I want to scan a form in and type info in certain spaces, and only print out the items I type in. Is this possible
    Guru:
  • 830 Answers
This is not possible with a scanned .jpeg or any scanned format.
You must convert the scanned image or document into a PDF file. You can use this free program to do so.
http://www.cutepdf.com/
Once this is done, you must make the PDF editable. You can do this using this free website.
http://www.pdfescape.com/
Posted on Sep 16, 2010
Need to print different forms on the same printer
In theory, that's what templates are supposed to accomplish. It may require some tinkering to get the desired results but it certainly is worth trying. You may have to consult an Access reference book for guidance.
Jan 16, 2014 | Printronix P7010 Line Matrix Printer -...
Tip
How to install a barcode
<p>Bar codes are images that data can be scanned and read by computers and other devices contain. They usually appear on the packaging as black lines that are scanned when you buy the products, but they can come in various shapes and used for many different purposes. Creating a bar code means to make the image bar code using special software, prints it and attaches it to the relevant item. <br /> <p><br /> <p>1. Surfing the Internet for sites that offer free services for creating barcodes (see Resources). <br /> <p><br /> <p>2. Open the Web page Most of these sites offer the ability to create different types of barcodes. If so, select the one you want by clicking on it. <br /> <p><br /> <p>3. Type the information that is encoded in a barcode field or space provided. Look for a button or link to the bar code and click generate. See the image of the barcode that results when displayed. Right-click the image to the browser's drop down menu and select "Save Image As" to save the image on your computer. <br /> <p><br /> <p>4. Open the barcode image and printing the image using sticky paper. Connecting a bar code scanner to the serial port or USB port of your computer and scan the bar code printed. Check the information sent to your computer to verify its accuracy. Cut out the barcode labels remove the patch and attach it to the item or product. <br />
on Jun 26, 2011 | Computers & Internet
WHEN TRAY EMPTY PRINTS OUT OF OTHER TRAY
The user cannot select a paper tray for a print job from within an application. It is also not possible to configure a default paper tray in the Document Defaults, Printing Preferences, Printing Defaults driver options.
This problem may be experienced with an HP PCL5e, PCL5c, or PCL6 LaserJet printer driver on any of the following Operating Systems:
  • Windows NT 4.0
  • Windows 2000
  • Windows XP/.NET
Typical symptoms of this issues include:
  • Paper tray selection grayed out.
  • Cannot select paper tray, only size and type.
  • Not possible to select tray.
SOLUTION: Perform the following steps to clear the NT Forms configuration.
  1. Go to the Printers folder by clicking Start , Settings , and Printers .
  2. Right-click the printer and go to Properties .
  3. Go to the NT Forms tab.
  4. Click the Clear All button.
  5. To save and exit, click the OK button.
SUMMARY: This is expected printer driver behavior. The NT Forms feature allows a user or system administrator to configure a so-called "form-to-tray assignment" for the printer. When this feature is enabled it is not possible to select a specific paper tray for a print job, or to set it as default, because the system is aware of the specific paper size and type loaded in the various printer trays, which makes the source selection redundant. Some applications or environments may require a "form-to-tray assignment" in order to take advantage of certain features. For instance, in an Active Directory environment, this feature has to be enabled for the operating system to be able to report the available paper sizes in the printer to the Active Directory
Nov 22, 2013 | HP LaserJet 5000 Printer
Brother printer MFC-3240C error message "printer busy"
For some reason when you are not able to scan an item of yours. To fix Brother Printer Error TW006 which has arrived with the scanner when scanning with the ControlCentre 3. When you try solving to scan a document using Brother ControlCenter 3 software but it failed to connect to Brother Printer. Interesting thing is when you attempt to configure the device remotely using same Brother ControlCenter 3 it worked actually without any issues. Initially there can be some form of firewall issue either on computer system however that was not the issues. As you are trying to scan a document from the ControlCenter, the following error message may occur under certain circumstances "No connection to the device is possible [TW006]". Printing is, never possible without problems.
