Question about Kenmore 22422 Top Load Washer
Washer will not agitate - Kenmore 22422 Top Load Washer
  • Kenmore Master
  • 17,130 Answers
Check the controller for voltage output to the motor. If present then check the motor for fault, either the winding is off or the main capacitor is faulty.
The program cycle must worrk if the controller is good and the inlet valve must open for water to flow, the water level sensor must work for the set level for the program to advance to starting the motor.
Check this sequence.
Posted on Sep 16, 2010
How to remove the agitator
Washer Agitator Repair Agitator Not Working ... - YouTube
? 7:51
www.youtube.com/watch?v=yxfDICZ0Ses
Apr 21, 2010 - Uploaded by applianceassistant Washer Agitator Repair Agitator Not Working Repair ... of a whirlpool built washer, manufactured under the appliance brandsMaytag, Amana, ... How To Repair Washing Machine Agitator -Remove And Replace Agitator Dogs ..
Sep 14, 2015 | Washing Machines
Hw to get fabric unstuck from bottom of agitator on a GE Gtwn2800Doww topload washer
Some agitators at the top have a plastic lid that has a bolt under it holding the agitator in washer. Take the bolt out and agitator should come out of washer.
Aug 20, 2013 | Maytag Atlantis MAV6000 Top Load Washer
How to take a whirlpool clothes washer agitator out of the washer to be replace
  • Pull the liquid softener dispenser off the top of the agitator. Pull the clear plastic cap out of the center of the agitator. Use a ratchet and socket set to remove the hex head bolt from the center of the agitator. Lift the top half of the agitator out of the washer. Pull the bottom half of the agitator straight up to remove it from the drive motor shaft, and remove the bottom half of the agitator from the Cabrio washer.
  • Mar 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Ge frontload washer seems like it is not aggitating... what would be the problem???
    Hello there:
    The first thing to check when your GE washer is not agitating, is the belt. Let me tell you how to check the belt & the clutch with out having to take the washer apart.
    The belt: Set the timer in the spin cycle and pull the timer knob to turn the washer on.
    If the washer drains the water and then spins the way that it should, this tells you that the motor, belt & clutch are not the reason why your washer won't agitate.
    A broken belt could be the reason your washer is not agitating or spinning.
    The agitator: After making sure that the belt, motor & clutch are working ok, lets check the agitator.
    The agitator uses a plastic agitator coupler that is couple to the transmission shaft by using splines cut in the coupler and on the transmission shaft.
    Too much usage or overloading the washer too many times will wear the agitator coupler splines. With out the splines the coupler could not be coupled to the transmission shaft and that could be the cause why your washer is not agitating.
    The clutch: A bad clutch could also be the reason the washer won't agitate or spin. Usually when the clutch is bad the washer will be noisy, like when you have bad brakes on your car.
    The transmission: The transmission could be the reason your washer is not agitating. A common problem with the transmission is oil leaking right on top of the motor pulley and the belt.
    As you can see, there could be different reasons why your GE washer is not agitating. You just need to keep checking each part until you find the problem and replace the part responsible.
    Oct 03, 2010 | GE WSXH208A Front Load Washer
    How to remove agitator from GE washer? Model WHDRR418G1WW.
    how to remove agitator from GE hydrowave washer machine?
    Feb 27, 2010 | GE WBSR3140DW Top Load Washer
    How to remove agitator cam from the upper part of the agitator?
    Had same problem with my washer. Check to see if there are little plastic tags holding top/bottom of agitator. after replacing dogs just ensure that you realign with tags so they do not break off.
    Oct 10, 2009 | Whirlpool LSN1000LW Top Load Washer
    Whirlpool washer agitates but makes a very loud noise
    It sounds like the agitator teeth, that are plastic, are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, and check the circular teeth inside, to see if they are worn out. These plastic teeth are the agitator part of the washer, where as the spinning part is a metal set of teeth, at the bottom of the agitator. You see the metal teeth, when you take the agitator completely out. You will have to replace the agitator if the teeth are worn out.
    Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    A wears out clutch might prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. Good luck!
    Feb 11, 2007 | Kenmore 15864/15862 Top Load Washer
    Kenmore 22422 Top Load Washer Logo
    113 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
