Question about Square D Powerlogic Circuit Monitor Cm2150 Cm-2150
Alarm code 991 - Square D Powerlogic Circuit Monitor Cm2150 Cm-2150
Why does the alarm randomly self arm when driving
I located the user guide for your remote...you will need to download the PDF file to view, then search the troubleshooting section...last resort would be to phone the 800 # Customer Care or send the manufacture an email describing your problem...Thanks http://auto.manualsonline.com/manuals/mfg/python/991.html
Jan 07, 2016 | 991 Responder LC3 SST Security/Remote...
Python 991 remote starter won't work in manual transmission vehicle. I have followed instructions, step by step. I get Error code for car alarm. Every once in a while it will work, but I am not doing
Not 100 percent sure, but sounds like the neutral switch connection is not working properly. Python can and is used on lots of standard vehichles, but they tie into the nuetral switch on the transmission. If this switch or the wires are corroded or loose, this is the problem that usually shoes up. Hope this helps
Mar 18, 2014 | Vehicle Parts & Accessories
A few times each week when i use the remote start function on my Python 991, the truck will start for a second or two then the horn starts blowing, lights flash then the truck shuts off and I lose all...
It sounds like the factory alarm is setting up. To make sure the factory alarm does not come on you should make sure all doors are closed before you actually hit the remote to lock the doors. Do not lock the doors with the switch on the door. Make sure you use the Python remote only and all doors closed before you press the lock button.
Jan 23, 2011 | 5702P Python 991 ResponderLE 2Way Security...
Code 991 continues to show.. will not clear... how do we clear that code???
to clear the 991 Takagi code, simultaneously press the bottom 2 grey buttons of the four just to the left of the flashing LED light. When the LED stops flashing, release and then press the reset button on the black panel about 8 inches above that
Jan 17, 2011 | RTO Takagi T-M1 Mobius Gas Tankless Water...
Cannot program Insignia IS-TV040919 20" TV on a comcast 3 device remote (red OK button) None of the codes work.(10171,11204,11963,12002)
No problem, This issued will be only resolve with regular TV's, not LCD or PLASMA Tv's. Just press TV botton locate on the top leftside of the remote, right after hold the SETUP button for 3 seconds once the TV botton blink twice go and press 991 then 1 again, right after you have pressed 991 the TV botton will blink twice and when you press 1 will blink twice as well, after those steps keep pressing the channel up botton until your Tv shut off. That will work. Good luck
Jan 07, 2010 | Insignia Televison & Video
I can't change the cable channels
Try the 991 code, press tv+ code set+991 then alternate between tv and power stop as soon as the tv respond then press enter , could take up to a 100 try since it goes thru all the codes. have fun
Nov 02, 2009 | Insignia NS-LCD19 19 in. LCD TV
I have a Toshiba DKT3010sd. How do I change the main greeting on the phone? I am able to change all the personal greetings but the main greeting (the first greeting the person hears when they call our...
if the password has not been changed it would be the extension followed by 997, i.e. password for mailbox 990 would be 990997 and 991 would be 991997, you can also log into mailbox 999 and assuming that password has not been changed and is 999997 you could go into admin mode and reset the mailbox security code for 990 or 991, hope that helps.
Jun 17, 2009 | Toshiba DKT3010SD Corded Phone
I am trying to change our company voicemail and the manual (with the company's contact info is, who we bought the phone from) has walked away. Is there a standard code for setting the main VM greeting?...
What Toshiba Voicemail system do you have? Is it a Toshiba or third party voicemail? Depending who setup you voicemail and what version you have. Mailbox 990 is the Intro greeting "thank you for calling xyz company". Mailbox 991 is the main greeting "press 1 for sales press 2 for tech support etc. If you have a toshiba Voicemail. Need to login to 990 and 991 (need to know passwords) Newer versions you can setup just 991 mailbox for both.
Nov 26, 2008 | Toshiba DKT 3010 Corded Phone
Square D Powerlogic Circuit Monitor Cm2150 Cm-2150 Logo
89 people viewed this question
Top Square Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Square Measuring Tool and Sensor Expert? Answer questions, earn points and help others
