Question about Samsung Jet S8000 Cell Phone
Samsung Jet Ultra will not charge & will not switch on - was okay, suddenly died for no apparent reason. Tries reset by removing battery & sim, no change. Phone only 6 months old - any ideas?
  • 358 Answers
Hi,when a phone does not come on, it is either the battery of the phone is dead,
might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to be restored
back the phone memory.
will need to be flashed.
if too weak to power up the phone all application you downloaded on the phone has
VIRUS and has affected the phone memory.
First Charge the battery for longer hours before using another battery to confirm
if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it to come back to life.
You can use the link below to know about how to flash the phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
(unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Posted on Sep 16, 2010
My battery died on my 2009 equinox & after I charged it the stabilitrak off light came on and now the vehicle is VERY hard to steer,,any ideas????
Heavy steering is an indication that the drive belt for the power steering is loose or missing. IT may be that that is the reason for a flat battery as the belt will also drive the alternator and the battery has drained down trying to supply the power to the electrical parts.. With a flat battery there may be a problem with the CPU program so use a code reader to reset it and then see if the light comes on.
Mar 18, 2014 | 2009 Chevrolet Equinox AWD
My samsung jet will not turn on
PHONE IS DEAD WON'T COME ON
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Jun 15, 2011 | Samsung Jet S8000 Cell Phone
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Oct 30, 2010 | Jet 3 Ultra Power Chair
NO SOUND FROM MY SAMSUNG S8300
the sound in my phone s8300 is low can I up sound
Jun 22, 2010 | Samsung S8300 Ultra Touch platinium-red...
I cant open my jet...stays on boot screen!!! i want to reset "bios" to factory options
If you cant boot it up then you will not be able to reset anything. Your firmware seems corrupted for whatever reason. It must be reinstalled. Please go to Samsung Service Center. They will do a thorough job and even remove all viruses etc which may be the cause of your problem.
Feb 12, 2010 | Samsung Jet S8000 Cell Phone
The battery on my jet 3 will not charge
you need to replace both batteries, their called U1 batteries (35 AMP-Hour)
Jun 08, 2009 | Pride Mobility Products New Pride Mobility...
Batteries not charging - just replaced with new -amp meter dosent move while plugged in. Old batteries were dead and owners manual says charger will cease to work when batteries die and to contact pride...
1st Check the 25amp inline fuse located behind the volt meter. 2nd Check the 50 amp fuse located behind the foot rest. A pin located under the foot rest when pulled out will open the front to access the fuse.
May 07, 2009 | Jet 3 Ultra Power Chair
Jet 3 Ultra won't charge
Indeed, you need to find a repair shop. Try a google search for power chair repair, or ask your local hospital or if you can find one a power chair store. Most likely, you have a mechanical failure of the wiring, the battery themselves, or corrosion on the battery posts. Since the chair lights up when the charger is in, it is unlikely that the charger is broken. You may have a failure of the controller board, but that is also unlikely. And batteries do not usually suddenly fail completely; they typically fail slowly, losing the ability to completely charge.
I assume that you did not see a great deal of fluid leaking out of the battery container; you might look in the container and check to see if a battery is cracked or missing fluid.
Nov 10, 2008 | Jet 3 Ultra Power Chair
Check the fuses may have a Blown fuse
Regards; Aaron
Sep 16, 2008 | Jet 3 Ultra Power Chair
Samsung Jet S8000  Cell Phone Logo
354 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
