Asus K60i - wiped hard drive - no partition - no recovery CD/DVD - what's the quickest way to get going?
    Guru:
  • 1,082 Answers
Sounds like it is time to buy an operating system at the local store.
Posted on Sep 16, 2010
Asus T101MT-EU windows 7 recovery t101.
You can download an ISO from Microsoft or many other sites. They are only useable if you burn them to disc and have your COA.
Dec 24, 2013 | ASUS Computers & Internet
Factory Restore
Try F9 during boot.. I doubt you repartitioned that small partition when you reformatted the main partition of the drive. Then again, the F9 function might not work anymore, even though the partition is still intact.. From Asus Support:
Using the Recovery Partition(on selected models)
1. Press < F9 > during bootup.
2. Press [Enter] to select Windows Setup [EMS Enabled].
3. Select the language you want to recover and click Next.
4. Read the ASUS Preload Wizard messages and click Next.
5. Select a partition option and click Next. Partition options:
Recover Windows to first partition only.
This option deletes only the first partition and allows you to keep other partitions, and to create a new system partition as drive "C".
Recover Windows to entire HD.
This option deletes all partitions from your hard disk drive and creates a new system partition as drive "C".
Recover Windows to entire HD with two partitions.
This option deletes all partitions from your hard drive and creates two new partitions "C" (25%) and "D" (75%).
6. Follow the onscreen instructions to complete the recovery process.
Dec 12, 2013 | ASUS K52F Notebook
Hooking up a Internal Hard drive
You probably need to give more details. If it's a replacement drive, did you reinstall Windows from a CD? Did you copy from the original hd? It's simple enough to remove the two cables from the original drive, physically remove and replace the drive, and hook up the new drive. But then you'd need to boot to a Windows CD in the CD/DVD player to format and install Windows, if that's what you're attempting to do.
There's possibly a recovery partition on the old drive )or a recovery CD). If so, you'd connect the new drive to a second power cable, and data cable (which might not be included in the tower) :
(from http://support.gateway.com/s/Manuals/Desktops/8510406.pdf)
To restore system software from the Recovery discs:
1 Insert the Recovery disc #1 into the CD or DVD drive.
2 Restart the computer, then press and hold
R when prompted to display the restore process options. The
Options menu appears.
3 Select a restore process option:
- Press R to boot from the hard drive recovery partition
or CD. If no recovery partition is found, go to Step 4.
- Press F to format the hard drive and perform a full system
recovery, then go to Step 5.
4 Click a system restore option. For more information, see
"Restoration options" on page 5.
- Non-Destructive System Restore (Recommended)
- Full System Restore (Destructive)
- Full System Restore (with Backup) (Advanced Option)
5 Follow the on-screen instructions to complete the system
software restoration process.
Oct 29, 2013 | eMachines ET183105 PC Desktop
I can't boot from a DVD ... tried the BIOS options but it doesn't even give a boot from cd dvd option... there are two boot options and Ive tried them both (doesn't say cd dvd just some numbers) but it...
Instead of wiping the harddrive, you can run recovery by pressing F9 at start up (Asus logo) if the fabric installation is present. This can also solve the dvd-issues, try that.
Sep 19, 2013 | ASUS U52F-BBL9 Laptop
OS Hard drive missing
Using Recovery Partition
The Recovery Partition quickly restores your Notebook PC's software to its original working state. Before using the Recovery Partition, copy your data files (such as Outlook PST files) to USB storage devices or to a network drive and make note of any customized configuration settings (such as network settings).
About the Recovery Partition
The Recovery Partition is a reserved space on your hard disk drive used to restore the operating system, drivers, and utilities installed on your Notebook PC at the factory.
Sep 12, 2013 | ASUS Computers & Internet
Memory wipe wd3200bevt
Download MiniTool Partition Wizard Bootable CD 7.1 from Here.
Or Download Directly by Clicking here
This CD allows you to boot computer directly into MiniTool Partition Wizard to manage partitions without any limitations. You can rebuild MBR, Partition Recovery, Move/Resize Partition, Merge Partition, Change Cluster Size, Copy Partition, Create Partition, Delete Partition, Format Partition, Convert File System, Hide/Unhide Partition, Explore Partition and much more.
Burn ISO file onto a CD using any CD/DVD Burner software.
Set the CD-Drive to 1st boot device in BIOS.
Insert it into drive and reboot the system.
You will get Partition Wizard Boot Disc Menu.
What to expect from this bootable CD
Step 1: Choose boot disk
Step 2: Choose screen resolution
Step 3: Manage your partition
How Delete All Partitions?
  • There are two ways to start this function:
    1) Click on Disk in the top menu, click Delete All Partitions from the drop down menu.
    2) Click Delete All Partition under Disk Operations in the Action Panel.
  • Delete All Partitions will delete all the partitions in the present chosen disks.
    Note: May cause Windows to not start properly when used on partitions containing the boot partition or system partition.
For more information check the website Link
Hope this will be useful for you.
Best Regards
Nandu
Apr 04, 2012 | Western Digital (WD3200BEVT) 320 GB SATA...
When i change my laptop wallpaper, and close the laptop it stays. But if i shut off the computer, it turns back to windows default wallpaper. I want to try to reformte the laptop, but i cant find my...
f you laptop was not supplied with a Windows CD then most likely the hard disk on your laptop has a recovery partition on the hard drive and you can restore your laptop back to the condition when you first purchased the laptop using this recovery partition.
Acer can also supply a recovery CD for your model laptop if you request one. This is needed when the hard disk has failed.
Read your laptop documentation for the instruction on the restore procedure. You also get this information from Acer's WEB site.
Apr 26, 2011 | Computers & Internet
My Asus k50Ij laptop was stolen now i got it back they changed the user name what can i do please help
Reinstall the operating system - it should wipe out the password and viruses that may have installed when they used it. Unfortunately, if it's a HDD password - get another hard drive. Go to the ASUS website and determine if there is a recovery partition in the hard drive to restore back to factory settings.
Dec 15, 2010 | ASUS Systems K50IJXD1B Notebook
I'm trying to wipe my hard drive with Fedora 12 and three partitions. I have 1 system disc and 3 recovery discs from Acer. After installing files from the system disc, I replaced it in the DVD drive with...
Jeff what you have to do is this dont disturb yourself just go straight off the system then later on it and press your key F11 down at a time simultaneously then it will bring the system recovering factory settings for you and follow the instructions then you are through is just that all you have on the system will be gone but you will have your system back alive the way it was manufacture to work BYE THANKS
Feb 20, 2010 | Acer Aspire 5520-5908 Notebook
Computers & Internet Logo
401 people viewed this question
David Payne
David Payne
