Question about Texas Instruments TI-84 Plus Calculator
When I try graphing a simple equation, it says error window range. What should all of the values in my window be set to?
  • Texas Instru... Master
  • 7,993 Answers
To restore the default Window dimensions, press the [ZOOM] key and select the option [ZoomStd] (Zoom standard). When in Zoom Standard, the window dimensions are
Xmin=-10.
Xmax=10.
Ymin=-10.
Ymax=10.
You can set Window dimensions by pressing [Window] and enter meaningful values that maximize the view. In any event Xmin must be Less than Xmax
Ymin must be Less than Ymax.
You will have to test different values to optimize the view. Knowing something about the function will help you determine where the interesting behavior is.
Posted on Sep 19, 2010
How do I graph a simple equation, without getting an error 07 message? y=-1.5x+3
Error 07 Syntax
Means you made a typing error while entering the equation. Using the minus sign instead of the negation sign (change sign) (-), can produce a syntax error. Maybe you need to explicitly type the multiplication sign
y= (-) 1.5*x +3
Try entering it as 3 - 1.5*x
Jun 11, 2014 | Texas Instruments TI-86 Calculator
When I try to enter a simple equation and graph it, I get error 07 message instead of graph.
Error 07 Syntax
y= (-) 1.5*x +3
c3b67db6-adc8-4b0c-8e71-dc94a9bdbeb0.png eb28a330-c2e9-4879-857f-1e41bfe8515a.png
Cannot graph two equations together, & trig graphs are not correct.
At first in Y editor type Y1=2*cosx and for example y2=[5*exp(-x)]-5 and then graphing it. Set RAD mode of course. See captured images
Jul 10, 2012 | Texas Instruments TI-84 Plus Silver...
I am trying to graph any possible equation and I get undefiend varialbe for any kind of equation as simple as x=7. It will always show as undefiend varialbe for any equation. I don't know why it does this.
Undefined variable error message displays when you evaluate a user-defined
function or run a user-defined program that references a local variable that is not
initialized (assigned a value). You have to type LineVert 7 and then graph function x=7. See captured image
May 02, 2011 | Texas Instruments TI-89 Calculator
Today i was trying to graph y=2x+23, but when ever i would press graph it would pop up window variables domain. What do i do to fix this?
Your ranges for your window settings are more, or less out of bounds with the equation y=2x+23, that you entered.
Press the [green diamond], and the [F2] keys to bring up the graphing coordinates. Enter the following values to fix the graphing coordinates. Starting at the top, xmin= -8, xmax= 8, xscl=1, ymin=0, ymax=40, yscl=1, xres=2. Now, press the [green diamond], and the [F3] keys, and the graph should display.
Dec 18, 2010 | Texas Instruments TI-89 Calculator
Graphing Problems
In home folder (main calculator screen) press [Diamond][F2:Window]] to access Window configuration screen.
Press [F1] ( not mecessary now because the F1 page is open by default). In the F1 page of configuration screen set Xmin=-10,
Xmax=10
Ymin=-10
Ymax=10
Xscale=1.
Yscale=1.
OR
Press [Diamond][F2:Window][F2][6:ZoomStd] (Zoom Standard) to set all values as above.
If a graph is active (axes displayed, or part of a curve is showing) press [F2:Zoom][6:ZoomStd]
Feb 15, 2010 | Texas Instruments TI-89 Calculator
Graphing an equation
Press the Y= key to invoke the Y= editor. Enter in your equation.
Press the WINDOW key to set the window parameters.
Press the GRAPH key to have the calculator graph the equation.
For more details and options, see the "Function Graphing" chapter in the Guidebook.
Nov 11, 2009 | Office Equipment & Supplies
Err: no sign chng
When you get the sign change error it is either that you have mixed up the left bound and the right bound or that you are marking the left and the right bound both above the x-axis or both below the x-axis. That's why you get the sign change error. Your range values must have different signs.
Aug 19, 2009 | Texas Instruments TI-84 Plus Silver...
How do you set up window range?
or press ZOOM, option 6 (ZStandard).  That instantly resets the window range.
Jan 20, 2009 | Texas Instruments TI-84 Plus Silver...
Graph feature not working on my TI-83 Plus
Simple:
Hit this sequence:
"ZOOM" "0"
That is for the "Zoom Fit" option. The calculator does not like the window you have for the equation you've given it. With this option, it will automatically give you the best fit in the window for the equation!
Nov 14, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
315 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
