Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Help my dishwasher will not fill with water but goes through cycle
  • KitchenAid Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Sep 18, 2010
Cycle starts waters comes in, after about 30 seconds water goes out beeps 4 times goes off
Hi
It would be helpful to know the brand/ model etc.
Usually if the water gets in, and then drains out straight away, the dishwasher thinks that it is either not filling, or over filling. If there are 2 pressure switches, there would be one for fill and one for overflow, the fill one (or the pressure tube to it) would be faulty.
Otherwise, if there is only one pressure switch, it may be a dual switch, in which case it is faulty.
If it is a whirlpool or LG, there may be an issue with the flow meter which checks the volume of water coming in.
Best of luck with it. If there are further issues try to supply more info in your response as while dishwashers all do the same thing, some brands go about it in very different ways.
Adam
May 28, 2013 | Dishwashers
My dishwsaher wont drain water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 10, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
When we start a cycle to wash a load of dishes, it goes through the cycle but doesn't fill up with water. The filter on the water inlet is clean with no blockage.
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
heatman101
Jan 16, 2011 | Dishwashers
The dishwasher goes through the cycles but will not fill with water on some cycles.
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter hen you'll need to replace the water inlet valve assembly.
Please post back for any further assistance.
Daniel
Oct 20, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Dishwasher won't fill on start
Check the following to address this issue.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Neff dishwasher not filling up with water
neff dishwasher will drain water goes in but the top and bottom spray do not work tablet falls in goes through cycle but will not wash. iangas
Feb 14, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Dishwasher keeps tripping electric
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Jan 04, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Brand new dishwasher not working
try this test: add water (one gallon each try) by hand fill and try the cycle again. Continue until light goes out. If light never goes out, then faulty water level switch or wiring. If light goes out, then water inlet valve is stopping too early, but need more info to determine why. Try this test: open door and find the door switch. Then activate the switch and turn on machine to watch water come in. It should not just "dribble" in; try to determine if water pressure is sufficient coming in.
Jun 19, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
56 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
