Question about Belling BE810 Bottom Freezer Refrigerator
How to defrost a belling be810 refrigerator - Belling BE810 Bottom Freezer Refrigerator
How do I defrost my Samsung bottom freezer? Can I turn off the bell if I need to leave the drawer open while it defrosts?
Most modern refrigerators can be turned off from the control panel. you should be able to shut off the alarm and the freezer and still leave the refrigerator on.
Dec 04, 2014 | Samsung RF265AA Bottom Freezer French Door...
Problem with defrost heater on GE side by side
Not really (shored out) Gidget Jordan,
Although I have experienced a high failure rate o the defrost thermostats... if they conduct at freezing and open near room temperature... they are good (designed to protect the soft plastic refrigerator interiors).
The third and final element of your DEFROST system
is the power board... (costly but easiest to change).
Amazon com wr55x10942
Unavailable at appliancepartspros
GE WR55X10942 Main Control Board AppliancePartsPros com
Sears
Refrigerator Electronic Control Board Part Number WR55X10942 Sears...
These parts are all pretty much the same quality...
Let the VIDEOS & price be your guide...
Carnac the Magnificent
Apr 21, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
What temp should belling fridge freezer be set at. fan not coming on
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 30, 2011 | Belling BE810 Bottom Freezer Refrigerator
I have a sub zero 690 series refrigerator. The display shows codes 34 01 and then EC 24 Any idea what this means? Thank you
DEFROST UNDER HEAT IS THE CODE DESCRIPTION. IF YOU HAVE A BELL BUTTON HOLD IT 15-20 SECONDS TO CLEAR. IF THERE IS NO BELL BUTTON POWER OFF THEN POWER ON TO REST AND SEE IF CODE COMES BACK AND THEN CALL FOR SERVICE. 1-800-222-7820
Apr 24, 2010 | Sub-Zero 690 Side by Side Refrigerator
Refrigerator and freezer quit working.
That sounds like it could be the problem. The common causes are a bad defrost heater, defrost timer or a defrost thermostat.
Aug 27, 2009 | Belling BE811 Bottom Freezer Refrigerator
Sub zero 632S error code 21
EC 21 has nothing to do with the refigerator. From the 600-2 series service manual page 3-21 EC 21 is Defrost Overheat fault.
The defrost system is only in the freezer and on a completely seperate refrigeration system. Clear the EC by holding the bell key pad down until you here a tone this is going to be a minimum of 15 but can be as long as 30 depending on the generation of your appliance. The part that you will most likely need to replace is the defrost terminator which stops the defrost cycle. You may have also had a problem in the refrigeration section which did fix by yourself, good job.
Oct 22, 2008 | Sub-Zero 632 / S
Belling be810
Hi the problem is with a clogged drain hose that's why all the water. to unclog turn off fridge. pull away from the wall . remove back panel. clean all vents . locate drain tube, by the drain tray. clean out the drain . thanks the appliance doc
Oct 06, 2008 | Belling Freezers
Belling intergrated Fridge Freezer
On integrated appliances the power supply is invaribly behind the unit. However there is normally an isolator to the side of the unit or in a side cupboard. Hope this helps.
Aug 06, 2007 | Belling BE811 Bottom Freezer Refrigerator
Belling BE810 Bottom Freezer Refrigerator Logo
66 people viewed this question
Top Belling Refrigerators Experts
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
Nater13
Are you a Belling Refrigerator Expert? Answer questions, earn points and help others
