Question about Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT
My MX550 keyboard will not allow me to imput any information, although its Status is shown as OK I have tried to reload the program also with the same result
I can't sign into my fb page. I am on my Daughter's computer & got on yesterday
are you sure you're typing your account information in correctly? Double-check that the Caps Lock key is not active. When you were last on your daughter's computer, did you sign out before closing the web browser? Have you run a virus/spyware scan recently with an updated antivirus/antispyware program?
There are 3 possible reasons why you cannot log into your facebook page- 1) Something is causing you to not type your account information into facebook correctly. 2) Someone else got onto your daughter's computer after you used it, and if you left yourself logged in, changed your password. 3) A malicious program or hacker has changed your facebook password information, so they may use it for their own purposes.
For all three, I would recommend these steps: first, try typing in your facebook account information again, being meticulously careful to input your information in correctly. double and triple-check the caps lock key. second, run a virus scan on your computer with updated antivirus software. third, after a failed attempt to imput your account information, beneath the text box where you would normally imput your password, there will be an option saying "Forgot your Password?" in small text. This will lead you to a page where you must answer the security questions you entered when you set up the account- but once answered correctly, will allow you to reset your password.
Have a good day, hope this helps!
Feb 27, 2011 | HP Pavilion dv6000z Notebook
Keyboard meaning
With the indulgence of the other posters.
The Acer Aspire AST180-UD400B or better known as Aspire T180 comes with a standard keyboard as shown below
Should this be what you have, the basic keys on the top left are:
Esc - Escape key. It is basically a shortcut to STOP or get out of a program sequence. Often this is as a shortcut key for the Stop button in many web browsers
F1 - usually launches a program's Help Guide
F2 - usually launches Rename command
F3 - usually launches Find or Search command
F4 - formerly a DOS for launching previous OS but currently used in conjunction with Alt that closes an active, open window and/or exits a program. With no active, open windows, it prompts you to exit.
If for some reason your keyboard is different, it is possible that the dealer could have bundled a different/after market keyboard such as those web or multimedia as shown below. The top left keys then would be either for web browser shortcut keys or multimedia shortcut keys or some other specialized functions.
Should this be the case, pls post back with the brand/model which may be determined by looking at the bottom or any of the markings at the top.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Feb 11, 2008 | Computers & Internet
Computer does not display any boot screen, although it turns on. no USB ports work, not do any other inputs on the rear of the machine. this was done after migration of parts to a new case for the...
DC5000MT (i think you left off the"T" right?) MT=mini-tower then.
they at SFF then too.
old old desktop pentium 4, with pata hard drive?
no monitor stated, make nor model #
no vga card stated.
migrating? oops.. why do that? nor if PC ran before?
NO OS stated,? windows XP what? (it came with XP)
ok the mobo turns on with case power button?
and the CPU fan spins fast, as does PSU fan?
what does USB ports mean>? using what there?
PS/2 keyboard. using that? or pS2/mouse?
does it beep:?
are you sure the monitor is ok?
if monitor is ok ?
and PSU and 1 stick of ram is ok
the BIOS screens work.
or the PSU
does this mobo have onboard VGA jack GPU:>
if yes, try both it and PCI video card.
and 1 stick of ram at a time. slot1, bank 0
Aug 12, 2017 | HP DC5000M PC Desktop
My snom 300 phone displays NR help please
try resetting the vlan settings if that doesnt work ensure that the default gateway and dns settings are correct.
Dec 08, 2010 | Snom 300 IP Phone
Hi im trying to start office 2007 and its saying im putting in the rong product key
Hi, stuped question first; I take it you have the correct product key? These product keys are case sensitive, so ensure you use capitals where appropriate and you imput exactly as shown on the CD or case. If no joy, uninstall, rebbot and install again. Hope this helps
Jun 28, 2010 | Computers & Internet
I installed Skype and my webcam has audio but no video
Hello...
All you need is to install the driver on windows.
Once installed correctly on windows, now you can configure it in skpye.
Tips to configure it in skype:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com
ok
try this...
Jan 22, 2010 | Logitech Webcam
Imput analog audio to Vista laptop via HP ExpressCard TV Tuner
Perhaps this device at creative.com (The link provided for you) or something similiar will do the trick for you.
http://us.creative.com/products/product.asp?category=209&subcategory=668&product=16186&nav=1
It connects to a USB port. You have 2 on the right side of your laptop. The device has two RCA ports which should provide the connections you seek.
