Question about Lithonia Lighting Psq500 Power Sentry Inverter Charger
I need a lighting diagram for a Power Sentry psq500 to hook up to a one lamp of a two lamp fixture. (2 4 ft. T8 lamp)
2 Suggested Answers
SOURCE: i need a lithona lighting
http://www.lithonia.com/SpecSheets.aspx
Lithona has a lot of products and they show the manuals.
Unlike a lot of companies where manuals are not available, as if customers live in the 1980's and still write to companies asking for information.
I don't see your speicific product at Lithona.
A search for 'power sentry' turned up many possible products.
Unlike a lot of sites that just say, 0 results.
Many times, the same product will have more than 1 name or product-number depending on who is selling the product >>> that's how different companies can sell the same product but claim their product line is unique.
You might search the manuals at Lithona and find a similar product under a different name or number.
Posted on Oct 15, 2010
How to retrofit fluorescent tube with led tube lights
Note:
First, corrosive or solubility chemicals will destroy the protective shell of lamps.
Second, the normal ambient temperature is -20 ° C to 40 ° C, if beyond the scope of this provision, it will make adversely affect on the lifespan of the product.
Third, before installing, do not connect high-voltage power supply, if there is damage to the external of lamp, switching to the engineers with qualifications for the repair and replacement; otherwise,the bulbs can not be replaced; take care of the the discharge of fire and shock.
Replacement Procedures Information:
First, the LED tube is generally a double-ended conductive LED lamp containing professionally designed built-in power supply, which can be directly input voltage AC100-240V,it can be mounted directly on a dedicated LED T8 tube light shelves, do not need to add other drives.
Second, the LED tube can directly replace fluorescent tubes, the user can remove the original fluorescent tubes and install LED tube, then double-check the configuration of lighthouse, following the figure A, B, C three installation diagram for installation.
Third, cut off the power for the installation, repair, maintenance and demolition work to avoid accidents.
Installation Guide:
led-tube-light-installation-instruction.jpgA, connect the power cord on the lighthouse to the external power lines, no need to distinguish neutral wire and line of fire fit with LED lamps , then rotate 90 °,then connect the power to light up.
B, if there is starter on light house , take out the starter, then just repeat the A
For more information about LED tube,just visit www.ledclan.com
May 21, 2014 | Acclaim PIXEL TUBE w/ 15 RGB LEDs
How to change bulb thats a t8 fluresent fixture in a home
A Lot of the T8 style have very little room to move the tubes around, check a few things:
See if you need to remove the tubes in a specific order,
See if the ends of the fixture are removable,
Instead of dropping both ends of the tube drop one side first,
Sometimes after the tube has been twisted and dropped slightly you may have to maneuver the pins to avoid the fixture.
Dec 11, 2012 | Philips 6996C FKD 230V 1000W Lighting
Loud sound when it is on
Cooling fans can sometimes be a source of noise, as can loose windings on the transformer. If it is not overheating and funtions normally, the noise is just something to live with. It is not always considered a defect, but you can ask the vendor about it.
Jan 13, 2012 | Lithonia Lighting Psq500 Power Sentry...
Are 24 watt t5 lights brighter than 24watt t8 lights
brightness is only greater if the lums are higher, so no if you use the same wattage, remember t8 lamps will only work in t8 fixtures, same with t5 lights, only in a t5 fixture, there are brighter lamps for both fixture you just have to look as to how bright you want
Sep 15, 2011 | Home
LIGHTING QUESTION: I have a GE Pro line T8 Ballast w/ (8) wires (2) Blue, (2) Red, (2) yellow plus Black & White. I know what the Black & White are for and are not connected to the lamps. Can you...
