Question about Maytag Neptune MAH5500B Front Load Washer
Trouble code E 3
Washer has been performing perfectly for the past year plus. I am aware of the problems Maytag has been having with this machine. Especially touble code "E-3". Within the past week my washer has begun to show this code very frequently.
Can you direct me to any/all solutions available?
Thank You
Charles Sahlin
  • 1,029 Answers
Check the blower rotational speed if it drops below 500 rpms,during a cycle it will effectall outputs and give error E3
the E3 error code also appear if there is a user interface or software mismatch.or when a component on the control board has failed. so check the board and Replace defective component.or the whole control board
Posted on May 17, 2008
  • 13,433 Answers
By Samurai Appliance Repair Man
Error code E3
There have been problems with the motor wire harness connector on these washers. The problems are either a loose or bent terminal in the molex connector.
Unplug the connector and tug on each wire. If a wire comes loose from the plug, bend the locking tab up. If a locking tab is not properly seated in the plug connector, the terminals will not fully engage as the connector is plugged into the motor.
Another manifestation of this problem is that one of the terminals may be bent. Inspect the terminals on the motor side of the connector. Straighten any bent terminals if they exist. Recheck the harness side of the terminal block if any bent terminals are found. Bent terminals can indicate a problem with the locking tab inside the plug.
My Maytag MAV6000 washer leaks intermittently. In the past 3 weeks it has been used many times but has leaked 3 times. I removed the front panel to look at the pump and hoses and put the washer through a...
Realistically, a 10-year old Maytag is nearing the end of its usual life. The pump may be leaking at random times during a wash cycle. If you put 50% of the cost of a new one into repairs, it is time to thing seriously about replacement of the machine.
Apr 26, 2017 | Maytag Atlantis MAV6000 Top Load Washer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer - Machine is 5.5 years old just started displaying the "dc" error message. Move clothes around but takes 3 times plus to get the load to finish. Serviceman was not...
Hello weirc215
Thank you for posting your model number.....so many folks post non FAV6800A/FAV9800A issues in this forum.
It is a Clutch issue. The One-Way Roller Clutches in the hub of the clutch are not locking up in Spin cycle. Most times you can get away with a low cost Clutch Maintenance.
See my Clutch Maintenance Post for the details….. Clutch Fix Post It’s posted under my old forum nickname dh1200s.
If you or someone you know have very basic mechanical skills you can do this and save your machine and you $300+ over calling in a repair company that may not know what the issue is.
I will help you or whoever will try to do this. Can you give me the 1st two digits serial number located here?
Jan 31, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Matag washer travels across the floor.
Velcro is a silly idea, what you want it to rest the washer on a rubber membrane as this will absorb all vibrations and kinetic energy thus stopping it from moving.
http://www.gkacoustics.com/anti_vibration_rubber_mats.htm this place sells them (aswell as other places) Neoprene Rubber and MLC Closed Cell Rubber is your best bet.
Hope this helps
Jan 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune. 10 years old.Slow drum rotation
The problem may be with the bearing of the washing machine is spoiled due to leak please try to change two inner bearing along with the washer it will work for another ten years
Dec 24, 2009 | Washing Machines
Should I buy a gently used Maytag dependable care plus model# LAT8824AAE washer? What's the reliability of this machine?
Maytag makes very dependable machines. They are fairly easy to repair and parts are easy to find. If I was in the market for a used washer, a Maytag would be my first choice. Since its used there is no guaranty that the thing isn't going to need repairs. If you can see it run through a cycle before buying it would be a plus. My first washer was a mid seventies model Maytag. I had two minor repairs twice in 15 years and its been working ever since at my buddy's. I hope this helps you.
Aug 27, 2009 | Maytag LAT3600A Top Load Washer
Maytag MAF1200AAW
WASHER MAGIC is the revolutionary product specifically formulated to safely and effectively clean the family washing machine. Top loading machine use whole bottle. Front loading use 1/2 bottle. You may rub Washer Magic on with a rag to eliminate odors.
Why Use WASHER MAGIC? Every time you wash your clothes, hard water and detergents causes lime scale and rust to build up inside the tub, pump and hoses. This build-up reduces the ability of your washing machine to perform. Mineral build-up acts as an abrasive increasing the wear on your clothes. The result: your clothes are not as clean as they could be and wear out sooner.
If you are unhappy with the way your clothes comes out of the wash, then WASHER MAGIC may be the solution you have been looking for. Only WASHER MAGIC can restore the family washing machine to the way it performed when it was new. Use once a month for optimal washer performance and to keep control of trouble causing build-up.
Aug 04, 2008 | Washing Machines
Problems with MAV9501EWW Washing Machine :(
your seals and bearings are bad do you wash a lot of sandy gritty clothes if you do that is the cause of the problem
Jan 19, 2008 | Maytag Atlantis MAV9501E Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
481 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
