Question about Gaggia Titanium Espresso Machine
Ventialtion error Continue to get ventilation error. Buttons do not work once i get this message.Only way to clear seems to be to reset to factory settings and then run hot water then change it to steam where it appears to clear it for a short time.
  • 2 more comments
  • MaraS Jun 11, 2008
    I have tried absolutely everything and I still cannot get rid of the ventilation message on my machine. I have tried running hot water through the steam wand, I have tried restoring the factory settings etc and the problem still remains. The ventation message eventually goes away and then I try and grind another cup of coffee, no coffee comes out and the Ventilatin message comes back.
    Can anyone suggest anything something else?
    Could there be something major wrong with the machine?
  • DenverGaggia Dec 21, 2008
    Ventilation consistently reoccurs after making 2-3 shots. I have done the reset the machine drill, with no long term success. The only thing I can do is shut off the machine 5 -10 minutes and then restart and go through the hot water through the steam wand process to get the "Ventilate" signal to turn off. The process starts all over again. Any new advice would be greatly appreciated
    Very Frustrating
  • jrkennie Dec 31, 2008
    We just got a new gaggia titanium and the ventilate message will not go off ... on the phone with my technician yesterday and he suggested just turning the nob on and off until the water started coming out -- it worked then, but is not working now!! Ugh! I have coffee cooling as we speak with no foam. I can't imagine that I have to replace the water counter as suggested as we've only had the machine for a week.
  • mmcars Jan 01, 2009
    Ventilate message comes up: I have had my Titanium only 2 months and it has been in for service three times now. I have had it! This machine make great coffee when it works but breaks down more often than an old Fiat...........
  • 515 Answers
It´s probably the flow meter in the machine you have to replace, it´s like a water counter, if it not reach the right value then it not reset the ventilate sign.
Make sure to descale your machine regularly, the calcium is a very big problem for the machine.
Posted on Jul 13, 2008
What is a 116-386 error code
Resetting to Factory Defaults / Clearing the Memory
You can selectively clear information stored in your machine's memory.
  1. Press Menu on the control panel until Maintenance appears on the top line of the display.
  2. Press the scroll buttons until you see Clear Memory on the the bottom line and pressEnter.
  3. The first available menu item, Paper Setting, displays on the bottom line.
  4. Press the scroll buttons until you see the item you want to clear.
    • Paper Setting: Restore all of the Paper Setting options to the factory default.
    • Copy Setup: Restores all of the Copy Setup options to the factory default.
    • Fax Setup: Restores all of the Fax Setup options to the factory default.
    • Fax Feature: Cancels all of the scheduled fax jobs in the machine's memory.
    • Advanced Fax: Restores all of the Advanced Fax setting options to the factory default.
    • Sound/Volume: Resets the sound and volume settings to the factory default.
    • Machine Setup: Resets all of the system settings, such as the machine ID, date and time, display language and save modes, to the factory default.
    • Set Report: Clears all records of your faxes sent.
    • RCV Report: Clears all records of your faxes received.
    • Phone Book: Clears the speed dial or group dial numbers stored in the memory.
  5. Press Enter. The selected memory is cleared and the display asks you to continue clearing the next item.
  6. Repeat steps 2 and 3 to clear another item.
  7. ORTo return to Standby Mode, press Stop/Clear.
http://www.support.xerox.com/support/enus.html
May 08, 2015 | Office Equipment & Supplies
I have chnaged the photoconducter but still comes up with error message, how do i clear this?
Hello, follow this steps:
1. Turn the printer off
2. Whilestill off, press and hold SELECT and RETURN buttons
3. Keep both buttons pressed and turn the printer on
4. Continue to hold both until either PERFORMING SELFTEST or CONFIG MENU appears on the display
5. Release buttons
6. RESET PC CNT should now show o the display. If it does not, press left or right menu buttons until it does.
7. Press select buton once. RESETING PC CNT VALUE should show on the display.
8. When the display shows CONFIG MENU again, turn the printer off.
9. Turn the printer on (do not hold any buttons down thi time). Printer is reseted.
I hope this simple steps will be helpfull for you. Good luck!!!
Mar 30, 2010 | Lexmark E342n Laser Printer
How do I set it to factory default settings? When I want to graph or want to do a zoom fit I get a ERR:SYNTAX 1:quit
Seems unlikely that you get a syntax error for both graphing and Zooming. Probably the error is in the function you are trying to graph.
To reset the RAM,
Press [2nd]MEM][7:Reset][1:All Ram][2:Reset] [ENTER]
Calculator answers with Ram Cleared.
Press [CLEAR] button to erase the above message.
Once Ram is cleared, open the [Y=] function editor and at the Y1= line, enter [X,T, theta, n] key or [ALPHA][X], to draw the simple function Y1=X.
If that works, that means your calculator is OK.
Jan 19, 2010 | Texas Instruments TI-83 Plus Calculator
I have an x543 Lexmark printer and there is an error message, I have not been able to clear; 122.05 Service - Fuser Error Any help?
i have an x543dn has a fuser error of 122.03 service fuser error, i just reset the factory defaults in the config menu and it cleared that error, to get to the config menu press and hold the tick button and the right arrow next to it then power up the machine and continue holding these until the menu is displayed then scroll through menu until you get to factory defaults select this then select reset base, hope this helps. Kev
Jan 08, 2010 | Lexmark T632 Laser Printer
Iam sooraj using HTC P400i PHONE MY MOBILE NUMBER +919946324460(PREPAID VODAFONE) I CANNOT USE GPRS IN MY MOBLIE PLS HELP TO BROWSE BY GIVING MANUUAL SETTINGS
This will wipe all the storage (not the sd card) and your device will be reset to default settings.
