Question about Maytag Refrigerators
We had a buzzing noise coming from fridge for a couple of weeks. Now it's not cooling at all, so we unplugged it for now. What could be the problem?
  • Maytag Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 17, 2010
3 Suggested Answers
  • 15 Answers
SOURCE: My ge profile fridge won't stay cold. the fridge is at 45 deg.
First things first - pull the fridge/freezer out from the wall, and look at the bottom.  You should see a metal coil somewhere - it probably needs to be cleaned.  Next, somewhere around the compressor (the big bulky thing in the bottom of the freezer) should be a fan blowing on the coil - make sure it is running.  That MIGHT have been the buzzing noise you describe - dirt on the fan blades or the fan hitting something.  Additionally, you can check the fan on the inside of the freezer - if it is stuck and/or not working, the air won't circulate properly, and you'll get pockets of different temperatures in your freezer.
Best of luck!
Posted on May 26, 2009
Macmarkus
  • 2605 Answers
SOURCE: fridge is running constantly, but the unit is not
Welcome to FixYa.
I suspect by your description the fridge either has a faulty overload protector or the compressor itself is seized. Hence when the overload reset's the fan starts ( as it should when the compressor runs, however the freezer fan runs constantly ) however the overload then trips and the fan stops while the compressor never starts, thus not cooling.
If you feel like you can trouble shoot further I`ll try to assist you or you may decide to call a professional appliance technician.
I don`t know the age of your fridge, but I should mention...
** Most of the Whirlpool fridges have 5 to 10 years sealed system warranty which would include the compressor but not the electrical starting devices i.e., the overload & relay. Check your owners manual, it is the ultimate authority on warranty no matter what anyone else tells you according to Whirlpool/Maytag/Amana.**
If you have a multi- meter you can check the compressor to see if the windings are ok.
**First, Unplug the fridge**
Remove the panel at the back down at the bottom. This should gain you access to the compressor.
On the side of the compressor will be the start relay/overload assembly such as this image...it may be enclosed in a black plastic cover as well.
Pull off the relay & overload and you'll see 3 pins in the form of a triangle...
With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin.
You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms.
On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good !
If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 starter kit.
i.e.
The above package contains info and hardware on how to connect it.
NOTE : the HS410 ( 3 in 1 ) should be considered just a temporary "fix" as opposed to an actual "repair" in should not be relide on for long term reliability or safety, but rather the factory replacemnet part 8201786... i.e. macmarkus_95.jpg The above start device kit contains instructions on "how to" install kit. Hope that help`s move you forward if nothing else. If so please take a second and rate the reply and a testimony to your inquiry you received here at FixYa.
Thank you and good luck.
Regards,
Macmarkus :)
Posted on Dec 02, 2010
My maytag Wide by Side refrigerator started making this buzzing noise coming from the freezer section every few minutes and now it no longer cools.
It is possible that the door was not closed tighly, so the humidity built up in the duct line and the low temperature from the freezer make it turned into ice causing the clogging. The Buzzing noise turns on due to the sensorsomewhre along the disigne path. Unplug the fridge for a day and a half so the the ice in the duct line could melt down then when you turn on the sensor won't turn on the buzzing any more. Good luck.
Jul 04, 2009 | Maytag Freezers
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Best of luck!
May 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge is not cooling
A failed start relay could be the culprit. The relay/overload assembly (12555902) and the run capacitor (C8931612) should be replaced.
Be sure to unplug the refrigerator prior to service.
Apr 27, 2009 | Maytag MBB2256G Bottom Freezer...
Candy fridge freezer
it should come back after about 20 mins only and should cool back after about 10 mins.
i'm afraid the buzzing sound could be coming from your compressor which can not start. the over current relay is tripping off after 20 seconds to prevent the compressor from burning up.
i suggest to unplug the ref, let it cool for 1 day, re plug it after a day and observe the compressor if would run.
if the buzzing sound is still there and the unit is no longer cooling, then the compressor is not running.
check the relay of the compressor. it could just be the relay.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Candy CPCA240FFK Bottom Freezer...
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
Refrigerators Logo
63 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
