Question about Belkin Computers & Internet
Why my wirless internet is so slow and gets connected to more than one network....it is always been the problem.could u advice what shall i do to make my internet wirless fast and block other network connection????
Need help email me drummernick2002@aol.com live help thx nick
ya set up password on yous update driver run cleaner ccleaner
Posted on Jun 08, 2008
Tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Hi i have realtek RTL 8187 wireless adapter, and when i watch in my antenna managing program, connection is quality and signal streght about 80% THATS GOOD. always was good connection, but now yellow and...
somebody is accessing your wireless network and getting free internet service from you unless you had setup a wep security! if you have an un-secure network then anybody with a wireless adapter can access your network and access your internet free and drag down the speed of your internet connection.
however, if you do have wep enabled and there is more than one computer connecting then this will slow your connection down as well. please remember that there are some games and gaming sites that are bandwidth hogs and will slow down other computers connection on the same network. also watching streaming videos and gaming at same time can slow down connections as well.
Aug 25, 2011 | Toshiba Realtek RTL8187B Wireless...
Every time i try chart on facebook the message i get is failed to connect to facebook chart
Is your connection speed slow or fast . In slow connections this problem is very common . In this case i advice you to get a faster connection .
If your connection is fast , then the problem is with your Internet browser or you don't have Java script installed on your PC .
If the problem is with the browser , then i advice you to uninstall it and reboot and then install it again and reboot and problem will be solved
and i advice you to have more than one browser installed on your computer . I already have three [internet explorer , google chrome , firefox ] .
If the problem is with jave sript , then go to www.java.com and install java from there and problem will be solved .
good luck .
rate please !
Feb 02, 2010 | Facebook Social Network
I have a laptop computer, and a wirless no internet
your internet gateway (the modem)if you have att you must turn on the the wireless inside your 17XXhg gateway modem if you don't then you have another system I gave you a example to clear your question if you need more help please repost with more information
Jan 14, 2010 | Computers & Internet
Where is the SSID on my at&t router and what is the WEP Key? I am trying to connect my PS3 wireless up.
ssid is service set identifier usually sniffer software will find them. the wep wirless encription protocall is a key number usually found on a sticker on the bottom of the wirless modem, router .
Jul 09, 2009 | Acer Computers & Internet
Which will be good to me????
wee if you do not have the wireless card you have to connect your desktop with wired connection in order to make it online but is you have the router in a different room you can also go for the wireless pci card that you can connect in your computer to use your desktop computer wirelessly...ok
Apr 29, 2009 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Need help
you reaqaly dont nned to pay for anything just get internet connection via wirless network (linksys,wireless router). that gives you wireless internet for computer, video game consoles and more. the router is bout 60-100 dollarz
Feb 18, 2008 | Nintendo Wii Console
SSID and WEB KEY number
i WANT TO CONNECT MY PS3 USING MY WIRLESS ROUTER BUT DON'T KNOW HOW TO CONNECT IT CAN YOU HELP
Jan 04, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
82 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