Hard reset (option 1)
  1. Pull out the stylus.
  2. With the device turned on, press and hold the VOLUME DOWN and CENTER buttons, then press the RESET button with the stylus tip.
  3. Continue pressing the RESET, VOLUME DOWN and CENTER buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to manufacturer default. Press ?VolUp to restore manufacturer default, or press other keys to cancel.
Hard reset (option 2)
You can also use Clear Storage to reset your device back to factory default settings.
  1. On the ?TouchFlo3D Home screen, slide to the Settings tab and then tap All Settings or goto Start and press Settings.
  2. On the System tab, tap Clear Storage.
  3. Enter “1234” and then tap Yes.
Hard reset (option 3)
  2. Turn device OFF.
  3. While pressing the CENTER button, turn the phone on with the POWER button.
  4. Continue pressing the CENTER button until you see this message on the screen:
This works on at least some Verizon CDMA phones on which option 1 will not work.
Hard reset (option 4)
  2. With the device turned off, press and hold the VOLUME DOWN and CENTER buttons, then press and hold the POWER button.
  3. Continue pressing the POWER, VOLUME DOWN, and CENTER buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to manufacturer default. Press ?VolUp to restore manufacturer default, or press other keys to cancel. (works with Alltel touch pro)
Sep 29, 2009 | HTC Touch P3450 Smartphone
How do i hard reset the htc p4600?
  2. Turn device OFF.
Sep 29, 2009 | HTC Touch Diamond Smartphone
Error 906 for mfp t642
  1. Turn off the printer and let it sit for at least 10 minutes.
  2. Then power the printer back on.
    • If the error does not return, try printing a few print jobs. If the error still does not return, continue using the printer as before but keep an eye on it for the next few days. If the error does not return, it may have been an isolated incident.
    • If the error does return, you can perform an NVRAM reset on the printer. Note: Please do this only as a last resort before requesting service. Resetting the NVRAM on the printer will cause the printer to return all customer-defined settings to the factory defaults. To perform an NVRAM reset:
      1. Turn off the printer.
      2. With the printer still off, press and hold the following three buttons: Select, Go, and the right arrow (>) Menu button. All three of these are located on the printer's LCD screen.
      3. While holding the three buttons down, power on the printer.
      4. Continue holding these buttons until you see Performing Self Test, Clearing NVRAM, or Restoring Factory Defaults on the printer's LCD screen. You can then release the buttons.
      5. If the error does not return on power up, continue using the printer but keep an eye on it for the next week or two.
        • If the error does not come back, the printer should be fine.
        • If the error does return, the engine/system board will most likely need to be replaced.
Jan 09, 2009 | Lexmark T642 Laser Printer
Error code 0005FBB6
  1. Turn on the HP All-in-One.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 3 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Then when that's done, try printing, or copying items. If its still not working, check the ink and change those out and this should fix it.
Cloud Striver
If you have further questions email cloudstriver@gmail.com
Dec 15, 2008 | HP Officejet Pro L7680 All-In-One Printer
Hard reset for a HTC Touch Diamond
To perform a hard reset
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
Clear Storage
You can also use Clear Storage to reset your device back to factory default settings and/or format the internal storage.
1. On the Home screen, slide to the Settings tab and then tap All
Settings.
3. In the drop-down menu, select whether to Clear Storage only,
Format internal storage only, or Clear storage and format internal storage.
4. Enter “1234” and then tap Yes.
Sep 14, 2008 | HTC Touch Diamond Smartphone
My Garmin street pilot 3i has stopped receiving satellite reception. It started about a week ago. Since then I've been on the Garmin site and checked for updates, changed the batteries and done a full...
Question: Why won't my StreetPilot i-series device acquire satellites?
Same happened to me - try --> Answer: If your StreetPilot i-series unit is having a hard time acquiring satellites we would recommend ensuring that it currently has the most recent version of unit software and then performing a master reset. In order to update your unit to the current version of software you will need to use the Garmin WebUpdater. Here is a link to the page on our website that has the WebUpdater program and instructions on how to use it:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Once your unit has the most up-to-date software, you may need to perform a master reset. To do this follow the steps below:
  1. Start with the device turned off.
  2. Press and hold the arrow button, wheel, and power button simultaneously.
  3. Continue holding these buttons until you see the message, “Do you really want to erase all user data?”
  4. Once this message appears, release all three buttons.
  5. Select ‘Yes’
Note: A master reset will restore your unit to the factory defaults and will erase all of your favorites and recent selections.
Once you have completed these steps, please place your unit outside in an area where it will have a clear view of the sky. The unit may need 15-20 minutes to initially acquire satellites. Once your unit acquire satellites you may continue normal operation.
solution = solution1description.innerHTML; Last modified on: 02/12/2008
Apr 24, 2008 | Garmin GPS
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
266 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
