Question about Dell Computers & Internet
I HAVE A VOSTRO 1500 WHEN IT IS RUNNING ON THE BATTERY IT IS FINE IF I PLUG IN THE ADAPTER/ CHARGER WITHIN A FEW SECONDS THE SCREEN GOES BLACK
  • dconner19982 Sep 16, 2010
    THANK YOU FOR YOUR REPLY. I HAVE HAD THIS LAPTOP FOR 3 YRS COULD THE SETTINGS HAVE CHANGED THIS CONDITION JUST STARTED
  • 11,896 Answers
Shut it down, remove plugin, remove battery. Press and hold the power button for 10 full slow seconds. Then wait 1 minute. Put battery back in, plug in, and then turn it on.
Posted on Sep 16, 2010
    President:
  • 2,923 Answers
Restart your system and press F2 to run BIOS setup.
Check the power option and adjust the battery and AC adapter settings.
If you're not familiar with it, you may send the computer to the reseller and I'm sure, they are aware of this issue.
Thank you and good luck!
Screen only lights up on battery power but no ac adapter/charger tried three ac chargers all do the same thing so its not screen or charger
Hi David
It sounds like a fault to its power transition section circuit. Actually, this circuit is built inside the mother board to your laptop.
Please contact the authorized service center, and describe and show them the problem you do experience now, with your laptop. It can be rectified. Gopakumar Gopalan Google
Feb 28, 2014 | Acer Aspire 7720 Notebook
Vostro 1500, won't start, I press the power button, the drive light comes on and goes off and nothing else happens. Screen never comes on, external monitor same results.
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Oct 30, 2011 | Dell Vostro 1500 Notebook
My dell vostro 1500 laptop doesn't boot up the battery and ac power source is fine, what happens is that the only light or noise that comes form it is that the caps lock blue light indicator flashes for...
it sounds like your ac adapter has burned out and won't charge anymore. That's very common... that's why they are so cheap on ebay. Either that or your power plug on the motherboard is cracked or loose at the motherboard (2nd most common) and last bad motherboard (don't assume this unless last resort.)
Jan 12, 2011 | Dell Vostro 1500 Notebook
The a lcok is flashing and my vostro 1500 will not start, what can i do>
Hi ekazar,
The easiest way to fix this problem is to perform a power drain. Please follow the instructions below.
1. Turn off the system completely.
2. Unplug the AC adapter from the power outlet.
3. Remove the battery from the unit.
4. Now, press and hold down the power button for about 15-20 seconds.
5. Put back the battery in and plug the AC adapter.
6. Reboot and observe the system.
Hope it helps.
Thank you for using FixYa.
Screen wont turn on. Laptop is on but screen remains black...... padlock with 9 on it is flashing
Hi bernmurphy,
Hope it helps.
Nov 17, 2010 | Dell Vostro 1500 Notebook
Dell Vostro 1500 not switching on...
Motherboard is bad that's why the ac adapter light will turn off ,possible short ciruit on the board. you need to have a replacement for it. Call dell tech support for repair.
Jul 21, 2010 | Dell Vostro 1500 Notebook
VOSTRO 1710 BATTERY WON'T CHARGE
If the battery will not charge, try this:
1.) First, power reset the unit by powering it off, unplugging it from AC power, removing the battery, then push and hold the power button on the unit for about 60 seconds.
2.) Next, plug the AC adapter back in (LEAVE THE BATTERY OUT), power the unit on. Does the unit power on?
If yes, Power the unit off and put the battery back in, let it charge overnight. If, after this the battery will still not charge, you will have to replace the battery. Contact the OEM to ensure you get the correct battery.
If no, remove the AC adapter carefully, look inside the DC port (where the charger plugs in to the laptop) you should see a small silver pin. Is this pin missing or bent? If the pin seems to be in good shape, then most likely you will have to replace the AC adapter. If it IS bent or missing, then you will need to contact a laptop repair center.
Oct 08, 2009 | Dell Vostro 1500 Notebook
Whenever i plug my charger in, a message is displayed saying the power type cannot be determined and the computer will not charge.
I had the exact same problem (Vostro 1500), the short story is the computer is dead and I'm looking at replacing the motherboard. Here's the long story: Whenever I got the error message, I'd fiddle with the connection at the back of the computer, and "reset" the power adapter (see below for my reset procedure). That worked for a while until last week--the computer refused to recognize the power adapter, and my little trick wouldn't work. I have no means for charging the battery, so now the whole system is dead in the water. I've determined the problem is not the adapter itself, as it works fine in another similar unit I own. It's definitely the computer's power port or some internal component related to it. Lo and behold, a bit of searching on the internet has revealed that this is a common flaw with Dell Inspiron 1500 series, and Vostro is a close relative of the Inspiron. I'm going out on a limb and assuming it's the "Inspiron Affliction." Anyway, every solution I've found recommends replacing the motherboard, because the power port is integrated with said board. $225-$300 is the going price. I'd just use a dock, but Vostro doesn't accomodate a dock, so that option is out :-/
Dell Power Adapter Reset: If your power adapter has an indicator light, does it refuse to glow when plugged in? To "reset" it, unplug the adapter from the wall and computer, then unplug the cord where it connects to the transformer brick. Plug it back into the brick, then plug it into the wall but not the computer. If the indicator light doesn't glow, then something is wrong with the adapter. But if the light glows, then your adapter is good. The next step is to plug it into the computer, if the indicator light stays on, you should be OK for now (although it will probably fail permanently sometime soon). On the other hand, if the indicator light flashes briefly and goes out, the problem is in the computer -- back up your files while you still have battery power! Either way, if your computer is still in warranty, I recommend extending it another two or three years, if that's an option.
Aug 25, 2009 | Dell Vostro 1500 Notebook
Won't Start No lights flashing does nothing when I hit the power button
Try taking out battery and plug in power. If it works, battery is faulty.
If not, try taking out your hard disk plug in power, if it works, hard disk is faulty.
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
May 08, 2009 | Dell Vostro 1500 Notebook
Computers & Internet Logo
56 people viewed this question
Alun Cox
