Question about Vacuums
How can i avtivate my mblaza RCV/STV on my usb broabband
My Dyson cordless DC59 won't keep a charge.
If you charged the vacuum overnight and it immediately, or shortly there after, your battery is shot...
Apr 09, 2017 | Dyson Vacuums
Need a manual for a shark SHKC7800 1400w 4.1ch. motorcycle audio system W/2 remotes FM,SD,usb bluetooth
Follow this link. On the right side one half way down should see download here. I started it to make sure it worked. Started fine so I canceled since I have no need.
For future reference most of the time you can find manuals by using model numbers etc followed by .pdf
Try it using you SHKC7800.pdf to see what I mean.
Good luck
Nov 26, 2014 | Shark Vacuums
Kindle fire will not charge charging port is broken was told there was recall on this
Check Amazon's website. Are you sure it is the port. The usb to usb mini cords go bad quite often. Have you tried another known good charger and cord?
Apr 01, 2014 | Bissell Perfect Sweep Turbo Sweeper
Unit wont turn on then wont turn off
when i put in the usb cable from the speakers to the lap top it dosent read it on the laptop end that something has been connected
Dec 23, 2013 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
I lost cd and usb cable for my timex ironman data link system watch,is it possible to get another
"A replacement charger cable may be ordered by calling 1-800-328-2677. The cost of the cable is $10.00 plus tax. Domestic First Class shipping is included in that price. International and expedited shipping will incur an additional charge. The order can be charged to the credit card of your choice. We accept Visa, MC, Discover and AmEx".
Dec 09, 2010 | Vacuums
Sir, I have TDK 4 GB Pendrive. I was formated some
this the great solution... try low level format..
1. plug ur usb flash
2. run Formatter v2.9.0.9.exe
3. follow the instruction and wait for the format (might take 5min for 4GB)
4. after complete, may the small volume (about 2MB...here the solution
5. plug your usb flash on other computer and format like regular (make sure u untick quick format) and click on "restore device defaults" then click format
6. now your usb flash drive was like a new one
Dec 14, 2009 | Vacuums
Manual Mode doesn't work
OK, so I had the same problem. I had not used the manual mode in quite a very long time. Went to use the hose the other day and nothing. Blinking light and no noise. Came here for an answer and iceray123 is on the right track.
On my bot, the switch is on the right side of the hose grip, so it's facing you when you look in the holder. It's a black, rubbery looking "teardrop".
I happened to have some electrical contact cleaner and gave it a squirt. Moved the switch in and out, working the fluid in there to clean out the gunk and the contacts.
Presto! She's hummed back to life!
If you don't have a can of contact cleaner you could possibly spray a little bit of WD-40. According to the WD-40 Job Site, it's also "A Great Contact Cleaner" **Your results may vary**
Hope this helps!
(Now back to cleaning)
Dec 25, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Vacuums Logo
306 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
