Question about Miele Novotronic T1520 Electric Dryer
How do I change the drum belt on Miele T490 tumble drier?
  • 883 Answers
SOURCE: changing drive belt
ensure that the tensioner pulley wheel is also part of the belt loop and that it is properly sprung to take up slack. sometimes, this pulley looks good mounted in reverse, giving no tension to belt. try it the other way, against the spring force.
Posted on Sep 24, 2007
  • 1314 Answers
SOURCE: tumble dryer
pull the front off then put the belt around the drum then pull the idler pulley back to put tension on it and put the belt around the motor pulley let the idler pulley back against the belt to keep it tight replace the front and your done
Posted on Mar 12, 2008
captaynkyrk
  • 170 Answers
SOURCE: Drive belt replacement on a Miele T230C tumble dryer
You must route the belt either in front of or slip it behind the drum to get it down to the drive wheel. You should remove the front panel to be able to do this the best.
Posted on Jul 06, 2008
  • 417 Answers
SOURCE: Zanussi Tumble dryer belt replacement
Yes, that sounds about right.
Posted on Oct 11, 2008
  • 67 Answers
SOURCE: Hotpoint tumble drier TDL52S
you dont need to take the back off. to get inside, first remove the panel on the bottom of the front, that will allow you to remove the front panel and you will be able to get inside the dryer. as far as stretching the belt, i have never heard of that. there is a belt tensioner that holds the belt tight though. good luck!
Posted on Oct 28, 2008
How do I replace the belt on my hotpoint futura tumble dryer?
I can't answer your question exactly but in my experience tumble drier belts are not particularly complicated to replace but the process is fairly time-consuming and involved as in order to slip the new belt over the drum an almost complete strip-down of the cabinet is needed.
It is a route-march of removing screws and plastic trim until something important falls off. The task then becomes rather more a thorough interior clean and a changing of felt bearings than merely replacing the belt. The belts last so long that by the time they need replacing the other things are also ready for attention.
Apr 29, 2016 | Hotpoint Dryers
Im trying to replace the drum belt on a Miele t7734 tumble dryer, but cant seem to get around the front or back of the drum to get the belt around it. Am I supposed to dismantle the whole machine to do...
Some dryers disassemble from the front, making it possible to slip the replacement belt over the drum and connect it to the tension idler and the motor pulley.
Dec 20, 2014 | Miele Dryers
Why is my Tumble Drier keeps beeping without stopping a few minutes into the drying program?
It sounds like the carbon brushes are probably worn down - they ride on the drum (in the top ) and determine the amount of moisture left in the clothes for drying - they connect to the drum and the metal bar inside the dryer - A wet clothing item conducts between the two giving the dryer an idea of how much moisture is left in the load - equal to how much time / heat is needed to dry load as required. These brushes wear out and need to be replaced over time
Aug 03, 2014 | Miele Washing Machines
Bosch Exxcel Condenser
replace the broken drive belt
May 13, 2013 | Dryers
My Miele T490 started vibrating like MAD when running. It's level and I cannot figure out what is causing this
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 04, 2010 | Dryers
How easy is it to replace the rear bearing on a Zanussi TC7102W Tumble Drier, do I take the whole drier apart to do it? Thank you
you first remove the top cover,then the front cover then the drum belt and drum come out the front,and the bearing can then be accessed
Oct 14, 2010 | Dryers
Drier does not tumble but it still heats.
Sound like the belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 05, 2010 | Asko T701 Electric Dryer
The drum on the tumble dryer isnot moving, why is this?
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 18, 2009 | Zanussi TC180W Electric Portable Dryer
Miele Novotronic T1520 Electric Dryer Logo
Top Miele Dryers Experts
Tim Whalen
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
