Spacebar acts as home button..how to solve. - Computers & Internet
  • 570 Answers
Don't worry you can solve this problem yourself by just following the below steps.
First click on start Go to control panel Then look for "Date,Time, Language, and Regional Options" in th control panel Click on the key boards and languages tab and make sure that language is selected as "United States" (English) Click on apply and then OK
Your problem will be fixed then
Thanks. Have a great day
Posted on Sep 16, 2010
My.spacebar.is.not.working
Start up in safe mode, select prompt mode and try if spacebar works, just inoput any text..
If it does works, it's your computer acting up but if not, probably your keybaord is failing and you should buy a new one.
Nov 04, 2015 | Dell Computers & Internet
Why does my delete key act like a spacebar?
There are a couple options:
1. Your keyboard is broken, you need to replace it.
2. Try unplugging / replugging it un and or restarting your computer, that may fix the issue.
3. Your keyboard layout might have changed. If you are using a Windows computer, you can press CTRL + SHIFT to switch between layouts. Or you can go to Control Panel -> Clock, Language, and Region -> Change Keyboards or other input methods. From here, you can change your keyboard layout back to use.
Jul 23, 2014 | Toshiba Computers & Internet
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
Hi my keyboard started working erratically a few days ago. it's an A4tech keyboard. and at first while using photoshop the spacebar stops working then I would have to reset it to have it start working...
It sounds like the keyboard is starting to you can try a different keyboard if you have one and it that works your keyboard is bad. If your other keyboard doesn't work to your port were your keyboard is plugged into maybe going bad, let me now if any of this helps.
Aug 02, 2011 | Compaq Keyboard
I have a mac Laptop and the space button on the bottom of the keyboard is stuck down .. can this be fixed?
It is tricky to repair the space bar. It has a plunger in the middle and is held in place by tension clips. The tension clips are what make the spacebar pop back up. Usually one clip comes loose and the other side still bounces. If the spacebar is stuck down with no bounce, I would check to see if there is something wedged under the spacebar. Get a can of compress air and blow under it, hopefully this will release whatever is under there. Only take the spacebar off carefully without jerking it upwards. If it breaks the clip holder at each end, you will need a new KB.
Good Luck.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 31, 2011 | Apple Computers & Internet
When i press spacebar my search results page appears
Keyboard replacement solved the problem. In my case it was a faulty Logitech keyboard. It seems that Spacebar is acting as F3 and Space the same time.
Feb 04, 2010 | Logitech 967437-0403 Keyboard
Onmydelllaptop,thespacebarwillnotspacenormove
The rubber plug below the spacebar button is faulty.The button needs to be removed gently and the rubber plug below it which touches the board below should be cleaned.If this does not solve the issue the rubber plug below the button needs to be replaced.Its a common problem.
thanks and please do not forget to rate the solution.keep updated.
May 19, 2009 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Spacebar.quit.working.
Try to reseat the space bar again.
Feb 18, 2009 | Sony VAIO RA710G...
Sidekick lx spacebar
Go to:
http://www.fixmysidekick.com/sidekick-lx-or-sidekick-2008-space-bar-not-working/164/
Or just read this...:
sidekick2008spacebarpicture.jpgIs the space bar on your Sidekick LX not working when you are trying to text or in AIM? Do you have thesame space bar button problem on your T-mobile Sidekick 2008? Does the Sidekick spacebar work in other apps though?
If so then this fix is for you.
1. Open the AutoText & Spelling screen. From the Jump screen, press the MENU button, then select Settings > AutoText & Spelling.
2. Uncheck the following settings:
    • Highlight misspelled words
    • Auto correct spelling
3. Exit out of the settings screen and try it out.
Hopefully, this will have solved your issue.
How to check for misspelled words with these two options unchecked?
Run a manual spell check on T-mobile Sidekick: To run a spell check while in a text field from any Edit Text submenu, or by using the keyboard shortcut by pressing MENU +S.
Dec 19, 2008 | Sharp Sidekick LX Smartphone
I have a sony vaio pc and the spacebar has broken, can I reassign any of the keys to act as the spacebar?
No, that is hard-coded.
You should be able to purchase a replacement keyboard quite inexpensively on ebay
Sep 11, 2008 | Sony Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
