Question about Acer Aspire 6930-6771 Laptop
I turn my lap top on and after a minute it goes dark. I can hardly see what is on the screen. Somes I reboot and it works fine for hours.
  • 2,567 Answers
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Posted on Sep 17, 2010
We have a Toshiba Satellite lap top. It was working about an hour ago, when we down loaded a BIOS upgrade from 1.4 to 1.5. After the down load and reboot the lap top now has a black screen with no wording....
BIOS updates sometimes cause the motherboard to revert to its default configuration. I recommend that you go into the BIOS setup and examine the Boot Devices and Boot Order to make sure that your hard drive is selected as the first boot device.
Oct 07, 2010 | Computers & Internet
When I move my compaq lap top or type a key too hard
that sounds like a video card error. if you can disassemble the notebook, check for loose connectors, particularly the connector that goes to the screen.
Apr 27, 2010 | Compaq Presario Notebook
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
Monitor goes to sleeep on lap top
Hello, you can try this... Connect your laptop with an desktop monitor throughVGA cable.... then Click on start>> goto control panel>> Double click on Power Option>> Under Power Scheme it should be Poratble /Laptop >> Select Never under System Standbye, Trun off Monitor and Turn off Hard Disk.
Thank you for contacting Fixya support, please rate if that helps!!
Sep 06, 2009 | Relisys RLT1720 17" LCD Monitor
Screen goes black
what do you mean by going dark?
dimming down or going off?
e-mail me djtatty@hotmail.com
Aug 12, 2009 | Computers & Internet
Compaq lap top presario f700 won't do any thing
try taking the hard drive and memory cards out then turning the computer back on without hard drive and memory cards for 1 minute then power it off (unplug it ) then put the memory cards in only then plug cord in turn unit on for 1-3 minutes then power down (unplug it) then add hard drive make sure there is no power going to the computer when adding the hard drive to the unit. at this point do let the unit set for 8 hours then try rebooting it should restore itself. if this don't work sorry there is a limit for what I $hare online.
May 12, 2009 | Compaq Presario 700 470024-192 Notebook
Pavilion dv 1000 won't reboot, stand by nor turn off
I had this kinda problem solved on a Acer 5920 LAptop. The webcam driver was the culprit. Remove the cam driver for the same, the windows driver will take over and then i guess it will work fine. I figure its a driver issue or a TSR program not quitting. If this fails try uninstalling recently addes program or driver.
Jan 05, 2009 | HP Pavilion dv1000 Notebook
Lap top screen
welcome to fixya
i would try this first goto device manger in your computer and find the video card in the list and see if it needs updated if this does not work it might be that the video card might be bad but it sounds like a video card update driver is needed
i hope this helps you out have a good day;:)
Jul 11, 2008 | Computers & Internet
Dell Laptop Screen goes Dim After 5-10 minutes
plase use another RAM in the same machine if the sam e problem will arise..its u r mother board prblem otherwise u r ram problem
Jan 19, 2008 | Computers & Internet
Acer Aspire 6930-6771 Laptop Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
