Question about General Electric GSH25JSXSS Stainless Steel Side by Side Refrigerator
Our side by side refrigerator's ice maker produces very little ice and the ice melts in the reservoir and drip down where it turns into huge clumps of ice. The temperature in the main part of the freezer is zero, but something is heating the icemaker area.
  • Jim Barr Sep 22, 2010
    We took everything out of the freezer when it appeared not to be working at all. Later, we looked in and the temperature seemed right. The ice maker was making ice and we did not have the huge icecicles that we had before. Do you think that the refrigerator could have solved its own problem or do you think we will have a recurrence?
  • General Master
  • 1,711 Answers
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the electronic adaptive defrost control will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
Now your defrost thermostat is bad it won't turn the heater off when it gets too warm. It's probe sensor is clamped to the evaporator coil at the top to sense the temp..
All above mention parts timer, thermostat in your fridge and all new modern fridges are all included in the so called Main board controller and from the number of issues we have from GE fridges like yours they have replace the Main Board controller and problem solved
However to replace such an electronic board need some experience since is a rather delicate job.
Posted on Sep 16, 2010
  • espressonist
    espressonist Sep 22, 2010
    The defrost thermostat is consist of a temperature probe and a a relay on Electonic control.
    Your problem were that the relays contact stuck for more time and now they open and close normal again. There are more 80% that this will happent again since it is an electrical part you never now for sure.
    However there is also the other 20% that the insident was just for once.
    If it will happent again this will be in the next two weeks for sure. If it does not the freezer will be ok for a long time.
    So just take care not put a lot of stuff in the freezer for the next two weeks which will be atest period.
  • espressonist
    One more thing. You can use a small bowl with ice cream in the freezer during this two weeks since you can very easily recognise if the ice cream have been melt and freeze again by its appearance.
The ice being produced is large clumps that melt and refreeze and stop the auger from turning. I have to use a blowdryer to melt the ice just to remove the bin. Any suggestions?
Can you provide a model number of the refrigerator? Is the water filling too high in the ice maker? Are the top of the ice cubes connected together before the ice drops into the ice bin?
APPLIANCE 911
Jan 04, 2016 | Refrigerators
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
Jennair refrigerator jfc2089htb2
It is possible that the half side of your=> 67006531 Water Inlet Valve that controls water to ice maker is leaking like a dripping faucet and causing the problem. Can you see signs that water is flowing from the ice maker fill tube? The fill
JENN-Air JFC2089HT Water Inlet Valve Thanks John Tripp Appliance 911
Jan 23, 2014 | Refrigerators
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker makes ice, but also drips water
cbscarter,
This may sound strange but you will find that the mold coating is peeling off of the aluminum mold. This causes the water to wick (climb) the loose coating and up over the top, leaking out making an ice clump on the ice maker and clumps ice in the container together. It would be easy enough for the average person to replace the ice make. Due to its age that would be smarter to replace than to repair the old one. It is a Whirlpool part #4317943 and comes with some instructions.
If this helped please rate me good, supertechks
Oct 11, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Ice maker freezes Whirlpool gold
try to remove all the ice in the bucket first and start all over again. the first bundle of ice could be the one making the problem. and then check the cold air vent towards the ice bucket. there should be cold air blowing to it to maintain the temperature in order for the ice not to melt.
after removing all the ice and inspecting if there is cool air coming out towards the ice bucket. let it run and observe it.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice cubes melting then refreezing in clumps
check the flap door to see if it is slightly open letting warm air in
Aug 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Clumps of ice cubes in back of ice bucket
sounds like your just might not be using enough ice and they are defrosting and clumping together.figure your pulling ice from front of bucket the the backs hardly get used espescially in winter your not using as much ice. or ice maker is slightly over flilling water and dripping over rear of unit
Jan 20, 2008 | Amana ARB1905C Bottom Freezer Refrigerator
General Electric GSH25JSXSS Stainless Steel Side by Side Refrigerator Logo
432 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a General Refrigerator Expert? Answer questions, earn points and help others
