Question about Walkera HM5#10 RC Helicopter
My upper rotor does not always power up when i throttle up on my walkera 5#10. i have replaced motors with new factory motors thinking that was the problem but same problem
Hi, I had this same problem but its my bottom rotor that wont throttle up. Before you bind put the throttle in full. After it binds return the throttle to min. and its ready to go. I hope this helps, although its not a fix. It a cheap one $$$.
Posted on Jan 02, 2013
2 Suggested Answers
SOURCE: I have a new Walkera 5#10. The Tx binds with the
Hi, well I indeed love my Chopper, and have had a few problems with it too...Usually though it has been connections, or the battery, or a jammed motor/servo/gears... I haven't yet found an actual faulty electronics, per sa.
So what you need to do is inspect ALL plugs clips switches & joints, if any are suspect, or the wires broken off then simply resolder, or even tightly wrap the wire around the terminal in a pinch.
See if you can swap over the servos/motors over to see if the motor/servo is faulty? If you swap and the problem "Follows" then that servo/motor is the faulty one.
basically the receiver sees the data stream that tells the servos what to do and how long to do it for.. So it can only be one of a few things to work through.
Posted on Dec 17, 2010
Motors stop as throttle increases
Spin the props over by hand and see if any are dragging; if they are then that is the problem. Those speed controllers have a safety that stops them if there is resistance on the motor. One other thing it could be is your battery could be bad or not getting charged properly. Good luck.
Mar 24, 2014 | Walkera QR X350 Quadcopter BNF WALQRX350
Code 0300 2000 Mercury Villager
Camshaft position sensor causing random misfire. Stuck EGR valve or clogged EGR ports.
Please comment on my info.
Mar 30, 2013 | 2000 Mercury Villager
Hi, I have a Walkera CB180d and there doesn't seem to be enough power for the helicopter to lift higher than my shoulders. I replaced the main rotor with a new one after I noticed a gap in the...
The gap is causing you to loose power transfer. Replace the main gear and you should be back in the air. The CB180 is a fixed pitch, so as long as the blades are intact and straight, you can't do anything esle to them. Also make sure your battery is good and fully charged.
Aug 12, 2011 | RC Remote Control Helicopter Ready To Fly
I have a new walkera uflys (rx-2435) when i get it up off the ground it spinnes round and round how do i fix this problem
sir jeremydylan2
you have a problem with your rear rotor assembly.
if your rear rotor shaft is broken or the gear is the copter will spin around and around.
or, if these parts are not broken then your trim needs adjustment or, you need to learn to fly and control the rear tail rotor so it does not spin around. Thats your answer. thundermounts@gustywinds.com
Feb 18, 2011 | Walkera Toys
Walkera lama 400 just spins round
The walkera Lama has a bad gear setup,there are two tiny screws on the top
gear which powers your bottom blades one on each side of the outer shaft
if these two screws were not properly tighened at the factory or you ran yourLama
400 into the ground even if it was at a slow rotation when the bottom impacts
the ground the bolts shear off the outer shaft and you no longer have 100%
power to those blades,if your helicopter spins clockwise and you tried every
thing,this is the problem,replacement is required or you can tear it all down
and drill and tap two new holes with new screws,these are machine screws
and are less than 4/40 which is very small.To check hold top gear with two
fingers left and right side of gear and turn the bottom blades only,if the blades
turn your shaft to gear screws are sheared off
good luck
SK Florida
Sep 12, 2010 | Walkera Toys
Just bought the Walkera 38 Chinook. First flight I got an inch off the ground and landed it. Next attempt the top rotors spun initially then stops causing them to come in contact with the bottom ones. ...
Sorry for late reply, youve probably sorted this by now. This is common problen, some thing to do with the gyro. If you want to spin the rotors without takeing off the trick is to put full right turn then the gyro tries to compensate keeping the rotors turning at speed. To lift of the trick is to get airborn quickly without raising rotor speed slowly then the gyro will keep compensating and keep the rotors running. Had same problem myself, although saved the gears fortunately.
Hope this helps
Matt
Sep 02, 2010 | Walkera New 38 CH47 Chinook RTF 24GHz RC...
Replace tail rudder blade on walkera cb 180d
yea cut it off longways down the shaft with large parrot nose plyers finish with little ones back up shaft and drive on rotor with small deep well socket simple!,
Apr 01, 2010 | Walkera #35C: Main Rotor Blade (Fiber...
I bought my sons Walker Lama 2 Copters and we need
Is the lower shaft blade not rotating.. and making flimsy noise....and olnly the upper rotor blades rotate and it does not fly even at full throttle...
If above is the problem, then check the corresponding motor gear, if you could see, white shades over the black, plastic body, then the chances of that gear, might have been worn out.. if it is the same, then replace the gear, it should work......
Mar 20, 2009 | Walkera HM5#10 RC Helicopter
Receiver problems right out of the box!!
You may have to "bind" the receiver to the transmitter again. See the instructions that came with the transmitter on how to do this. If this not the problem the hobby shop is obliged to make sure it works so take it back before it get damaged.
Mar 16, 2009 | Walkera HM5#10 RC Helicopter
Walkera HM5#10 RC Helicopter Logo
130 people viewed this question
Top Walkera Toys Experts
ray gallant
Are you a Walkera Toy Expert? Answer questions, earn points and help others
