Question about Canon PowerShot A520 Digital Camera
Shutter Opens Partially
I have a PowerShot 520 which recently developed a problem when I turn it on. Instead of opening the shutter fully so that I could see a full scene in my monitor it opens partially so that I can only see a 1/4" wide scene running from the upper left corner to the lower right corner. I can open the shutter fully only then I move the zoom lever to the right and then to the left.
  • caas May 28, 2008
    I tried the above suggestions without success which led me to call a local camera shop to ask about repairs. His costs exceeded the cost of the camera but he suggested removing the shutters which I did.
    I used a very small screwdriver from my glass repair kit to lift up the lenses and then pulled them out with needle nose pliers.
    The camera must be in the off position so the shutters don't move when touched.
    After doing the above I turned the camera on and off multiple times and I had no problems getting clear pictures.
  • Canon Master
  • 4,738 Answers
This is a common problem for the A520 (it happens on mine sometimes). Recommend trying only the simple fixes listed on the following web page, but do not recommend opening the front cover which is also listed here. The A520 is a little tricky getting back together.
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on May 18, 2008
My powershot A540 shows a black screen and takes blank photos. Something between the viewer/card and the lens is closed and only opens occasionally, no matter how much I fiddle with the settings.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 04, 2011 | Canon PowerShot A540 Digital Camera
Canon Power Shot SD750 screen went black. Read solutions, not sure what TV mode is? Is it same as video mode?
Tv is "shutter priority" mode. The Canon SD cameras do not have that mode. Instead see Fix 5A of the below link. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Pictures takeh are too bright
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html for further info and a simple fix that may help.
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Nov 07, 2010 | Canon PowerShot A420 Digital Camera
My Canon PowerShot SD1000 shoots completely black pictures. The lens is open and there is no damage to the lens or the screen. The battery is fully charged and I've even tried a different memory card. It...
Nov 06, 2009 | Canon PowerShot SD1000 Digital Camera
LCD screen is blank and pictures are also blank
Jul 24, 2009 | Canon PowerShot A620 Digital Camera
Lens blocked? Canon PowerShot SD1100 IS, recently water damaged
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Jul 13, 2009 | Canon PowerShot SD1100 IS Digital Camera
Shutter not opening fully while taking snap
Hi there
Try spraying the shutter with WD-40 and keep on opening and closing it until it works properly
Good luck and regards
Jan 07, 2009 | Canon PowerShot A470 Digital Camera
Nikon fm10 35mm SLR developed pictures turn out white
That sounds like your shutter isn't opening. take the lens of and set the shutter speed to B this should keep the shutter open as long as the release is pushed down. advance one frame and hold down the shutter release while looking at the opening where the lens should be. If the shutter opens you will hear it and see the back plane where the film would sit to be exposed. I expect your shutter won't open.
Good luck
Rob
Dec 11, 2008 | Nikon FM10 35mm SLR Camera
Shutter will not open fully
You should submit the unit for warranty service.
Jun 03, 2008 | Canon PowerShot A520 Digital Camera
Shutter cover opens partially in power shot A520
brother the camera gear system has got problems it seems. it happens due to misplacement of gears inside it.
even tough u can do it manually dont take risk of doing it manually untill u have full knowledge of internal parts. am from chenai. here in our service centre it costs around 1800 rupees for servicing it. so better take it to service centre.
Dec 23, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot A520 Digital Camera Logo
184 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
