Question about Vacuums
I need instruction on how to replace the drive belt.
  • 32 Answers
First unplug the device...depending on the model you have there are two screws that hold the cover onto the unit. sometimes they are hidden behind the rubber wall guard and sometimes they are hidden in the random designs on top or even the bottom of the unit. you unscrew the screws (usually 2) and remove the plate. you should be able to see the drive belt now, remove and replace with the new one. (it would be a good idea to clean hair etc out while you are in there :) ) make sure it turns freely and replace the cover, screw it in. vacuum to your hearts content
Posted on Sep 16, 2010
Replacing the belt
this link is for the manual it will give you full instructions on belt change
http://uk.bissell.com/images/UserGuides/3750E_1007.pdf
Dec 28, 2012 | Bissell 3750 Lift Off Bagless Upright...
Belt drive not working. Won't turn beater brush.
You need to replace the belt. Here is the belt you need and the manual which has instructions:
Dyson DC07 Belt and Manual
Jan 09, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Brush not turning
That is usually caused by a worn, stretched or broken drive belt. Here is a link to the replacement belts you need and to a manual that you can view which has instructions. It's really simple.
Dyson DC07 Replacement Belts and Manual
Nov 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
The belt broke
You need to replace it with a new one. Here is a link for the instructions on how to change the belt and a link for the belt you need:
DC07 Belt Changing Instructions
Replacement belts for DC07
Nov 15, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The brush is not working anymore
Your drive belt is probably broken. They usually need to be changed every 6 to 12 months. If you haven't replaced the belt recently I would try that. You can get the belts you need through this link and also view the manual which has step by step instructions on how to change the belt. hope this helps!
http://www.vacbelts.com/bissell-lift-off-revolution-pet-vacuum-belt-.htm
Oct 25, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
I need to replace drive belt on dyson dc17
Here is a link to the belt you need and a manual you can view which has instructions:
Dyson DC17 Belt and Manual
Jun 08, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Changed belt, now its not working
need schematic of machine
replacing the brush drive belt
a item that looks like a valve dropped out and i need instructions as to where it belongs
Jul 04, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
The belt p/n 0100623 broke - need instructions on how to replace it - we have Bissell ProHeat Powersteamer
I just replaced mine last night. 1) take off the top belt cover. 2) take the water and cleaning solution tanks out then lay the unit on the side so the bottom of the cleaner is facing you (water and solution may leak out so you might want to do this on an old towel). 3) On the same side of the machine as the belt cover but on the bottom you'll see an orange piece (at least it is on mine) that is held in with one philips screw. Take the screw out then slide the orange plastic piece out (might need a pliers to help). 4) there is a black cover over the brush belt that has a tab on it. Pull on the tab and the brush roller on that side will come out of its place. 5) You'll see a cogged belt that drives the brushes. Just slip that off the drive on the machine. You don't need to take it out completely - just off the drive. 6) Slip the new belt (p/n 0100623) in and on to drive. It goes "inside" of where the cogged belt goes. 7) Slip the cogged brush belt back on. 8) push the brush roller and black belt cover back into position. 9) slide the orange plastic piece in place (make sure the belt cover is held in place by it) and screw it back on. 10) flip the cleaner so it is on its wheels again. 11) pull the new belt over the metal drive and manually get it kind of centered. Make sure it isn't touching any protruding plastic. 12) plug in the cleaner and quickly turn it on and off while looking at the new belt. You should see it self center. 13) put the top belt cover back on 14) insert water and cleaner tanks. 15) get to work.
It'll take less than 10 minutes to make this fix (less than 5 probably).
Jun 19, 2008 | Bissell Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
