Question about Life Fitness 95Se Stair Climber
I have a life fitness 95si and it won't power up or give any resistance...what do I do?
  • 3,083 Answers
This sounds like a power supply problem, and you can order one at either of the following sites:
http://www.fitnessrepairparts.com/equipment/Select/15371/Life-Fitness/95SE
and:
http://www.sportsmith.net/productsearch.aspx?dsNav=N:6-10686&dsContent=Nea:True.
If you're handy with a voltmeter, you can verify if the power supply is the problem. Otherwise, it could be a switch or wiring or wiring connection problem.
Start with the power switch and power supply.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 16, 2010
Tectrix climbmax
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
You can find some of the information on these machines with the link above. Without knowing your model and serial number, the below link is to one of the manuals we have available on our Website. http://www.sportsmith.net/images/product_support/tectrix/Manuals/P1303103%20-%20Climbmax%20Personal%20Manual.pdf
Apr 18, 2014 | Exercise & Fitness
My 95si will not turn on
You may want to start with checking the voltage output from your power supply. I am attaching a video of how to use a multimeter.
Jan 03, 2014 | Life Fitness Used Stepper 95Si
Life Fitness X3 does not turn on. So I can't set resistance nor intervals with console. Plug was checked and is fine.
follow this steps and fix it.
God bless you
  • Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
    Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
  • 2
    Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
Sep 30, 2013 | Life Fitness X3 Elliptical Cross-Trainer...
Life fitness crosstrainer 9500 HR just shut down few second after start
see the video and fix it. This happen because the lack of maintenance schedule.God bless you
Apr 04, 2013 | Life Fitness Crosstrainer, 9100, 9500 Rear...
Life fitness resistence
see the video and proceed according .God bless you
Apr 04, 2013 | Life Fitness 9500HR Next Generation...
How do I remove the pedals on a 8500 life fitness recumbent bike
Using a wrench, you remove the left pedal as you would loosen a normal, left hand threaded bolt. The right side is a reverse thread and would need to be loosened in the opposite direction.
Feb 20, 2013 | Life Fitness Nut Lock, Cranknut, Lifecycle...
My treadmill life fitness 9100HR won't start
Have you checked the drive belt @ the motor, if it is OK then check the fuse, if it is ok then the brushes in the motor may be worn out
May 04, 2012 | Life Fitness T3 Treadmill with Advanced...
Life Fitness 95Se Stair Climber Logo
423 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
