Hi.
I dont know either *********** board recognize dvd/cd if not do all.
Set bios save as default .To set the bios follow the link=
http://www.computerhope.com/issues/ch000192.htm after configure press F10>yes.
If it is same, then change the dvd/cd cable.
If can not read any cd
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is noharm in trying
If you take a little riskcan solve .
follow the instruction: Don'tpanic its very simply.
1. When running yourpc ,
open the drawer.>
2. switch off the acpower
3. remove powercable & sata or pata cable
4. remove all thescrew from the back side
5. press clip toopen the font panel
6. reverse thecd/dvd rw
7. just remove thecover
8. clean the
optical lance
9. http://www.howtodothings.com/computers/a3631-how-to-clean-a-cd-rom-drive.html
10. use
a little ( not much )oil place on two
steel shaft
11.cover all the equipment
12.now you can fit to your pc
Ifit does the same problem please change the cd/dvd rw because the lance hasdefected.
Hopeit will help you.
