Question about Microsoft Xbox 360 Console
Sons Xbox 360 shows code E71 what does this mean or the ring of dead...?
  • 4,102 Answers
Hi E71 error code is listed as this fault
E71: Dashboard Error - Error within Xam.xex: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair
try using both of these reset procedures below to solve the problem, you may lose some game data so you need to bare that in mind.
if the below methods dont work then the chances are it has over heated and you will get the dreaded red ring of death.
if you look at the display where the on button is let me know how many lights you have as this is also an error code.
Clear All Installed Game Updates and Console Cache
1. Go to the "system" blade
2. Select "memory"
3. Press Y on the HD symbol
4. Press X,X, Left Bumper, Right Bumper, X,X
5. A message will appear saying: "Do you want to perform maintenance on your Xbox 360 storage devices?"
6. Select Yes
Clear Any Failed system updates that cause the console to error.
1. With the console off, press and hold the sync up button (the small white one)
2. While holding the sync button press the power button to turn on the console
3. Continue to hold the sync button until the Console has booted up completely.
4. During the boot process the console should clear any failed updates, allowing you to use it normally.
let me know how you get on ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 16, 2010
What's the difference between a xbox 360 over heating and the rrod
There are 4 different kinds of RROD on a xbox 360. When the ring of light shows 1 red light, it means there is a minor hardware issue. If it shows 2 red lights, it means it over heated. If it shows 3, it has a major hardware failure and 4 red lights means that you dont have your A/V cables plugged in. Hope this helps.
Aug 04, 2010 | Microsoft Xbox 360 Console
Tip
XBOX 360 Error Codes
There are several error codes you can get with an XBOX 360, the first step to resolving any problem is finding the root cause. The fault codes are primarily shows on the "ring" on the front of your console (this is the ring split into 4 segments that shows when controllers are connected and what player position they are).
  • 1 SEGMENT FLASHING RED - Thisindicates a displayable error code, the specific error code will bebeing displayed on the TV you have it connected too.
  • 2 SEGMENTS FLASHING RED - The console has overheated.
  • 3 SEGMENTS FLASHING RED - This is the somewhat infamous RROD (Red Ring Of Death).
  • 4 SEGMENTS FLASHING RED - AV cable not detected.
If you have 1 segment flashing red indicating a displayable specific error code then you can identify the fault from the list below.
  • E45 - Update Error.
  • E64, E65, E66 - DVD Drive Error.
  • E67, E68, E69, E79 -Hard Drive Error.
  • E71 - Update Error.
  • E72 - Unknown.
  • E73 - General Hardware Error.
  • E74 -AV cable error.
  • E76 - Unknown.
This is a basic overview of all the fault codes for the XBOX 360, for more in depth information on the faults and how to repair them please see my other tips!
Thanks!
on Mar 25, 2010 | Video Game Consoles & Games
When i put a game into my xbox to play it it comes up with this writing in japanese and german and sais error E 71 can you help i no it is not the red ring of death bacause it only has one red bar ???
The error code E71 with one red light flashing on the Ring of Light means that the console is having trouble accessing the memory device which is the hard drive. what you can do is to remove the hard drive and power on your console, if it starts up fine it means you need to replace the hard drive. If it does the same thing without the hard drive, well your console is having hardware failure inside and needs technical repairs, you contact Microsoft and have it fixed for free if it is in-warranty.
Jun 01, 2010 | Microsoft Xbox 360 Arcade
Rings of death
check out this site it will give you what your codes mean.
http://xbox-experts.com/
May 28, 2010 | Microsoft Xbox 360 Console
One red light in bottom right of ring of xbox 360
Hello, I know it's past christmas, but if you still need it fixed I run a repair service called DRAGONF1R3 REPAIRS. We are cheap and fast and completely reliable. If you have any questions e-mail me (e-mail is in my description) I can explain what is wrong and how I will fix it.
Dec 04, 2009 | Microsoft Xbox 360 Console
My sons skate 2 disc has a ring around it. bought a new one and the same thing happened after 10 min of play
Did the Xbox get bumped or moved while game playing?? It could be damaged Rom also ... Youtube has video showing how to dismantle and fix Rom drive
Sep 29, 2009 | Microsoft Xbox 360 Console
My xbox got one ring with error code E79 or E71
Well, E79 and E71 are different things.
The E79 is an error code representing a Hard Drive error. It could be the HDD itself or its a connection problem with the hard drive. Try playing your 360 without it and see what happens.
E71: possibly a dashboard update error, there is no solution at present the console must be sent back to MS for repair. Try resetting your console, or Power Off, remove the HDD if you have it. Reconnect the HDD.
Jul 15, 2009 | Microsoft Xbox 360 Console
Xbox 360 doesn't work
you have the red ring of dead which means your xbox is dead. Call xbox support and if your xbox is still under warranty theyll fix it for you.
May 20, 2009 | Microsoft Xbox 360 Console
Three rings on the xbox 360 are flashing red
MEANS YOUR XBOX 360 IS BROKEN CANNOT BE FIXED
ITS CALLED THE RING OF DEATH
MEANS UR XBOX IS DEAD
Jul 02, 2008 | Video Game Consoles & Games
XBox 360
error code information here:
http://support.microsoft.com/kb/907534
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Jan 10, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
362 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
