Question about Bose Lifestyle 48 System
I replaced the hard drive in my Bose Lifestyle 48 sytem and the error coce still appears and I do no think the hard drive is being recognized. The drive is the drive that is specific to bose system. Is there information that needs to be on hard drive for a hand shake connection?
  • 4 more comments
  • dtmet Sep 16, 2010
    error code 802 has been the consistant code, but code 172 has shown up when trying to use upgrade disc.
    Thanks
    Will the software upgrade cancel the 802 error code or is the series of functions that needs to done to clear code?
  • dtmet Sep 17, 2010
    I have the lifestyle 48 I am not sure of manufacture date. I bought it in 04 or 05. Console sotware, FX...con:05/01/06 but that is an update for sure.
    Thank you
    Lifestyle 48 bought in 04 or 05 last update showing on console 06
    I have contacted lucky4lynn2 with more information.
    Thank you
    President:
  • 1,139 Answers
This is a known problem for the Bose 48 system, which is associated with the reading of hard drives in general, it has affected other systems even the Xbox 360. What you can try is contacting Bose who should be able to supply you with a firmware update that may or may not sort your problem. If it does not sort it out then you will more than likely need to send it to Bose to be repaired. Sorry to be the bearer of bad news but I hope you get it sorted.
Posted on Sep 17, 2010
    Master:
  • 497 Answers
Hello, first I need to know which Lifestyle Series you have. (i.e.: III, IV? etc.) The Manufactured Date is helpful as well. I will be able to further help you after you give me that info, ok? Thank You
Posted on Sep 16, 2010
    President:
  • 2,923 Answers
Can you tell me the exact error code? Using the error code might give us a clue on what information we need.
I''ll be waiting for your reply.
Thank you!
  • 1 more comment
  • Melvin Ramos
    Melvin Ramos Sep 16, 2010
    The error code 802 means that the hard drive not being identified. And your decision is correct, to use the upgrade disc should fix the problem. Unfortunately, you've got an error 172. The reason why you've got an error 172 when you tried using the upgrade disc, because most of the distributed "Upgrade" discs were corrupted when they release it in January.
    As far as I believe, if the Bose Lifestyle 48 system is still under the warranty, the manufacturer will replace that because the errors or problems that you've got is a known issue. Please contact the reseller or manufacturer and check with them if they will replace it. If not, ask for an updated "Upgrade" disc that you may use. That should resolve the problem.
    Thank you!
  • Melvin Ramos
    Melvin Ramos Sep 17, 2010
    Sorry, I just opened my fixya and saw your question. Yes, the software upgrade will cancel the error 802.
    Thank you!
Bose lifestyle 48 won't play stored music. Everything else works fine
Hard drive is ****..... impact computers.com hard drive number is MK4026GAX pull out of system and replace look at my other posting for 801 code!!! and dont be a ******** again and buy a bose!! TELL YOUR FRIENDS , FRIENDS DONT LET FRIENDS BUY BOSE!!!!
Mar 19, 2010 | Bose Lifestyle 48 System
Tip
Bose LifeStyle 48 Video Mode
Bose LifeStyle 48 System Video Mode Change
Follow these steps to change the video setting from European to North American:
With the media center turned off, use the controls on its front panel to follow these steps:
  1. Press and hold the Enter button on the media center.
  2. While holding the Enter button down, press the Store button. Selections will appear on the media center display each time you press Store.
  3. When Video appears as the selection on the display, release the Store and Enter buttons.
  4. Use the Volume up and down buttons to scroll through the Video options.
  5. Stop scrolling at the proper selection:
  • For a component connection only, select:
  • -NTSC COMPONENT (in N. America)
  • -PAL COMPONENT (outside North America)
  • For a component connection and progressive scan, select NTSC PROGRESSIVE.
6. With the proper selection made, press Store to confirm the
selection and leave the Video options.
I hope that helps.
_______________________________________
Bose LifeStyle 48 Manual Download
Reset Bose LifeStyle 48 VChip Password
on May 02, 2010 | Bose Lifestyle 48 System
Tip
Download Bose LifeStyle 48 System Owners Manual
Have you misplaced your Bose LifeStyle 48 System Users Guide?
Would you like a digital, searchable, pdf version of the Bose LifeStyle 48 System Owners Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
My Bose lifesystem 48 will not start when i start it up error 802 is showing in the display. I can her some nois (tikking) from the harddisk. i am from Norway but my Bose is from USA .I use a transformer...
Purchase a new bose mk4025gas hard drive from impact computers .com for 100 bucks and install, a monkey can take six scews out, pull back up and slide off top remove hard drive from the side of the dvd player, just pull out remove 2 screws from bottom and then pull off ribbon. install back in reverse order.
Dec 22, 2009 | Bose Lifestyle 48 System
Bose lifestyle fault code 802 hi there- i have a bose lifestyle 48 and on display it reads format unsupported when i try to listen to cd's gut not on dvd's - in addition i am unable to store music into the...
Unfortunately, an 802 error is bad. That means hard drive (HDD) failure. This can happen to any hard disc drive, and there's no way to predict it and no way to fix it from home.
If you even try to troubleshoot it (reset etc), you could loose more data (music you've already stored to the system). If you try to access 'stored' music- the error will continue. Also, every time you turn the system off, it checks your HDD, and will probably cause the 802 or 801 errors to display again.
The "Format Unsupported" message may be related, but usually temporary. The 802 (and also 801) errors mean irreversible HDD damage so it doesn't matter.
Call Bose tech support immediately.. They can repair it for $165 and give a new 1 year warranty. And if it's already under warranty they will repair for free. In either case they will replace your HDD with a new one, and transfer any salvaged music files from your existing drive to the new drive.
May 31, 2009 | Bose Lifestyle 48 System
System does not work
try update cd,,,, i might work..
if its hard drive normally says error code, might be somthing like mother board...
Sep 22, 2008 | BOSE48 - Lifestyle 48 Home Entertainment...
Lifestyle 48 Stuck Error 002
My husband left the power unplugged overnight, and by the next morning everything worked fine. Mystery!
Sep 08, 2008 | Bose Lifestyle 48 System
Bose Lifestyle 38
I believe there is a USB port on the back of the unit. Has anyone been able to connect to it? Can anything be seen of the files on the hard drive?
Aug 10, 2008 | Bose Lifestyle 48 System
Aladinom
Call Bose. It needs a new hard drive. There's a charge if it's out of warrantee, but it is reasonable. Seems like this is a common problem!
Oct 27, 2007 | Bose Lifestyle 48 System
Bose Lifestyle 48 Error code 801
We had this problem. I called Bose, and they reported that the 801 error is a hard drive problem. The unit started squealing while I was on the phone to support, and the guy heard it. Said the hard drive was failing.
$200 to ship the unit to Bose to replace the drive. Wish they had a secret warantee for what seems like a common problem.
Oct 01, 2007 | Bose Lifestyle 48 System
Bose Lifestyle 48 System Logo
601 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
