Question about Frigidaire FRS26R4C Side by Side Refrigerator
Can a compressor be replaced without a service tech?
  • Frigidaire Master
  • 43,501 Answers
Hi, No, You need special equipment to do this...
Here is a tip that I wrote about how to add refrigerant to a air conditioner orcooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Posted on Sep 17, 2010
My a/c on my Buick ,Enclave blows hot air took it to dealership .Service tech said it was low on freon checked for leaks none were found .One hour later hot air was blowing again.Service tech cannot find...
Where is the hissing sound coming from ? What year is the vehicle , how many miles on it ? Ever have A/C repaired ? compressor replaced , system opened up ? Without hooking up A/C pressure gauges an checking could only offer a guess as to what the problem is . I have no idea how good the dealer tech's knowledge of A/C system is . You mite try another repair shop , You don't need to take it to a dealer , there are a lot of good independent repair shops around . Have any near you that have been there for years ? Most of this have better tech's then dealers .
Mar 05, 2018 | Cars & Trucks
Freezer is making an on and off clicking noise. and making lights dim
The compressor is trying to start and going off on overload that is the clicking noise you are hearing.... Also the compressor is drawing high amp which is what is causing the lights to dim.....You have a compressor that has a locked rotor or the start components are bad....
In either case if you can't get a service tech to come out right away you will need to unload the freezer.... because the compressor is not working which is what the freezer uses to make it cold...
When the service tech checks it out he will be able to tell you if he can get it to work by replaceing a capacitor or the Compressor is not repairable.and that he will have to replace it..... which is a major repair.
If the freezer is old I would recommend buying a new one...... You will get a new 5 year warranty on the compressor and if you replace the compressor you will get only a 1 year warranty.....
May 30, 2011 | Kitchen Ranges
Compressor will not kick on
About the only thing you can do without a service tech looking at the unit is to check the capacitor. If it is bulging it has blown and you'll need a new one. If you are not comfortable working with electricity I'd take it to someone because, even unplugged, you could get harmed or worse just from handling the capacitor.
If the problem is not the capacitor and the unit is getting power the chances are good the compressor itself has blown and you'll probably be better off buying a new unit rather than bearing the cost of a comrpessor replacement. That choice is, of course, up to you.
Good luck.
May 26, 2010 | LG LHD45EL Dehumidifier
Humidifier compressor does not stay on more than 1-2 minutes
Sounds like bad relay on compressor or bad compressor. There is only so far you can go yourself without knowledge in electrical and AC units. Suggest you call a service tech or if you can take it to service cemter near you. Russ
Jul 24, 2009 | Kenmore 5230 Dehumidifier
How long do i wait to connect the fridge after I moved
Rule of thumb...if you laid fridge down, stand it up and leave unplugged for same amount of time fridge was laid down. If old fridge, and will not come on after above method, it is possible compressor motor has fallen out of mounting isolators inside compressor case. If so, compressor may hum and get hot but not cool fridge. This means you may need a tech to diagnose further, but probably cannot fix without replacing compressor. Only a qualified tech can diagnose this for sure.
Jul 23, 2009 | Refrigerators
Central air unit only blows warm air , when set on cold
First check to see if your outside unit is working and you can here the compressor running. If the fan runs and the compressor does not you have a problem with the capacitor or wires burnt off terminals. If your not sure you know how to work on this please call a service tech ask for free estimate. If the unit compressor and fan runs you may be out of gas that meanns you have a leak. Either way you need a service tech. You can only go so far without the correct tools to work with. Russ
Jul 22, 2009 | Heating & Cooling
My air conditional unit outside ,fans turns on but the unit compressor wont turn on,just stopped working this morning.i turned the thermostat to 72 but only the fan on the outside unit comes on and it is...
Somethings aperson cant fix without a service tech. First it could be wire burnt of capacitor going to compressor. Second it could be bad capacitor. There is a dual capacitor on the ouside unit one side says herm that runs the compressor. Turn power off to check to see if wire is burnt of the herm terminal or the C ternminal. Wire burnt off compressor common terminal.. Could be locked up compressor. Unless you know how to troubleshoot unit. You may have to call service tech. Cost if bad cap. is about 100 to 150. But unit wont run without it. Rus
Jun 21, 2009 | Emerson Quiet Kool 12HT13 Air Conditioner
We got an a/c central unit goodman modle ckl60-1 and a month a go it broke and the technician said that it needed a new capacitor and freon and about a week ago the unit broke again and the technician said...
When a compressor is has to start. 1. HAs it been off longer than five minutes. As a service tech when I run on to this problem I install a hard start kit and a time delay. The start kit helps the compressor to start under heavy load condtions. The timer helps the compressor to balance out before tryng to start. Have tech set at 5 minutes. I install hard start kits and time delays on all my change outs. Replace problem will go away. Thanks Rus
Jun 15, 2009 | Goodman CKL60AR60 Air Conditioner
Maytag has a recall for compressor relay update possible fire hazard stated on notice,tech comes out and does update,now fridge wont cool. tech states that adaptive defrost timer is bad,he jumped wires...
Check the cold control thermostat for continuity.(off/on switch)
When he bypasses the wires at the board ,he also bypasses the thermostat control.
Apr 08, 2009 | Refrigerators
Frigidaire FRS26R4C Side by Side Refrigerator Logo
56 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
