Question about Whirlpool LSQ9560PW
My WP EA6800XTW0 is leaking onto the floor. Why?
  • Whirlpool Master
  • 17,129 Answers
You are the best judge to see the exact spot of the leak.
So use your palm to moe over to find the water trickiling.
Look around the door gaskets , the drain hose, the drain pump or a spillover from the inlet hose/inlet valve.
In all these cases a good plumbing job can help to plug the leak. If however within the valve or pump , remove and try repairing with resetting or replace.
Posted on Sep 16, 2010
Testimonial: "Thank you for your help, now I know where to look for the leak."
Ice accumulates at bottom of refrigerator, water leaks onto floor if not removed.
sounds like a blocked drain, either by debris or failed drain heater?
Oct 07, 2015 | Refrigerators
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
Frigidaire refrigerator leaking
Good Afternoon Friend,
I understand that there is a frost build-up on the back wall of the freezer portion of your Frigidaire refrigerator. I also see that there is water leaking onto your floor from the front of your appliance. What you are describing is a possible frozen evaporator, and the freezer needs airflow to work properly. You need to completely defrost the freezer. If your appliance starts behaving normally after defrosting then you need to monitor it closely, as it will sometimes start frosting up again. If it does fail again then it's possible you have a defrost problem. Possibly the defrost heater, but can also possibly be the defrost timer or defrost sensor. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please leave me your model number. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire Refrigerators
Washer leaks on floor from drum top while centrifugating
Good Morning Andres,
I see that you are having trouble with your Frigidaire laundry center, model# FEX831F, and the washer leaking water from the drum top onto the floor. It could possibly be that your washer door is either not closed all the way or is not sealing properly. I suggest checking to make sure that the door is closed all the way. If it is, I would check the seal, and see if there anything that might be damaged and allowing water to leak from the drum top. If you are unable to find anything that might be allowing the water to leak out, I suggest contacting your local authorized technician. They will be able to diagnose your appliance and see why you are having water leak from the drum top. Hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire FEX831F Top Load Stacked Washer...
Water leaking onto paaenger floor board when a/c
There is a drain to the hvac box under the hood passenger side. It's most likely stopped up.
May 26, 2010 | 1995 Jeep Grand Cherokee
Water leaking from bottom of machine onto floor during fill and wash cycle
there are 3 bolts are bottom front compartment, may be taken off with a phillip screwdriver, or it may be a torx. when you take it off, cut your washer on and see where it is leaking, your gasket could be broken, your hoses or pump.
Sep 07, 2009 | Kenmore Elite HE4 Electric Dryer
Inside leak
It is very possible the defrost condensate drain is blocked and could be in different locations depending how your refrigerator is designed. I am sending you a couple links that will help you resolve this problem. This is a very common problem and many things can cause this. You may need to use wed and dry vacuum cleaner to help remove the obstruction. Here are some links that will help you resolve the problem. If you are still having trouble, just let me know and I will assist you in resolving the problem, Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://www.youtube.com/watch?v=c7gONf6sIHY&eurl=http%3A%2F%2Fappliancepartsseabreeze%2Ecom%2FTemplates%2FTMPn4rwgkfv9f%2Ehtml&feature=player_embedded
SITE=> http://servicepartstec.blogspot.com/
Jul 30, 2009 | Kenmore Refrigerators
My GE refrigerator collects water under the crisper and then spills onto the floor..What is the solution?
This is a common problem when the defrost condensate drain becomes blocked. Below is a link that tell more about what is happening. Sea Breeze
- This is when it leaks into the fresh food section.
http://appliancejunk.com/forums/index.php?topic=22.0 - And this link is when it's cause in the freezer section.
Jul 23, 2009 | GE GTS22KBP Top Freezer Refrigerator
Whirlpool LSQ9560PW Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
