Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Dryer not spinning
I have a stackable Maytag. Everything is working fine other than the dryer is not spinning. It still heats up, but the clothes are not drying, due to the spinning malfunction. Is there any way to troubleshoot the problem?
Thanks,
John from Houston
    Genius:
  • 1,224 Answers
Ok this sounds simple
if the dryer stopped spining there are 4 things to look at
1 the belt for dryer if this snapped the drum will stop spining
2 the dryer wheels these ware down and break off this is what helps keep dryer in a spin straight
3 this is the crucial one the motor siezed up from lack of appliance oil not being added to a regular maintenance
4 the guages has stopped working but i doubt this if it still keeps a timer going round this would not be it you dont have to run dryer to test guages just set guage to a time and see if it rotates with the time on it
the belt you can check your self by pulling down the dryer pan that will show bottom of dryer with belt if its a belt simple maytag can come out and do a replacement and maintenance on the spot
i hope this helped seeing im not there to actually see in person whats actually wrong
Posted on May 17, 2008
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
I have a stackable washer/dryer gas maytag. Purchased around 17 years ago. The dryer is not drying clothes. Gas is powered fine and it is heating up. The cycle seems shorter than normal
The problem with it not drying is most likely going to be a worn out blower wheel thats slipping and not moving the warm air through the clothes to dry them properly. Always a pretty good sign the blower is slipping is,if you hear a rumble noise from the dryer at start up and also that same rumbling noise when the power stops. So if you hear it at start up...wait 30 seconds and open the door and listen for the rumble noise as drum stops. also you can check where the vent exits the house and see if their is air flow when the dryer is running.
GENE
Aug 19, 2011 | Maytag LSE7806A Top Load Stacked...
My Maytag LDG7600AAW dryer is not heating.
did not have Maytag dryer but clothes dryer filters and duct work to exterior were blocked.Cleaned and everything was fine
Feb 21, 2011 | Dryers
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Maytag stackable dryer
STACKABLES ARE NOT KNOWN TO HANDLE TO HANDLE HEAVY LOADS.TRY PUTTING LESS IN THE DRYER.
Mar 07, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Jul 06, 2008 | Maytag LSE7806A Top Load Stacked...
My dryer in my stackable washer/dryer quit
I Think the belt got binded on the motor spindle and the burning smell was the belt burned through by the spinning spindle
Mar 23, 2008 | Dryers
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
302 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
