Question about Maytag Neptune MAH5500B Front Load Washer
Mould on door + odor also the fabric softner does not always empty
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#$
Posted on Sep 28, 2010
Fabric softner dispnser filled with water
Try siphoning it out or pumping it out .
Feb 06, 2013 | Washing Machines
Mold remain in rubber rim of washer
Hi Qqiustin.There are couple of solution for this,you can try that before attempt to change door gasket.1- Run machine empty on Cotton 95C cycle,while it's intaking water add 300ml of bleach.(It could produce some foam but let it go & finish it's cycle)That progress will clean your machine & mould on the door gasket should get disappeared.Alternatively you can try EXIT MOULD or likely products on the super market sells.Follow the instruction.Goodluck.Thanks.
Aug 02, 2010 | Miele W1926A Front Load Washer
My Ge Adora washer fabric softner dispenser
You have low water pressure which wont reach the dispenser drawer during rinse cycle. Clean the feed pipe in case there's dirt in the feed gauze located at the back of the machine. The mould on the rubber is dirt in the machinme. A mixture of 1 cap of bleach and 1 small tub of Swarfega mixed with water and put into the drum on an empty wash will stop it geting worse but it cant be removed.
Dec 09, 2009 | GE WSXH208A Front Load Washer
My front load washer will not empty out the fabric softner. I have taken out the drawer & cleaned it. It will empty out the laundry soap, but not the fabric softner
I have the same problem with mine. I found that some fabric softners worked better than others. I found Downy the worst, when i switched the problem seems to stop once i cleaned out the drawer
Nov 30, 2009 | Frigidaire GLTF2940ES Front Load Washer
Why does my detergent drawer always hold water in the fabric softner and Bleach drawers
pull the drawer out and give it a good cleaning in warm water/also take a look into the hole you pulled it out off and make sure it not blocked with mould etc.adrian.;;;;;;
Nov 11, 2009 | Frigidaire Affinity ATF7000E Front Load...
The softner dispenser will not empty. then has bad smell.
if this is a front load washer you need to raise the top and check all the dispenser hoses for clogged, hardened fabric softener. if you only wash in warm or cold water, the hoses will get built up with soap and fabric softener. you need to do at least one load of hot every month to keep the hoses cleaned out, the hot water disolves it better. as for the smell you can buy a product called AFRESH and follow the directions on the package and routinely use one tablet every month for the odor. if there is a lot of water in the tub, you may have something caught in the impeller of the drain pump. hope this helps.
Nov 07, 2009 | Kenmore Washing Machines
Maytag MTW5620T2 the fabric softner despenser doesn't despense. There is mositure inside and it slings fabric softner everywhere. It leaks from the side hole of the agitator. Gets fabric softner on my...
Liquid Softener was clogged up over time.
1-Put hot water in the place of the Softener slowly and let it over flow to dissolve the solidified liquid.
2-Keep doing this until you see water at the bottom of the tub.
3-Run a small load to clean out the gum.
Jul 02, 2009 | Maytag Washing Machines
MY FRONT LOAD WASHER STINKS! THERE IS A MUSTY ODOR COMING FROM INSIDE.
what kind of washer?
all front load washers get this issue
the way to get rid of the smell is by doing an acid wash to your machine
set the washer to the highest temp setting (sanitize would be best)
mix in 1/2 to 2/3 cup of javex or white vinigar, either one will do it
run your washer through the longest cycle possible with no clothes in it
may need to be done more than once. and up to once a month
the smell is caused by leftover detergent and leftover fabric softner gathering on the interior shell and in the rubber boot at the door.
front load washers do not require much detergent at all, and even less fabric softner.
be careful on how much of these you are using, more is not better
this will help prevent the odor from comming back
as well when laundry is not being done, the front door should be left open a bit to allow air movement in the washer.
hope this helps
May 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Water left in bleach and fabric softner after running load
You must take out the compartment and empty it out before adding any bleach the next time, there is a type of button way in the back that you press down on pull out the entire door and empty the water for the next washing. You must press down very hard the entire door does come out check out your book for instructions it is way in the back on the left hand side. This happens to mine once in a while not all the time.
May 05, 2009 | LG WM1812C Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
