Question about Canon PC-940 Black and White Copier
Copies are coming out wrinkled - always in the same spot.
  • Canon Contributor
  • 185 Answers
You can try to stop the process mid-print. That way if the paper is un-wrinkled before it hits the fuser, then it must be the fuser causing your problem.
The PN for the fuser is FG6-3720-000 and sells new for about $175
Whit
Item, inc.
Posted on Sep 17, 2010
Copies come out severely wrinkled. What is causing this?
If the "wrinkles" are wavy or bubbly in nature then it's likely the fuser. If the "wrinkles" are making bends in the paper then it's likely there is some debris in the paper path or it is catching upon exit.
Apr 02, 2015 | Office Equipment & Supplies
Why is my photo copier wrinkling the paper sometimes?
Check the lower pressure roller at the heater unit for damage.Also see to it that the copies are alligned before it enters the heater unit ..
Aug 01, 2014 | Toshiba 6LH58317000-OEM Estudio 355...
Copier wrinkles copies
It cuold be that paper has too much moisture or you nned to replace press roller bushings alonh with cleaner and fixing film
Apr 30, 2010 | Canon PC-940 Black and White Copier
Wrinkled copies
Fuser unit is about the only thing in this model of printer that WILL cause wrinkling/creasing of the paper. So most likely, yes you are going to need to replace the fusing assembly.
Part# LU0214001K
About a $179.00
The vendor I use is precisionroller.com
Good Luck
Mar 04, 2010 | Brother Multi-Function Center MFC-8870DW...
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
I keep getting error codes
E001 usually means an over-temperature problem. Maybe a fragment of paper is jammed between the upper fuser roller and one of the thermal sensors, or maybe one of the thermal sensors is not contacting the fuser roller correctly. Either of these could also account for your copies coming out wrinkled.
Nov 09, 2007 | Canon imageRUNNER 5570 Copier
Black Spots all over my copies
There are lots of things that can cause this. Inspect the fuser assembly & verify that there isn't any teflon missing from the upper roller & that the lower roller is clean. The spots can also be caused by a build up of waste toner in the cleaning assembly, causing excess toner to be dropped on the copies as they pass under it. The cleaning assembly would need to be removed & cleaned to correct this. The spots are not always in the same place - but are they the same pattern? A worn drum assembly can cause spots that are usually a repeating pattern but located in different parts of multiple copies. Dirty corona wires can also cause random spots & rewiring the coronas would solve that.
Jun 11, 2007 | Toshiba DP2570 Printer
Canon PC-940 Black and White Copier Logo
189 people viewed this question
old marine
old marine