A device like this one or similiar should give you the best "Quality" audio transfer.
But if cost is more of an issue, you can find "Patch cables" at you local electronics store to go from RCA jacks to stereo headphone jack this will allow you to port the information in through your Microphone jack.
Hopefully this helped you,
Dave
Nov 23, 2008 | HP Expresscard TV Tuner For Windows Vista...
Finepix A350 - everything is blurry
I had the same problem. I tried a reset in the camera, also reformated the card through the camera once I had done a reset. At present it seems ok.
Aug 17, 2008 | Fuji FinePix A350 Digital Camera
Installing a French ( Brand is Genius) keyboard to my Dell computer.
Pair to a Bluetooth Device (new and re-pair)
  1. Locate the Bluetooth icon in the lower-right corner of the computer screen, and compare the status to Table 1.
    (The Bluetooth icon may be hidden, click the Show hidden icons arrow to show any hidden icons.)
    Bluetooth Icon Status Enabled - The Bluetooth adapter is ready to pair with another Bluetooth device.
    Connected - The Bluetooth adapter is already connected to a Bluetooth device (if the desired device is not the one its connected to, it will have to be re-paired). Disabled - The wireless switch is off. For information on how to turn the wireless switch on refer to the
    Online User's Guide. None When no icon shows the Bluetooth driver needs to be installed, refer to Dell Knowledge Base Article:
    "How to Download and Install the Latest Dell Wireless Bluetooth Driver" Table 1: Bluetooth status
  2. Verify the following conditions have been met:
    • Batteries are Installed in the Mouse and Keyboard.
    • The Bluetooth adapter, USB Bluetooth adapter or 13/19-in-1 Media Card Reader is installed in or attached to the computer.
    • The latest version of Dell Bluetooth Wireless Keyboard and Mouse Bundle is installed,
      if unsure refer to Dell Knowledge Base Article: "How to Download and Install a Driver"
    • The Bluetooth device you are going to pair is within 30 ft. (10 meters) of the computer.
  3. Right-click the Bluetooth icon in the system tray.
  4. Click Add a Bluetooth Device.
  5. Turn on the Bluetooth mouse and press the Bluetooth connect button on the bottom of the mouse. The Bluetooth LED on top of the mouse should start blinking. If the LED does not blink, press the Bluetooth connection button again and hold it down for 2-3 seconds until the Bluetooth LED starts blinking.
  6. Click Next to start searching.
  7. Click the icon for the mouse to highlight it and then click Next.
  8. The connection is set up automatically. Once the connection to the mouse has been created, the wizard closes and returns to the Bluetooth Settings window. The new connection is now listed there. The link symbol under the mouse indicates it is connected.
  9. SetPoint will now launch and ask to check for updates, click OK. If an update is available click to download it.
  10. After the update has been applied, click OK.
  11. Turn on the Bluetooth keyboard and press the Bluetooth connect button on the bottom of the keyboard. The Bluetooth LED on top of the keyboard should start blinking. If the LED does not blink, press the Bluetooth connection button again and hold it down for 2-3 seconds until the Bluetooth LED starts blinking.
  12. Click the box next to My device is set up and ready to be found and then click Next to start searching.
  13. Click the icon for the keyboard you want to connect to in order to highlight it and then click Next.
  14. When the keyboard is connected, the Confirm Keyboard Connection screen appears. A passkey that has been generated for the keyboard is shown. Type in the passkey as it is shown on the screen. Note:
    The keyboard can only store one passkey. The passkey is unique to each computer. If you try to connect the keyboard to more than one computer, the passkey is changed each time you create a connection.
  15. The connection is set up automatically. Once the connection to the keyboard has been created, the wizard closes and returns to the Bluetooth Settings window. The new connection is now listed there. The link symbol under the keyboard indicates it is connected. You are now be able to use the devices.
Aug 25, 2017 | Trust Silverline Direct Access 12879...
How To Import Individual WinFAX files? .FXR and .FXD
Hi You can go to:: http://www.getafreelancer.com and post this request. I've seen it there before you wil need some third party app. Look for Project Number 138099 this will give you more info. Have a Great Day!!
Apr 12, 2007 | Symantec WinFax Pro for PC
Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT Logo
387 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
