Question about ASUS A7V266-C (A7V266-C W/A) Motherboard
Compatibility issue I have only one questuion. Which LAN card do you suggest to me to buy? thnx in advance
  • 2,785 Answers
Dlink one
Posted on May 17, 2008
My Acer emachine EL1800 was damaged by suspected lighting. The Lan connect is out and video output sometime shows no signal on the monitor. Can video graphic & Lan can be replaced ? OR I have to...
First, I suggest that you get the PC checked by a professional for possible damage.
As far as LAN and Video Card are concerned, and if this appears to be the issue, you can buy and add additional LAN and video Card, which would be cheaper.
Hope it helps! Good Luck! Thanks for using Fixya!
Jul 01, 2011 | Acer (ACERMOTHERBOARD)
MSR 206
there is no way to use it with win7 if driver not reader is only support with win98/2000/nt
May 24, 2010 | Unitech MSR 206-33 (msr206-33) Magnetic...
Compatibility of Radeon HD4770 with PCchips a15G motherboard?
i is supported... the alternative card is nvidia GTS 250, XFX GTS250 1gb cost ~rs8500
Jan 17, 2010 | PC Chips PCChips A15G Motherboard - v1.0,...
The internet providers technical person connected the cable and told me that your lan card is faulty so change it. my lan card is inbuilt on motherboard
Unplug your power cable; Take off your casing cover; make sure your hand is dry and clean, install your LAN Card to the right slot (Please refer to your Network Card Manual Book); Power On your PC, Press Delete at boot screen until u login the bios screen, go to the Advanced Tab on the top there, Select [Disable] for Onboard Lan; Then save & exit. You're done well! Congrat!
Dec 01, 2009 | ASUS M2A-VM Motherboard
My internet provider says i need a lan card what is this? and how do i get it
You can buy Lan card at any computer store, just give them the spacification of your computer and model, they will give you the Lan card compatible to your computer.
Lan card is a board that you will attach to *********** board, it have an connector for you lan cable so that you can connect to a modem to connect to the internet.
Nov 04, 2009 | Dell Computers & Internet
I have a p4m800pro-M v2, i recently change my os to vista starter, the problem is my LAN driver is incompatible with vista due to im using the installation disk supplied.. i tried downloading from ECS...
P4M800pro LAN CARD are no longer available driver for Windows Vista, all you have to do is to buy a new LAN CARD Vista ready.
Actually this motherboard are only have its own lan driver available for 98/2K/XP/2003 but for VISTA i think not.
Hope this might help you some ideas to provide some assistance. Good luck!
Aug 07, 2009 | EliteGroup P4M800PRO-M Motherboard
Lan card toshiba wireless no working
Check this Tip for an overview
  1. Connect your PC to your router using LAN Cable: be sure you can browse internet
  2. If you cannot browse check router config with your ISP
  3. Connect to your router using IP address you find for gateway in Network status
  4. Configure your router wireless section to match with your PC card
  5. Start removing security, broadcast radio signal, create a simple SSID as network name
  6. Check if router network is seen by your PC card (when you disconnect the LAN cable and activate the wireless card)
  7. If connection is established ( near the router) try different location
  8. Reconnect cable and reconfig adding security protocol (WPA-PSK recommended) use parameters compatible with your lan card
Jan 15, 2009 | Toshiba Satellite 5105-S501 Notebook
Compatible with Microsoft Vista?
I would like to tell u that since vista was lauched it had some driver compatibility issues with most of the printers , however its been nearly one year now that vista has been in the marketplace & almost most of the issues have been taken care of.
However in case u would like to get a recommendation on compatibility > being a technician i would suggest you to go for Hp Photosmart C 7280 all in one printer .
Thanks .
May 06, 2008 | HP Photosmart C7180 All-In-One InkJet...
Lan card
Use a different PCI slot and reinstall the drivers for your LAN card. If this does not fix the problem there may be a compatibility issue between the network card and some other software (eg. irq conflict etc.), or the LAn card may be slightly faulty and have problems on some motherboard.
In this case you can try troubleshooting the problem.
If you cannot find out the problem at a glance, checking in device properties, you may be forced to reinstall Windows. In this case I suggest to just replace the part. The Ethernet (LAN) pci card is quite an inexpensive part, and you can still use this one on a different computer.
Apr 02, 2008 | Gigabyte Slot 1 GA-6BXC Motherboard
ASUS A7V266-C (A7V266-C W/A) Motherboard Logo
37 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
