Back to:
Tags:
Heaters
Generic problem for all Heaters
Portable radiant convector heater -burner slightly...
posted by me68gan on May 17, 2008
hi there
i have an everdure bridadier 25mj portable gas heater.
2 of my 7 burners are not working properly.
they do seem to have a flame behind them but they are not burning as brightly as the other burners.
how can i fix this problem?
does anyone have a manual
cheers megan
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 30, 2008
Not Rated (0)
burzerko
Rank:Guru Guru
Rating: 88%, 113 votes
you probably need to adjust the primary air mixture. There should be shutters on the front of the burner assy. If this does not correct the problem you may have dirty burners themselves. you could remove the burners and drag a wire brush across them to clean. but do not drills the openings unless you use a r&m bit
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on portable radiant convector heater -burner slightly faulty:
I don't want to Accept this solution
Can you Help with these Heaters problems?
Rinnai Toyostove Direct Vent Heater:...
my stove keeps going to error code 6 and 2. what does that...
Heaters
How serious is a crack in the heat exchanger ? How much to...
Heaters
I can't adjust the heater to go on when the temperature...
Coleman Propane Forced Air Heater...
I have a rottisere grill that uses an electronic ignition...
Leisure SPC-54 Patio Heater
I purchase a All-Pro SPC_54 patio heater this summer. Used...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
