Question about Blanco 157-075R-WH Elan II Kitchen Faucet White
Blanco 157-075-WH: Any new faucets in stock? - Blanco 157-075R-WH Elan II Kitchen Faucet White
    Brigadier General:
  • 3,006 Answers
Certainly not at FixYa as we don't supply any physical goods of any kind.
Just entering the term Blanco 157-075-WH on Google immediately produces results, such as this one, but it all depends upon where in the world you are. FixYa is a globally available website so without knowing which part of the world you live in it's difficult to suggest a relevant stockist.
Posted on Sep 16, 2010
Cartridge replacement
Should be able to order new one at any plumbing supply. Remove handle, then with pliers pull out old cartridge, and push in new one till it seats, place handle back on.
Oct 25, 2013 | Blanco 157-013-CR Harvest Kitchen Faucet...
Leaking blanco single handle faucet with sprayer
minarl deposit bildup in the handol best to just replace the sprayer any hardwer store hose is still good only sprayer head needs replaced comen threds
Mar 11, 2012 | Blanco Plumbing
My new Blanco sink faucet does not provide much water pressure; is there a restricion part inside the faucet head that can be removed to allow for more pressure?
No you can not remove them, if you try to dill out the water saver you might do damage to the faucet.
Sorry next time you buy check the G P M flow rating.
Best of luck Rich
Sep 05, 2011 | Blanco Classic Single Handle Faucet with...
Have a Blanco single-handle pull-out faucet with single-stream and spray option. Spray option can be turned on and off with a twist switch on top of the faucet. Our faucet is now stuck on spray option and...
Unscrew the part where the water comes out and remove the enterior parts paying close attention to how and the order in witch the come out so you can clean everything good and put it back together and pay close attention to the twist switch and how it operates. This shought fix the problem your having.
Jun 30, 2011 | Blanco Classic Single Handle Faucet with...
I have never done it before, so I need step by step directions in removing an old blanco single handle faucet and now putting in the new one
Turn your water supply off to the existing faucet.
With a crescent wrench and plyers remove the supply tubes from the shut off valves.
Unthread the sprayer hose that is attached to the brass connector under neath your faucet in the cabinet.
Unthread the lock nut and fastening plate which is on the same brass fitting as your spray hose.
Remove faucet from the sink.
Reinstall the new faucet in the reverse order.
Feb 25, 2010 | Blanco Classic Single Handle Faucet with...
Blanco harvest kitchen faucet with pullout spray low flow rate
Check fine filter at tip, probably blocked, got caught with same thing myself recently!!!
Jan 26, 2010 | Blanco Harvest Single Handle Faucet with...
My blanco kitchen mixer does not swivel. It is stuck in one place
You need to remove the handle and then remove the top cover to the housing. After the cap is removed you can pull off the spout. It probably needs new washers. You will see what you need to fix it at this point. Just remember to turn off your water before doing this.
Mar 22, 2009 | Blanco CLASSIC 1 Handle Pull-out Spray...
Blanco 157-075R-WH Elan II Kitchen Faucet White Logo
164 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
