Question about Neon Light, CCFL COLD CATHODE LIGHT KIT 30CM/S/BLUE
Neon light only comes on for a second. What is the issue
  • 732 Answers
Investigate all soldering on printed circuit board and check for bad (swollen) electrolytic filter capacitors. May need large magnifying glass or low power(5x to 20x) inspection microscope to find hairline thin fractured thermally intermittant solder connections of electronic component leads to foil trace circuitry!! good luck with the hunt! 12fixlouie
Posted on Sep 16, 2010
My 2002 dodge neon is an automatic and shakes awful, what causes this? It also has an engine light that will not go off. The shaking is worse when the car's air is on, and when I come to a stop.
You have a check light on the dash
So I will ask --- why have you not have that issue
looked at
Those lights are part of the on-board-diagnostic-system
& have been on all vehicles for 30 years,so you surely
must have some knowledge & experience on what to do
Aug 26, 2011 | 2002 Dodge Neon
Hi, My name is Norma. I drive a 2005 Dodge Neon. The oil can light on the dash board keeps turning on... I drive for a few miles and on a stop sign or red light when I press the brakes that's when...
Is your oil level low? If your oil pressure is low as indicated by the light, you will do serious damage to your engine if you continue to drive without repairing the fault. The fault could run the gamut from a loose oil pickup, to a bda oil pump to bad bearings.
Jun 23, 2011 | 2005 Dodge Neon
I am having issues with my 2004 dodge neon missing at idle spped and low rpm. Is there a simple solution to look for. No check engine lights are coming on so I am unable to check any codes.
Be careful, when its running, slowly pull each spark plug wire up, if you see sparking coming out of the side of the spark plug boot, replace the wires and spark plugs. Use the correct Champion Spark Plugs.
May 24, 2010 | 2004 Dodge Neon
2004 Neon: The engine light came on and does not blink but wi...
Take the car to an auto parts place and have them run a scan on the car (PCM) powertrain control module. Auto zone does it for free, The pcm has a code set in it and by scanning it you can find out what is wrong,and then you can correct the problem. Hope this will help you.
May 17, 2010 | 2004 Dodge Neon
Need to reset engine light
Disconnecting the battery for at least 30 seconds, then reconnecting it, will reset the computer and the engine light. If the problem that caused the light to come on isn't corrected though, the light will come back on after a few miles of driving.
Bill B
Mar 15, 2010 | 2002 Dodge Neon
Dodge Neon 2005) Car will not start.
I was having the same exact problem with my 2005 neon as well. The guy at Discount auto suggested the starter itself was the problem(cost approx $200). The car isn't old enough to be having a starter issue so I figured it was something more simplilar. My dad took a look and founf out it was the starter relay. It is located in the black fuse/relay box on the driver's side right next to the battery. I had to get a new relay at the dealership(cost $20) and my car starts perfectly. Hope this helps
Jun 26, 2009 | 2005 Dodge Neon
How do I get the service engine light off on my 1998 plymouth neon
Disconnect battery (-) for about 10-15 seconds. It will come back if problem not cured, you know that right?
Jun 15, 2009 | 1998 Plymouth Neon
2005 dodge neon light stays on
i have a 2003 dodge neon and mine does the same thing and i had the oil changed by the dealer, its full of oil as well, they put just a tad over in it and the light comes on and blinks for second then goes off and the only thing i do is let the oil go out on its own and get to the level its supose to be and once it gets to that it will stop, well it should but if you want to be sure have it checked out. i hope this helps you out, let me know if it does.
Mar 24, 2009 | 2005 Dodge Neon
Computers & Internet Logo
116 people viewed this question
Top Neon Computers & Internet Experts
David Payne
David Payne
Are you a Neon Computer and Internet Expert? Answer questions, earn points and help others