Try this link-- for a wiring diagram--- let us know if this helps-- Mack
http://www.replicasuper.com/wp-content/uploads/2016/01/T12-Ballast-Wiring-Diagram-Here-Is-An-Example-Of-A-Circuit-That-You-Can-Make-The-Guidelines-For-Making.jpg
Oct 27, 2017 | Vacuums
We have an existing wall mounted occupancy sensor ON/ AUTO/OFF (2 wire with equipment grounding conductor.) Until now, the sensor has controlled two (2) incandescent medium base porcelain lamp holders (60W...
This is not a surprise. Many wall-mounted devices such as occupancy sensors and dimmers operate by leaking a little bit of power through the light fixtures. In the world of incandescent, this was rarely a problem - that little bit of current wasn't enough to excite the bulb. But now that we're living in a world of low-wattage lamp types, that little bit of current is now enough power to excite the lamp and cause what you're seeing. The added detriment is that little bit of pulsing that you see in the CFL can actually wear it out pretty quickly.
The short-term solution is to use the older-style, incandescent lamps.
Another short-term solution would be to attempt using another manufacturer's CFL or try an LED lamp - that's by no stretch a guarantee, you'd be rolling the dice with each lamp choice you made. The higher wattage the lamps, the less likely you'll see an issue.
There are two long-term solutions:
1) Add another lamp - the more lamps the control sees, the less leakage current that goes through each lamp. Several people have solved this by adding a 'dummy' incandescent load (like a 15W or 25W lamp) somewhere in the lighting circuit to take the brunt of the leakage.
2) Change the wall-sensor. Lutron makes one (MS-OPS6M-DV-WH) that has extremely low leakage current and may solve the problem. But the best way to guarantee it won't be an issue is to use a wall-sensor that connects to the neutral wire in the wallbox. Those devices take that leakage current and dump it out the neural wire rather than run in through the light fixture. Lutron makes one of those as well (MS-OPS5AM-WH)
Oct 20, 2010 | Leviton Manual-On Occupancy Sensor -...
I need a lithona lighting power sentry psdl3 wiring diagram
Oct 15, 2010 | Lithonia Lighting Psq500 Power Sentry...
No power to lighting ballast ,only lights up on loss of power 277v at emergency ballast
Follow the appropriate wiring exactly. There are about 6-8 different diagrams. Find your lamp type and number of lamps. Locate your ballast type (usually instant these days) Quite often these diagrams show a switch on the power lead going to the operating ballast. If it isn't on a switch be sure to wire it in with the lead to the emergency battery ballast.
Jun 30, 2010 | Lithonia Lighting Psq500 Power Sentry...
Kill power to light and emergency single light does not turn on also with power on push test knob and emergency bulb not come on
Hello Ramon, Check the power back (battery cell) as without a functioning battery pack, the emerbency light won't function.
Typically the batery packs will need to be replaced periodically every 4-5 years, depending on the istallation location and ambient temperatures.
When you kill the power to the emergency lighting circuit the PSQ is switched to operate automatically on battery power only. The same thing occurs when you press the test button; it disconnects the lighting from the electric power that keeps the battery charged and ready for service. You might also want to check the bulbs with a test meter (remove the bulbs from the fixture and test with the Ohm setting) While rare that these bulbs burn out, since they aren't usually illuminated often, only during a power disruption/outage, etc.
Here's a link to the Lithonia site with the spec sheets for the PSQ series of emergency lighting products, for your use and reference.
http://www.lithonia.com/product/advSrch.aspx
I hope you find this Very Helpful and best regards!
Nov 24, 2009 | Lithonia Lighting Psq500 Power Sentry...
Changing ballast
Here is the link for wiring Lithonia Power Sentry Ballasts: http://www.acuitybrandslighting.com/Library/LL/documents/Installation%20Instruction%20Sheets/PS.pdf
Hope this helps Sparkylikes480
Mar 27, 2009 | Lithonia Lighting Psq500 Power Sentry...
Lithonia Lighting Psq500 Power Sentry Inverter Charger Logo
168 people viewed this question
Top Lithonia Lighting Electronics - Others Experts
Are you a Lithonia Lighting Electronics - Other Expert? Answer questions, earn points and help others
