Question about IBM Office Equipment & Supplies
I have an ibm personal wheelwriter. When typing on the right hand side of a page, the bottom part of the letter is not being typed. When typing on the left hand side, everything is OK.
  • IBM Master
  • 3,594 Answers
The platen is not fully seated in the side frame. Press down firmly on the platen it should pop into place. Occasionally the black latches crack and the platen needs to be replaced.
DickyO
Posted on Sep 16, 2010
IBM Wheelwriter 2, the bottom half of the letters are not printing. It is not the ribbon because I have changed it out.
Two things come to mind for this problem. First try pushing down firmly on both ends of the black rubber platen roller. Sometimes the black plastic latch on either side may break causing one side of the roller to lift up causing partial print. The other possibility is the ribbon is not lifting correctly. A technician can adjust the ribbon lift. After typing a few letters, take the ribbon out and look at the letters on the ribbon.Are they in the middle of the ribbon or are they at the top or bottom of the ribbon? middle of ribbon is correct.
Mar 01, 2016 | IBM Lexmark Personal Wheelwriter 2...
What causes the problem when the letter l is typed and it will not space on an IBM Wheelwrite 6
You language button is activated, depress code and hold it down then press the lang button. Usually is the L button.
Jan 21, 2016 | IBM Wheelwriter 6 Typewriter
IBM Wheelwriter 3 - Cannot get the complete word - Middle part of word is white
Type on a two part form if the carbons are goog then you have a ribbon problem. Look at the ribbon. Do the letters overlap (ribbon feed) If they don't fall in a line near the center of the ribbon (ribbon lift) Check for folds in the ribbon.
DickyO
Oct 04, 2012 | IBM Wheelwriter 30 Typewriter
My IBM Wheelwriter does not type the letters until I hit the carriage return. How can I correst this?
I have made a copy of the IBM Wheelwriter manual for you. If you send me an email to LBrown18062@hotmail please be sure to put IBM Wheelwriter as the subject and I will send it to you right away. Lawrence Brown
Nov 22, 2011 | IBM Wheelwriter 6 Typewriter
Hi, I have an IBM Wheelwriter 30 Series II. When I type text it does not type the bottom 20 % of letters. I changed the ribbon and made sure that the roller was securely locked down. Any suggestions? ...
yes in the carrier ribbon there is a adjustment of ribbon to fix it up and down.
take out the ribbon.
see the cam from where the ribbon carrige lift up.
in side that cam a adjustable screw from that screw you can adjust the ribbon hight.
Nov 25, 2010 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6-Letters striking paper above
Put in a multi part form and type if the carbons come out OK the the ribbon isn't lifting, Wiggle the big black gear on the R. side of the carrier back and forth. They do get tooth for tooth when they get old. If the print on the copies id bad or not there you need a print solenoid cap. We sell them for 20,00 including instructiond and shipping.
DickyO
Cleveland Business Machines
216-241-0027
Feb 18, 2010 | IBM Office Equipment & Supplies
We have a IBM Wheelwriter 5. Need to use
Correction is pretty simple type a letter, press the correction key and it should lift the wrong letter off.
DickyO
Sep 30, 2009 | IBM Wheelwriter 30 Typewriter
49 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
