Question about Toshiba Satellite A135-S2386 Notebook
Have a brand new Toshiba satelite and it won't open. The Num lock key is lit .
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Posted on Sep 18, 2010
    Guru:
  • 830 Answers
Take the battery out and wait for three minutes. Put the battery back in. If this doesn't work, try starting it without the battery.
If it is brand new, I would take advantage of the warranty on the laptop. This sounds like a faulty battery.
Posted on Sep 16, 2010
Cant find num lock or equivelant on a toshiba laptop
Depending on the age and layout of your keyboard it could be a couple of options. If you have a button that looks like either of the following pictures then press FN key and that button or press the FN key and the F11 key which should have a little square picture that looks like a grid. A couple of higher end models have a little led strip above the keyboard that just looks like indicator lights but in truth are actually toggle buttons as well try gently pushing the lit number one if you have this strip. Hope this helps.
9f0df0be-f528-425a-bdce-86e84e32beb5.jpg 0b37502e-48d8-4bdf-9785-624c3b230fe5.jpg
Mar 17, 2014 | Computers & Internet
Numerical keypad offset numlock on keyboard
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Nov 18, 2012 | Genius KB9229047 Keyboard
When I type on my keyboard on my computer numbers are popping up instead of letters
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times.
Also, try this too: Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
hope this helps
Try this. Press the Start key + R. type osk in that box and hit enter On this keyboard, try toggling numlock scrolllock and capslock a few times
or
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Nov 08, 2012 | Computers & Internet
My keyboard is locked and 3 lights above the number pad are lit
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Oct 03, 2012 | eMachines Computers & Internet
Toshiba satellite c655d-5332 keys problem
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Sep 23, 2012 | Toshiba NB205-N210 Netbook
Keyboard letters are numbers and numbers are letters
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Aug 26, 2012 | Amstron Toshiba Satellite M305-S49052...
My laptop keyboard is locked
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Jul 15, 2012 | Toshiba Satellite A135-S7403, A135-S7404,...
My keyboard is typing numbers and characters instead of letters!
Sounds like you have num lock on. The Num lock key is usually the same as Scrlk but to select the Num lock you have to press and hold Shift then press NumLk/ScrLk. A light should light up to indicate the keypad is on/off.
Regards,
G33k
May 11, 2011 | IBM ThinkPad T30 2366 Notebook
Some of the keys on my Toshiba satelite keyboard
Turn off "Num Lock"on your keyboard... Thanks..
Dec 21, 2009 | Sony VAIO PCG-K35 Notebook
Num Lock key must be off. I can't log in using my 4 digit code. How do I turn on the Num Lock key? It is not marked.
It is one of the function keys, it will have a keypad symbol on it.
On my Toshiba it is the F11 key.
Try the Fn key + F11 key to enable the numbers, press the combination of key again to turn off Num Lock
Apr 30, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135-S2386 Notebook Logo
54 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
