Question about Philips Avent® Scd510 Dect Baby Monitor
1- The baby unit doesn't work on the mains only 2- The parent unit is on the charger for a day now and still doesn't open
  • 21 Answers
Your issue #1 seems like a power adapter issue. Please swap the sender and receiver adapter and see if anything changes. Mark them with a sticker or felt pen before you do this because they probably are identical.
Your issue #2 seems like you have defective batteries, although I don't understand 'doesn't open'. The receiver uses standard NiMH cells that can be reached through the back battery compartment. You could swap them out and test.
If the set is still within warranty I suggest you take it back. Within the warranty period you usually get a replacement.
I hop this helps.
With kind regards,
Babycare.nl
Erwin de Raad
Posted on Sep 16, 2010
I have tomy classic baby monitor from a year now, from few days parent unit is beeping continiously, have checked connection and evrything and even the green light does goes red
The unit may have a back-up battery installed that is low on charge. Replace the back-up battery. The unit is probably still working because you have it plugged-in.
Sep 17, 2014 | Baby Gear
MPB33 motorola baby monitor
For better assistance you can contact our Baby Monitors specialist.
http://www.motorolacordless.us/
Best Regards,
Katy
Motorola Support
Dec 27, 2013 | Motorola Mobility MBP36 Baby Monitor
The sound suddenly stopped working on the parent unit of my MBP36 baby monitor even though the volume is turned up to its max. Is there an easy fix for this? I have only had it for 5 months and the picture...
Okay, a couple of things.
This speaker issue seems to be a common problem, and I believe it most likely occurs due to rough handling of the unit. Although it seems to be fairly rugged, it should be treated gently. In general, I would only handle it as much as needed, and be careful when setting it down, and make sure it doesn\'t get dropped.
With that being said, the unit can be opened, however doing so will break at least some of the "snaps" that hold it together. If it is out of warranty and you need to get into it, this is a necessary evil.
Step one: Remove the battery cover (one phillips screw) and battery. There is a second, smaller phillips screw that also must be removed.
Step Two: At this point, you are ready to separate the unit. Using multiple flat head screwdrivers, pry the unit open (starting on the right side when looking at the unit from the front) then "wedge" the pried open area with a second flathead screwdriver as it will naturally want to close back up. Continue working your way around the unit, being careful not to crack the screen. You will break some tabs along the way, but I see no way around this as they are not visible to try and release them any other way.
Step Three: Once you have separated the two halves of the unit, the power button will have fallen out. This is okay as it will slot back into place when you reassemble the unit. Just set it aside and do not lose it.
Step Four: I do not know the exact failure mode of the speaker, however you will find that it is apparently strongly secured in the housing with an adhesive (epoxy or some sort of resin) and if you had to remove it it would be difficult and not very fun.
MY SOLUTION: I hooked the battery back up and turned on the music feature, which should play music from both the camera and the parent unit. In my case, I found that tapping hard on the speaker (it took more force than you would think) would cause the music to momentarily play. I found that wedging a screwdriver between the plastic housing and the speaker body would make the speaker play. I used a small nail (like a trim nail for small trim) and wedged it between the speaker and the housing, then trimmed off the excess of the nail.
This solution is not ideal, but it was relatively quick and worked to keep the unit functioning for now. I imagine that there is some sort of connection that has failed internally in the speaker, and that wedging it has (at least temporarily) reformed the connection. I imagine that a new speaker could be installed with some work to remove the old speaker, and then a new one soldered in and glued into place.
Once I got the speaker working, I disconnected the battery and carefully replaced the power button, then the two halves simply snapped back together. I replaced the screws and reinstalled the battery, and all has been working as it should. The case does show some damage from my prying, and it doesn\'t fit as tightly as it used to with the broken snaps, but it does hold together and doesn\'t have any issues in normal use.
In all, it certainly beat buying a whole new unit, especially since it was working just fine other than the sound. Good luck!
Sep 28, 2013 | Motorola Mobility MBP36 Baby Monitor
MBP36: speaker does not work
Good day,
You can contact baby monitor tech support specialists
Http://www.Motorolacordless.us
Emilio
Motorola Support
Mar 26, 2013 | Motorola Mobility MBP36 Baby Monitor
No sound on parent unit
Posting this all over, common issue...
Nov 05, 2012 | Motorola Mobility MBP33 Baby Monitor
Tomy baby monitor srv 400 instruction
Page 1 SRV Series (Model SRV400) Q & A'sQ. My Parent and Baby (Camera) Unit have lost contact, what should I do?A. It may be possible that the encrypted code pairing both units has corrupted, to reset the code please
follow these instructions;
1. Place the Parent Unit next to the Baby Unit.
2. Activate both Parent and Baby Units by pressing their respective ON/OFF buttons for greater than
2 seconds.
3. Press the Mode/Enter Key to enter the Parent Unit's Main Menu screen.
4. Using the four-directional Navigation Keys, select the 'Add/Remove Baby Unit(s)' option and
press the Mode/ Enter Key to confirm your choice.
5. The current status shall now appear, showing all four Camera Units shaded grey;
6. To reconnect the Camera unit to the Parent Unit, using the Parent Units Navigation Keys ensure
the green circle is highlighting 'Camera 1'. Now press the Mode/Enter Key
7. Select the 'Add' icon with the plus symbol and press the Mode/Enter Key.
8. The screen will show the Parent Unit at the bottom transmitting a signal to Baby Unit
Jun 05, 2012 | Baby Care
THE PARENT UNIT DOESNT SEEM TO PICK UP THE BABY UNIT THE PARENT UNIT SEEMS TO KEEP FLASHING WITH 2 LINES IN THE MIDDLE OF THE SCREEN WITH THE BABY UNIT FLASHING TO.
The units are not locking in to the same frequency and if this is new it must be referrred back . However if this was working earlier then there could be a shift in the communicating frequencies between the master and slave.
So remove battery of allthe units and replace after 15 minutes.,Try a reset if desccribed in the manual or the procedure for intial set up once again .
Sep 19, 2010 | Angelcare Deluxe Movement Sound Monitor...
My parent unit is not working. All it does is flash when it's supposed to show me the pendulum swinging, room temp etc. I have forgotten how to reset it. Help please
Manuals here: http://www.angelcare-monitor.com/Canada/en/help#tabs-2
Had same problem - here's what worked for AC401 (from manual):
CONNECTING THE PARENTS UNIT TO THE NURSERY UNIT: If you lose the connection between the 2 units,turn them both off. Turn ON the parents unit and press and hold the MENU button ,the "out of range"indicator will flash and you will hear a beep.Turn ON the nursery unit and press and hold the top button of the nursery unit to reconnect. The Tic light flashes.This normally happens within a few seconds and you will hear a bleep to confirm it. If successful, the parents unit display will first show the channel of transmission (C1 to C8), which will be replaced by the room temperature and icons for all activated functions.
Oct 02, 2009 | Angelcare Deluxe Movement Sensor & Sound...
Philips Avent SCD520 Baby monitor interference
cold be intefernce from any other electronic device... potentially at a neighbours. even though mifddle of the night, could be microwave, kettle, electric blanmket, heaitng system, etc etc ... any appliance. If on the 2.4ghz wavelength could also be a computer wireless network nearby? good luck with finding and isolating - worst case, take it back and get one on the 1.8ghz ... which is reserved for these devices, and cordless phones, etc
Aug 30, 2009 | Philips Avent Scd520 Dect Baby Monitor
Philips Avent® Scd510 Dect Baby Monitor Logo
328 people viewed this question
Top Philips Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Philips Baby Gear Expert? Answer questions, earn points and help others
