to blow will be important to know. Refrigerators do draw a good bit of power on a 20 amp circuit especially when the refrigerator goes into defrost. Refrigerators are made to run on a 20 amp circuit without other machines or appliances using the same power circuit. Circuit breakers weaken over time too especially if they have more than they are. rated for plugged into the same circuit. And your circuit may be doing its job by detecting an excessive draw of power when the refrigerator is plugged in. You must have someone that knows electricity to inspect your refrigerator for shorting and the circuit it is plugged to for correct wiring for every ones safety. Thanks, Sea Breeze
Apr 25, 2010 | Fisher and Paykel RF201ADUX Bottom Freezer...
Our miele condenser dryer with the miele washing machine will often trip the whole house's electricity. Sometimes it will trip on the house circuit board. while other times it trips the external trip...
have the neutral power connection on that circuit and back to the main house panel and then have the neutral connection checked at the power companies side also, it sounds like you have a high resistance neutral connection somewhere in the circuit and its looking for another return path due to the high resistance on the line to another feed circuit line to make connection
Dec 07, 2009 | Miele Novotronic T220 Electric Dryer
Brunt smell and sweating
Seems like your blower motor is burning up. Its the motor that blows cool air across the refrigeration coil. If it is a whole house ac unit, probably your main blower motor for the furnace. If you are getting sweat, that means the compressor is compressing the refrigerant, and you should not smell anything from the outdoor unit, only from the furnace. Hope this helps.
Jun 04, 2009 | Goodman CKL24AR24 Air Conditioner
Zanussi frostfre fridgefreezer r600a
if a frost free type and happens only now and again, suspect defrost element short to earth
Mar 20, 2007 | Zanussi ZEBF277W Bottom Freezer...
Refrigerators Logo
246 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
