Question about Miller 903777012 SPECTRUM 2050 PLASMA CUTTER
Cup light is on, nothing happens when trigger is pulled
Pull trigger and nothing happens
Are you sure you have the safety key attached. Make sure power is on at receptacle.
Feb 09, 2014 | Ridgid Ms1065lza Saw 10-inch Compound...
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
Drill intermittantly responds when trigger is pulled. (mostly nothing happes or it sins for a second or two) Light does not light up. Batteries are fully charged.
Sounds like a bad switch. I have seen that happen when a switch fails. It may work at times but not all the time and often it no longer has any variable speed to it.
Jul 14, 2011 | Ridgid Drills
I have a dyson dc16 and when i pull the trigger all three lights come on but nothing happens from that point?
it needs charging . and if the lights dont light when you put it in the charger somthing is wrong with charger or battery
Oct 23, 2010 | Dyson DC16 Root 6 Bagless Handheld...
Lincoln 3200hd. welder,when power switch turns on, the fan comes on, but when i pull the trigger on gun to start to weld nothing happens the wire does not feed. i am not sure what is happening
open the area were the role of wire is and check when trigger pulled if any action to feed motor. [wire might be stuck at end, or there usually is a small fuse in that area for feed motor]
Dec 04, 2009 | Lincoln Electric K1170 AC-225 Stick Welder
No pressure when pulling trigger, trigger sticks in handle body
if air sound comes out when you press trigger your pressure regulator pin is stuck-oil gun and attach hose repeate until pin frees or remove pin and clean with brake kleaN oil and replace
May 31, 2009 | Ingersoll Rand 236 1/2" Air Impact Wrench
Miller 903777012 SPECTRUM 2050 PLASMA CUTTER Logo
42 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
