Question about Canon CanoScan 4400F Flatbed Scanner
Canoscan 4400F The scanner only scans badly in black..almost like negative image of a normal document. What is wrong? I didn't get any installation CD's with this scanner..is this the problem?
  • Canon Master
  • 13,433 Answers
Well, lets start with geting the newest software for your product.
select your operateing system and language and download the newest versions from here
http://software.canon-europe.com/products/0010399.asp
Posted on May 17, 2008
  • Ekse May 17, 2008
    And, if you have already installed any software / drivers for the scanner uninstall them before installing these newer tools from canon
My scanner was scanning my 35mm slides beautiful..then just started scanning them as if they were a negative..help
Well from my past experiences with those scanners it is usually caused by the memory filling up from all the images your scanning. My first suggestion is to reboot your computer to clear out the memory. If the problem persist's then I would contact Canon you may have a problem with the unit inside your scanner that does the imaging.
I hope this helps you out if it does please give me a YES that I did attempt to help you with your problem. Thank you
Apr 08, 2011 | Canon CanoScan 4400F Flatbed Scanner
Pages come out crooked and upside down on their own - not operator error! Why does this happen and can it be fixed?
I had the same problem scanning to PDFs with the CanoScan Toolbox until I went to the File Settings dialog, and unchecked the option "Detect the Orientation of Text Documents and Rotate images". Now it seems to work more predictably (no more scans that have been rotated for no apparent reason).
Jan 28, 2011 | Canon CanoScan 4400F Flatbed Scanner
Why is my canoscan 44oof scanning in negative mode i.e white paper with black print is scanning black with white print
I solved this problem by the following:
Don't scan from the Canoscan toolbar. Use an imaging program (I used Picasa), import from the Canoscan, and Scangear opens up. In the settings for Scangear, you can choose positive or negative film (use positive for slides). You can keep using Scangear, or after using it once, you'll see it has corrected the problem with the toolbar
Oct 07, 2009 | Canon CanoScan 4400f MultiFunction Color...
Slides scan as negatives
this scanner usb cabal no didact tell me bored problam ya cabl problam 6600E
Feb 04, 2009 | Canon CanoScan 4200F Flatbed Scanner
Cannon 4400F Scanner
I had the same problem with about 1 out of every 16 slides when I first got the scanner. The only way I found around it was to rearrange the slides and try again. I started scanning through the ScanGear software instead of Canon Toolbox, and haven't had that problem since. I've scanned about 6,000 slides and negatives so far.
Jan 25, 2009 | Canon CanoScan 4400F Flatbed Scanner
Help installing CanoScan 4400F
Here's the link for the drivers, just select your Operating System and language and you should be good to go. It also includes the software that you need.
Canon CanoScan 4400F Software Driver
Sep 18, 2008 | Canon CanoScan 4400F Flatbed Scanner
Color
You may need to calibrate the scanner. This should be able to be done in the Advanced Mode of ScanGear. ScanGear is the scanner driver. Once in Advanced Mode, locate the option to Calibrate under the Image Settings section.
Jul 02, 2008 | Canon CanoScan 4400f MultiFunction Color...
CanoScan 4400f
Keep the protective cover on except when scanning slides or film.
Jan 27, 2008 | Canon CanoScan 4400f MultiFunction Color...
Canon CanoScan 4400F Flatbed Scanner Logo
117 people viewed this question
old marine
old marine
