Question about Oreck XL2800 Bagged Upright Vacuum
Turn on motor just humms - Oreck XL2800 Bagged Upright Vacuum
  • 377 Answers
If the motor is actually running and not picking anything up, I would believe it to be either a broken drive belt for the beater brush or the beater brush is frozen or both. Remove the beater brush and clean, paying special attention to the end pieces that hold it into the vacuum. If possible spray a little WD40 on them to be sure they turn freely on the brush. Also a good idea to replace the belt, but be sure it is installed correctly in order to have the brush move in the proper direction.
Posted on Sep 16, 2010
  • pwillitz Oct 04, 2010
    I am sorry my solution was of no help to you.
    Paul
VACUMN MOTOR SHOUNDS LIKE IT BURNED OUT I SHUT IT OFF NOW IT ONLY TURNS ON THE ROLLERS AND DOES NOT SUCK...
if you have a two motor vacuum, the brushroll motor may still be turning the brush roll, you will have to replace the suction motor.
Jan 22, 2017 | Vacuums
Electrolux Ultra Active ZUA3840 error blinking L (or 7)
Sure, Disconnect the two wires going directly to the motor. Then apply line voltage directly to the motor terminals. If motor does not turn it is defective - check the brushes for wear or bad contact. If motor runs then the electronics are bogus.
Nov 28, 2013 | Electrolux Vacuums
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
Beater bar motor quit, now the main motor quit. Replaced the on/off switch. still nothing
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Vacuums
Power is not coming on
Sep 27, 2012 | Wagner Spray Tech Wagner 915 1,500-Watt...
The pump motor hums but wont start
unplug machine and see if you can turn the brush in the head. if the brush can be turned then the motor is probably burnt out. if the head is hard to move then there is something stuck in there preventing the motor to turn. there is usually a belt from the head to the motor.
hope this helps
Jul 12, 2011 | Vacuums
Brushes are not rotating is there a belt
I had the same problem, on mine there is no belt, the brushes are driven by an air motor. My problem turned out to be one of the motor brushes was completely worn out and the motor was not turning at the proper speed.
Mar 28, 2010 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover SteamVac Dual V Carpet Cleaner just hums when I turn it on
if the motor doesn't run sounds like you either have a bad motor or your motor armature might have gotten wet and created a dead spot.if you have any contact cleaner spray a little on the armature then turn the motor by hand make sure its uuplugged first if you can turn the motor then plug it in and try to start it
Apr 04, 2009 | Vacuums
Power head for Kenmore Canister Vac
Another potential problem for the increase in difficulty in turning the beater bar (drum) could stem from extremely dirty bearings, located at each end of the beater bar. I've seen hair knotted up to the point it chokes the bar and significantly reduces its ability tpo turn.
Mar 11, 2009 | Kenmore Whispertone 29512 Vacuum
Oreck XL2800 Bagged Upright Vacuum Logo
66 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
