Question about Sansui VRDVD4005 DVD Player/VCR
NETFLIX DVD will not play ...
Because Netflix says the dvd has a block and I should be able to get like a dvd for my SANSUI dual player (VHS/CD combo) to fix this problem...is this true? Thank you - Dee
    Genius:
  • 1,224 Answers
Sounds like a region code block on your dvd player this is a risk unlocking region codes for player search internet explore region code for your model follow directions this is a use at own risk code
your dvd is region coded and your dvd player combo is region coded which code i dont know if live in united states the code for this region is one
Posted on May 17, 2008
My mom has Netflix setup so we can have it on one other tv without a blueray player or anything. I have a starplus satellite box and a toshiba 22lv610c tv with the built in dvd player. How do i set up the...
Netflix has to be an app or your need the CD/DVD from Netflix. If you go to the netflix website they list all the devices their service will work on.
Sep 08, 2014 | Televison & Video
DVD player will play store bought dvd's but will say unknown disc when I insert one from Netflix.
Is it possible that this is a Blu-Ray disc from Netflix? If so, It may not be able to be read on a standard DVD player.
Another possible reason for this is that the disc is somehow damaged and thus unreadable.
I'm afraid without seeing the disc I am unable to help you further.
Either way, might be time to complain to Netflix:
Netflix Customer Service(800) 279-5688(888) 638-3549(800) 585-8131
Sep 06, 2012 | Zenith XBV243 DVD Player/VCR
I have tried to play 2 dvd's from netflix. I have used this player for 6 months and not had a proble. Both dvd's didnt play and disk error message appaered
Double check that you don't have BluRay disks that you are trying to play in a standard DVD. Or that they are upside down...
Netflix disks, in my experience, have all had scratches and gouges on them. It might be that you are the recipient of 2 disks in a row from netflix that are too damaged for your DVD to play.
Jun 11, 2010 | Televison & Video
I have a sansui combo VRDVD4005 I need instructions on how to copy my VHS tapes to DVD format.
I believe it's available on a Sears sponsered website called managemylife.com. I hope this helps you. Look under "Dubbing".
Apr 11, 2010 | Sansui VRDVD4005 DVD Player/VCR
Netflix dvd not playable on SamsungDVD/VHS
Buy a cheap DVD player under $50 they play anthing.I have a $600 Toshiba Tivo DVR that won't play some DVD s.My $32 RCA plays anything.Good Luck.
Sep 07, 2009 | Televison & Video
Only dvd plays properly but vhs will not show picture.
Most likely you have the dvd part connected through component or svideo cables. Despite the fact that this is one unit, like other vcr/dvd combo units it acts as two separate units in the same box. The vcr will probably not play through those cables. As you have audio coming through I'd imagine that the audio is connected using red and white composite cable. Connect the video on the vcr side with composite yellow cable or run direct to tv with a coaxial cable.
Feb 04, 2009 | Sansui VRDVD4005 DVD Player/VCR
HOW DO I RECORD A DVD TO A VHS ON A VHS DVD COMBO BY PHILIPS
Cannot do this on a combo unit. There is a chip that senses copy protection and prevents recording a copy-protected DVD to a VHS and vice-versa. Solution: Use an outboard DVD player or an outboard VHS VCR and try the recording with the video routed through a "stabilizer" box. The stabilizer (about $30 or less on Ebay) defeats the copy protection on MOST DVDs, but not all. It works with Netflix DVDs. Route the audio as usual. Audio is not protected.
Dec 15, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Sansui DVD Vcr combo wont play Dvd's model no. VrdVD4005
you will need to run a cleaning disk in it , if that won't work then it will have to be taken apart to clean the laser eye manually
which then if you can't do this then you will need to take it to a local repair shop where they can do it
electech
Oct 26, 2008 | Sansui VRDVD4005 DVD Player/VCR
I have a SANSUI DVD/VCR Combo,and cannot record from VCR to dvd.Itcomesup with disc error. Can you help?
1.- Check the type of DVD that the recorder accepts, usually id DVD-R (minus R).
2.- Make shure is a DVD recorder.
3.- Internally, the DVD combo comes with a software that don't alow to copy VHS original movies, is a kind of codification that is with the information content in each movie.
Sep 20, 2008 | Sansui Televison & Video
Sansui VRDVD4005 DVD Player/VCR Logo
218 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