If your device is switched on and ready for operation, this can be a problem with the DNS resolution. Even if the MFC has been installed using fixed IP, as recommended above, the scanner app may use the node name. This leads to this problem under certain circumstances. As the problem, usually comes in the MFC Model of Brother Printer. Connect to http://www.brotherprintersupportnumber.com/
for more clear understanding of the issue.
Follow the steps to troubleshoot the Brother Printer TW006:
Step1: Make sure your computer device is not using multiple network connection
Step2: Reset the Twain Settings using the Twain Reset Tool
Step3: Enable the Windows Image Acquisition service in the registry
Step4: Reinstall thebrother machine software and drivers
The steps mentioned in above section should be sufficient to fix the error code TW006 but in case you fail for immediate and instant you can call Brother Printer Customer Support Number 1-800-213-8289. Brother Printer Support Phone Number 18002138289 Repair Service
Oct 05, 2013 | Konica Minolta bizhub Office Equipment &...
How do I find the directions for playing the game "gardner" on egames 251 games
found instructions on Hard Drive in gardener folder:
Gardner
Object
The object of Gardner is to group like items together to get the highest score possible. You should swap the vegetables that appear on the board to make them form groups of 5 or more plants. A group consists of vertically and horizontally adjacent vegetables. (The plants that are diagonally adjacent aren't considered neighbors).
When a group is formed, you can "gather" it to the basket, freeing space for new plants and getting points. The aim of the game is to get as many points as possible before the board is full.
Controls
The game is controlled using the mouse only.
Left mouse button -used to swap items. Click the first item you want to swap (you'll see it's selected), then the second one. If you wish to cancel swapping, click the item again and it will be deselected.
Right mouse button -used to group items. In this case to gather plants and free up space to continue the game.
Board Menu
Four options included in the menu are:
1) New Game - starts a new game
2) Sound - turns game sound on or off
3) Exit - exits the current game
4) Continue - closes the menu and continues the game
Jul 04, 2009 | eGames 251 Awesome Games Collector's...
I want to increase size of small items to make them more legible
Set your printer to let you Preview before printing. From there, make sure you have the size upped to a percentage that will fill up the entire paper. You can also try scanning forms and such at a higher resolution initially. This will give you a bigger image to work with. Let me know if these are sufficient for your needs or need a different solution.
Jan 11, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
How could i delete a certain info that i've entered in a listbox??
my OS is Win XP, im using Visual Basic 6.0
Sales System is the one Im now working for and I have a difficulty in deleting a certain info.in a listbox..
can i have a sample code on how could i delete info in a four listoxes??
for example, list1 is for item code, list2 for item name, list3 for quantity and list4 for price..
upon simulation..if a click in list1, list2-4 will automatically highlighted also..so if i delete list1, list2-4 will also be deleted..
thank you for future answers..
thank you
Feb 27, 2008 | Computers & Internet
Excell
In Excel, you can import the scan, by importing a picture. You will need to put the scan into a compatible format. Can you open the scan and save it as a JPEG or other format that Excel can recognize? You can then import it, resize it as necessary, and place it next to your data. Then you can select a specific grid of cells as the Print Area, and tell Excel to 'fit' your document to one page wide by one page tall in your Print Setup.
Oct 03, 2007 | Microsoft Office Standard for PC
How do I scan colored paper and still read print? HP Scanjet 8270
First thing to try is just play with all the scan settings to see what gives you the best result - try changing resolutions, type of document, type of output document, contrast, brightness, type of scan. If this doesn't give you any better results, then one of the best ways to do this is to get some plastic sheet of the same or almost the same as the predominant colour on your forms (you can go one step further and make a multi coloured filter if you are feeling creative and your forms are all identical). The text jumps out of the page and most scanners will give you a good scan - just make sure the filter is not too thick/dark. Hope this helps :)
Jun 25, 2007 | HP ScanJet 8270 Flatbed Scanner
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
