Question about Xerox DocuColor 12 Printer
What is warrenty of a xerox photo coppy machine
9-343
Posted on Sep 23, 2010
Does not coppy from a4 to b3 says set adf ??? di183
ADF is the feeder on top of the copyboard glass. set your original in the tray atop the machine. then select the copy size you want.
Nov 21, 2013 | Minolta DiALTA Di183 Copier
How do you reset toner counter on phaser 7750? Thanks
On the back of the 7750 toner there is a metal piece you can push in near the end that goes in to the machine first, this will tell the printer that the toner you put in has not been installed until now. I would not suggest doing this unless the toner is full and is using geniune xerox 7750 toner.. If you refill it with generic or non-7750 toner it can damage the machine and will void any warrenty you may have left on the machine.
If you switch machines with the 7750 toner the machine will not know how much toner is remaining in that toner. Xerox changed this method on the 7760 to use a toner chip to fix this.
Hope this helps, thanks
Apr 01, 2011 | Xerox Phaser 7750DN Laser Printer
Xerox Document Center 440 replace cartarage every 4 coppies
just Check The Wiring of dc bord
in back side of a printer.
Dec 28, 2009 | Xerox Document Centre 265ST Printer
"Power Up Failed" Error
On this product you may need to have Xerox to come repair the copy machine.
This problem maybe more involved than anyone can assist to correct it on this site.
Also, depending on the call charge if all parts and labor are included with the charge, "PAY THE $400.00 FOR THE REPAIR VISIT."
It is well worth it! Besides Xerox will warrenty the service call for 30 days.
Oct 11, 2009 | Xerox CopyCentre C65 Black and White...
The machine says my copier/scanner has failed to initalize . what do i do ??
This problem might need a Xerox Serivice Rep to repair the machine.
Sometimes the scanner motor fails, needs to be replaced.
The drive cable might be loose or have broken gears on the drive motor.
For indepth solutions, call Xerox, hopefully the labor and parts are included in the call charge. Xerox will warrenty the service for 30 days.
Oct 07, 2009 | Xerox CopyCenter C118PL Copier
Graininess on xerox dc12 print s
hi i think u took print in low resulution photo. pls check ur phot resulution.
Nov 21, 2008 | Xerox DocuColor 12 Printer
J1 Error, Changed a brand new factory-sealed toner, still getting J1 Error
Make sure you have the right code: J1 or J2.
one is for the drum and the other is for the ink.
Make sure the toner unit is for this model and not for a different model.
If the old modual is still available, check the connectors at the back and see if they are the same.
If anything else Call Xerox for repair. If the cartridge was bought through Xerox have your reciete available for warrenty.
If repairs still need to be made, A Xerox service call may be needed in order to fully repair the copier and warrenty the cartridge.
Nov 06, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Phaser 8560 mfp code error
Thanks for your assistance, but I found out the machine is still under warrenty and is scheduled to be fixed.
LeRoy
Jul 11, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox WorkCentre Pro 416DC
Laser(Polygon motor)problem-$
Jun 22, 2008 | Office Equipment & Supplies
Xerox DocuColor 12 Printer Logo
41 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
